Front end popping noise - brand new Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by zoomie1983, Dec 1, 2017.
  1. Oct 25, 2018 at 2:11 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    My new truck with less than 300 miles is doing this. Only clicks the first couple feet, 15-20 feet, right or left. One POP.. doesn't seem to pop after that, but always after each time I start my car and drive.
    And I thought my Chevy had problems.. roll eyes.
  2. Oct 25, 2018 at 3:45 PM
    helloo
    helloo New Member
    Aurora, CO
    2018 Black TRD CM Limited
    ABS check. Happens at like 7MPH. Normal.
  3. Oct 25, 2018 at 4:13 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Yes, I realize that now after observing the speedo needle 6-7mph.
  4. Dec 18, 2018 at 2:44 PM
    one1paa808
    one1paa808 New Member
    I’m a ase L1 master technician out of Hawaii so this problem everyone is experiencing is a design flaw in the brakes Tacoma’s and tundras with the four piston fixed caliper systems will be affetected so to verify this have someone put the truck in drive roll coward to load the front end stop while pressing the brake and loading the front end have the assistant turn the wheel right to left lock to lock while holding the caliper watch not to get your arm caught between the wheel and spindle you’ll feel movement going through the rotor pads and calipers so far every Tacoma and tundra I’ve done this to made noise from 2005 to 2018 and there is no tab or recall for this issue so when you take your trucks in show the writer the noise and let me know what they say I’m just curious
  5. Mar 22, 2019 at 10:59 PM
    lotsip
    lotsip New Member
    My brand new 2019 tundra does exactly the same thing! Took it back to the dealership, and it wouldnt happen there on a test drive, so they never even put it on a lift to check anything! Of course it hasnt stopped happening for me. Usually happens coming out of my driveway as I turn? And randomly turning at a stop sign. Did you u find the cause?
  6. Mar 22, 2019 at 11:03 PM
    lotsip
    lotsip New Member
    Exactly my issue! What did u do?
  7. Mar 22, 2019 at 11:06 PM
    lotsip
    lotsip New Member
    Exactly! Same issue. So ignore it? Brand new truck here.
  8. Mar 23, 2019 at 5:46 AM
    CamaroSsToTundra
    CamaroSsToTundra New Member
    Ohio
    2018 Tundra
  9. Apr 3, 2019 at 2:28 PM
    Brandondsfla
    Brandondsfla New Member
    2013 White SR5 w/mods
    Afe throttle body spacer, k&n Cai, 3" lift, 33" Nitto'$
    I have a 2013, doing the same thing. I have scoured the internet at this point. I found another thread on here, about this, mine is Definitely not a suspension issue, sounds like someone dropping tic tac on the dash. They say that the fix is to push thick pieces of velcVe between the front of the dash and the bottom of the windshield. This makes sense to me, mine could for sure be the 2 pieces rubbing. I will be trying the fix as soon as I get home.
  10. Apr 4, 2019 at 5:30 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    14burrito, hagrid and Js18tundra like this.
  11. Apr 4, 2019 at 7:59 PM
    Jerguy
    Jerguy New Member
    Same clicking/rattling noise but i don’t have a skid plate. Super annoying. 2018 and I have heard it since it only had 400 miles
    Any suggestions? Dealer says everything is fine.
  12. May 28, 2019 at 11:28 PM
    jabula_za
    jabula_za New Member
    Shaun
    Sabre Springs, CA
    2017 Tundra SR DC 4x4
    Icon 2.5s with RR & CDCV, 17x8.5 Method MR316 with BFG AT K02 32.6x17x10.5. K&N Filter, Blacked out tailgate emblems.
    Same issue on mine. Not the abs. Clunk when accelerating slowly or hard, even braking but all at low speeds.
    Took the Toyota tech for a joy ride to show him, he eventually got his ears tuned in and said he could also hear it.
    He took it back to the shop and when I called the service advisor he said the technician said we couldn’t reproduce the noise on our test ride. Stupid effing c***s.
    I’ve taken it to them twice for the issue - no joy.
    Replaced the front coil overs, UCA’s and disconnected the sway bar - noise still there, definitely got worse over the past year.
    It’s driving me nuts has 17000 when I purchased it and now a year later only 22000 so everything is pretty much new
  13. May 29, 2019 at 8:39 AM
    djhase
    djhase member
    David
    Southern Illinois
    2019 Silver Tundra TRD
    I have a new 2019 with 1500 miles. Since day one, I hear (maybe) and feel (definitely) thru the wheel and floor board a pop like a spring popping from released tension. Only happens once after starting the truck and moving a few feet at a slow rate of speed. Its a very faint feel and sound so I have not been too concerned. The sound is not heard or felt any other time but happens every time we start the truck and beginning to roll. Turning the wheel doesn't matter. Happens turned or straight. I assume its a normal thing. Have not asked the dealer to look at it. It doesn't seem like an issue worth messing with actually.
  14. May 29, 2019 at 9:01 AM
    APatt
    APatt New Member
    2019 Cement SR5 CM 4x4
    Diamondback Bed Cover, Voodoo Steel Max Modular Bed Rack, iKamper Skycamp
    I agree with your comments. I have a brand new 2019 with 800 miles on it and it too pops when moving forward whether turning or not. Earlier posts noticed it around 6-7mph. Mine pops around the 6mph mark. I’m going with the thought of it being the ABS check until I start hearing it repeatedly at higher speeds.
  15. May 29, 2019 at 10:00 AM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    Funny thing is I had this same issue, until I lifted my truck. As soon as I did this the pooping went away. Maybe has to do with the UCAs since I swapped those out as well.
  16. May 29, 2019 at 10:05 AM
    Boxer310
    Boxer310 New Member
    2018 white tundra crewmax sr5
    Mine does not do that I would take that truck back to dealer and tell them u paid for a new truck and want a new truck with no problems
  17. Oct 18, 2019 at 9:28 PM
    New_DoorDing
    New_DoorDing New Member
    2016 TRD Pro DoubleCab
    My skid plate turned out turned out to be the culprit. Watch this video to verify if this is the noise you’re hearing. Im taking to dealership to have them add spacers. https://youtu.be/bgLBBwW7O-s
  18. Dec 22, 2019 at 12:50 PM
    TRDPROSean
    TRDPROSean New Member
    Hattiesburg, MS
    2017 CM TRD PRO
    275/70r18 Nitto Ridge Grapplers, TRD rear bar and intake, Coachbuilder +2 shackles, Corsa 14916 exhaust, UWS lo pro toolbox, Craven Speed stubby, tint
    Thanks for the video. My Pro has just recently started making this popping noise. Or, I've just started to notice it. I tried to tighten every bolt on the skid plate and they all seem to be pretty tight. I'll try to remove the rear ones and see if I can get some rubber shimmed in there. I'll report back.
  19. Dec 22, 2019 at 12:57 PM
    #49
    nowayout
    nowayout New Member
    NY
    15 Dbl
    @New_DoorDing that's what mine sounds like but I don't have a pro.
  20. Dec 22, 2019 at 1:04 PM
    #50
    TRDPROSean
    Hattiesburg, MS
    2017 CM TRD PRO
    Frustrating as hell tracking down noises.
    nowayout[QUOTED] likes this.
  21. Dec 22, 2019 at 4:51 PM
    #51
    Cornilsa
    Cornilsa New Member
    Andy
    Gaston OR
    2014 Tundra Crew Max Limited
    Mines in The shop right now trying to figure it out
  22. Dec 23, 2019 at 2:33 PM
    #52
    d4ivg3i2j
    d4ivg3i2j New Member
    J
    I was 20 feet out of the parking spot of the dealer with my new '20 PRO and I heard the noise. It only pops once, always after a startup. It's a mild sound I attributed to something getting started/staged or whatever. Always within the first 15/20 feet.
    nowayout likes this.
  23. Dec 23, 2019 at 2:55 PM
    #53
    Cornilsa
    Cornilsa New Member
    Andy
    Gaston OR
    Mine ended up being the lower control arms the van blots we’re not torqued to spec
  24. Dec 23, 2019 at 3:53 PM
    #54
    TexasYota
    TexasYota Custom Yotas
    Fabian
    2014 Black Tundra CM SR5
    Fab Fours front & rear replacement bumpers, Toyo Open County 35x12.50x18, Method NV Wheels, OME suspension Front & Rear, Camburg 1.5 Uniball UCA's, Coachbuilder 3" Shackles, and much more
    My 2014 has the same problem, pop/clunk when pulling out of driveway and sharp turns. I'm pretty sure it's the LCA's needing to be retorqued. I've deleted my swaybar and skid plate so there is no way those are the problems. I'll try to retorque soon and see if that fixes it
  25. Dec 23, 2019 at 3:57 PM
    #55
    Cornilsa
    Cornilsa New Member
    Andy
    Gaston OR
    Let’s hope so, my clunk wasn’t so much in turning as it was stopping a a stop sign or backing out ok a parking spot and hitting the brakes
  26. Dec 23, 2019 at 4:12 PM
    #56
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    For anyone having noises like this try going under the hood and giving the fuse box a jiggle. Its the box on the firewall in front of the passenger. I had same noise until i put a zip tie on , securing the box tightly to the mounting bracket
  27. Jan 29, 2020 at 12:17 PM
    #57
    Dez R
    Dez R New Member
    2018 tundra
    None
    Mine is a 2018 trd 4x4 and since new Iv also heard a poping sound as if a loose shock or hood latch not catching the hood right. Soulds like its coming from passanger side. Almost sound like a double bounce at times. Kind of driving me crazy too. Happens more in cold at slow speeds when going over covered pot holes or rail road tracks even crossing intersection where it has a slight dip. I think that when cold rubber shrinks and something to due with either rubber bushing that is held by loose bolt can eventually cause it to sound like that, when the day is sunny and warm dont hear it much. Could be the rubber stoper that tension the hood . who knowshope its figured out. I went to the passenger front wheel well and banged on it closest to light on inside and heard somthing on the inside dribble could that be it didnt have time to take of plastic wheel well will come around to it soon.
  28. Jan 29, 2020 at 12:19 PM
    #58
    Dez R
    Dez R New Member
    2018 tundra
    None
    Darren hadnt seen your reply ill check that thanks.
  29. Jan 29, 2020 at 12:21 PM
    #59
    Dez R
    Dez R New Member
    2018 tundra
    None
    Come on toyota don't have time to figure these things out. Love truck but hmmmmmmm.
  30. Feb 21, 2020 at 10:13 PM
    #60
    TRDPROSean
    Hattiesburg, MS
    2017 CM TRD PRO
    Mine wound up being the skid plate. I loosened it up, snatched off some rubber from impact gloves and jammed that between skid plate and crossmember. Noise is gone
