Frame rust
Discussion in '1st Gen Tundras (2000-2006)' started by skeeter1949, Mar 15, 2020.
  1. Mar 15, 2020 at 5:15 PM
    skeeter1949
    skeeter1949 [OP] New Member
    Cecil
    2014 TSS 4WD
    TRD Exhaust, K&N Filter
    I have a 2003 Tundra that is starting to get some rust on the frame. That may not be big problem to take care of, but what I am worried about is what may be inside the frame rails. No way to get something inside the rails and clean it out. Is there something that I fan spray in there that will neutralize anything that is in there.
  2. Mar 15, 2020 at 5:20 PM
    18" TRD Off Road Wheels
    You could try something like fluid film to coat it all. I think it would arrest any further rust, but I don't know for sure.
    Wallygator likes this.
  3. Mar 15, 2020 at 5:31 PM
    Comet
    Comet Yes, it is a tundra.
    2001 Tundra Limited 4x4 2nd owner 120K and counting.
    De-flared
    Fluid Film is good. Look up WoolWax too. I believe same company, different smell and a little thicker.
    Wallygator, rebmo and GODZILLA like this.
  4. Mar 15, 2020 at 5:36 PM
    Linuxmale
    Linuxmale 2018 Tundra 2003 Tj
    Sault Sainte Marie, MI
    2018 CREWMAX TRD Off Road ( a Canadian import )
    I use Fluid Film on my frames. My 16 year
    Old Jeep has almost no frame rust ( I didn’t do it from new ) there are several kits you can buy and videos on YouTube about applying it inside of frame rails. Great stuff. Fluid Film and Wool Wax are both just lanolin. Somehow they got the color and smell out of the Woolwax. Haven’t used it much yet compared to the Fluid Film
  5. Mar 15, 2020 at 5:38 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Woolwax is better but more difficult to apply. Fluid Film is easy to spray on, but needs to be reapplied occasionally
    .02
  6. Mar 15, 2020 at 5:49 PM
    Flightmech65
    Flightmech65 New Member
    Bucks County, PA
    2015 Crew 1794 & 2016 SR5
    TRD duals and cold air
    Check out Eastwood. They have a ton of different coatings
  7. Mar 15, 2020 at 7:21 PM
    skeeter1949
    Cecil
    2014 TSS 4WD
    Thanks all...I am familiar with Eastwood products, but never heard of fluid film, or wool wax. Gonna check out both of those.
    Thanks again.
  8. Mar 15, 2020 at 7:47 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I know it might be tough to get into all the nooks and crannies inside the rails, but i would try to get a good rust neutralizer inside there before coating it with something like a fluid film. Adding a coating over existing rust might just add to the rusting problem. Just my 2 cents of course, and good luck. :thumbsup:
  9. Mar 15, 2020 at 7:59 PM
    Fluid film isn't a coating like the black tar mess they use to prevent rust. It's similar to smearing it with oil, so it will soak into any existing rust and (hopefully) arrest the process.
    Linuxmale likes this.
  10. Mar 15, 2020 at 8:03 PM
    skeeter1949
    Cecil
    2014 TSS 4WD
    I do intend to get get some type neutralizer in the rails. I think Eastwood has some with an application gun and hoses. I was and am worried about getting some sort of mechanical device, ie...a wire brush, or whip in there to break loose anything that may be in there. I plan too run a plumbers type bore scope in there to take a look at what is in there, if anything . It may be a moot issue.
    TILLY and GODZILLA like this.
  11. Mar 15, 2020 at 8:04 PM
    Knowing is half the battle, as they say. Being able to see it will give you intel on how best to move forward.
  12. Mar 15, 2020 at 8:32 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    I just did mine yesterday with Woolwax. Also bought the kit that came with the undercoating gun. Also had a flexible hose you can attach that sprays in 360 degree directions. Great to get in the closed frame areas.
    For my Tundra 8 ft bed used 3 1/2 bottles. Putting it on pretty thick
    To spray good thru the gun. I needed to raise the psi to 90 -100. And product was still to thick. Had to heat the product to 80 degrees to make it a little thinner.
    Just sat the bottles in a bucket of hot water for 30 minutes.
    3 years ago did my rust areas with rust converter and rustoleum undercoating over that. That was a complete waste of time and money.
    Lasted well on places with no rust. With rust I did a lot of prep and only lasted a year or two.
    May work if you have no rust or very, very little rust.
    I choose woolwax after a lot of research. And think this is the best solution. But not like I have a lot off experience with this and time will tell.
  13. Mar 15, 2020 at 8:48 PM
    TILLY
    Massachusetts
    Everyone has their favorite product to use in this arena, but we all have the same goal of keeping our Tundras rust free!..Good luck with it. :)
    GODZILLA likes this.
  14. Mar 16, 2020 at 4:23 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Luckily we have pretty good access to the boxed portion of the frame on our trucks since it's not boxed for the rear-most 2/3.
    If you haven't already, check out the pics in this recent thread. They give you a good indication of the problem areas you should pay particular attention to when you're inspecting with your boroscope.
  15. Mar 16, 2020 at 4:33 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    As others have suggested, fluid film is a good choice and is mentioned each week when a tundra frame thread is started.
    If you won't more reading and comments, the below forum search shows most of the past weekly threads concerning frame rust....
    https://www.tundras.com/search/2739730/?q=Frame&t=post&o=date&c[title_only]=1&c[node]=2
  16. Mar 16, 2020 at 4:38 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  17. Mar 16, 2020 at 6:31 AM
    Professional Hand Model
    Hand Protectors
    Having a 1st Gen I’ve been using a two prong approach:
    1) Grease rubbing the entirety of frame with Moly-b even using a plunger to get the grease up into the boxed portion under/around the engine. The grease over time turns into a gooey shell that doesn’t wash off like Fluid Film.
    2) PB Blaster Penetration Spray shot up into the box frame to get into all the nooks and crannies/welds. You can slide the little straw into the factory holes and spray. Also, you can direct some spray between the frame overlap at said holes. Open the engine hood and soak your frame from above directing into the holes as best as possible. I’ve done this a few times in the past 2 years with success. Stay vigilant.
    N84434 likes this.
  18. Mar 24, 2020 at 3:04 AM
    w666
    Maryland
    I was searching the net for something else when I cane upon these interesting pics...
    This of course is not limited to Toyota products, but it seems like we have more than our fair share.
  19. Mar 30, 2020 at 10:50 AM
    Huvster
    Huvster New Member
    Jt
    2002 4x4 6cyl manual
    Throughly pressure wash then fluid film spring and fall. Keep it up every year you will be good.
  20. Apr 5, 2020 at 9:12 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    I assume you used fluid film on your truck. What did you set the psi @ when spraying? The site says they recommend a min of 2000 PSI.
  21. Apr 5, 2020 at 9:36 AM
    Bronzeback
    Bronzeback New Member
    POR15 also now comes in a spray can. Expensive, but it does the job.
  22. Apr 6, 2020 at 1:45 PM
    Linuxmale
    I sprayed fluid film through a “undercoat gun” I got Amazon for under $20. Depending on how cold it is I used from 50-70psi
    rebmo likes this.
  23. Apr 6, 2020 at 4:18 PM
    RR60
    RR60 New Member
    If you buy everything else for the prep work before. Then being brittle. When it cracks the rust grows underneath,
  24. Apr 6, 2020 at 4:20 PM
    RR60
    RR60 New Member
    I think you have that wrong with 2000 psi.
    I used woolwax. A thicker form made by Fluid Flim and still just used a pressure of 90 to 100 psi.
    rebmo likes this.
  25. Apr 7, 2020 at 4:43 PM
    Bronzeback
    I spray everything down with APC then power wash underneath. Wire brush and POR15 spray. No brittleness or peeling to be found.
  26. Apr 7, 2020 at 6:29 PM
    skeeter1949
    Cecil
    2014 TSS 4WD
    Bronzeback...I am not familiar with APC..what is it?
  27. Apr 7, 2020 at 6:53 PM
    Bronzeback
    Just all purpose cleaner. Simple green, etc.
  28. Apr 8, 2020 at 5:39 AM
    skeeter1949
    Cecil
    2014 TSS 4WD
    Thanks....I originally thought that, but then thought ...thats way t. simple, it's gotta be something specific
    ...thanks again.
    Bronzeback likes this.
  29. Apr 8, 2020 at 6:08 AM
    Wallygator
    This stuff works great. Don't worry about trying to remove rust from the internal frame rails but wash out the rails real well with water. Allow to dry of course and then goto town with the internal frame coating. I used it on a 1989 FJ62 with great results. Then Fluid Film everything else on the out side of the frame/underbody. Then drive down a dusty dirt road and forget about it until you need to apply the Fluid Film again. I reapplied every other year and spot applied on the areas that would wash out from time to time.
  30. Apr 8, 2020 at 5:19 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    I was, sorta. They recommend minimum of 2000 psi, that's if you're using an airless paint sprayer. Doesn't say what to use for pneumatic spraying. 2 different paragraphs. That's what I get for skimming
