Fox TRD Pro or Fox 2.5 Resi system
Discussion in 'Suspension' started by 2019-1794, Jun 28, 2020.
  1. Jul 25, 2020 at 10:23 AM
    SM 2018 1794
    SM 2018 1794 New Member
    Cool you got them on
    Looks good. How do you like the feel of the truck? Kind of different but in a good way sitting nice and tall now.
    2019-1794[OP] likes this.
  2. Jul 25, 2020 at 10:26 AM
    SM 2018 1794
    Oh wow just noticed you got did get the TRD PRO rims and them powered coated?
    Looking good. What size tires you running and how much of a difference has it made in the ride quality and handling of the truck?
  3. Jul 25, 2020 at 11:14 AM
    2019-1794
    2019-1794 [OP] New Member
    2019 1794 Crew Max 4x4
    Yeah as far as the Pro suspension goes I couldn’t be any happier, I mean I figured they would ride better than stock but didn’t realize they would make as big of a difference as they did, so smooth... so glad I went that route.
    The wheels are actually Landcruiser Heritage edition wheels, they are essentially the BBS Pro wheels just in the bronze color....I was skeptical at first how they would look on my truck but think they fit it perfectly after seeing them on it. Tires are 285/75R18 Goodyear wrangler duratracs.... I also think the 18” wheels and tires with bigger sidewall contribute to the exception ride and handling on the road as well. Smooth is all is can say about the set up
    COTundra23, ryanwgregg and Tundra1078 like this.
  4. Jul 25, 2020 at 11:26 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This may seem slightly askew from the standard motivation, buuuuut I'm going to ask. I'm interested in the Fox TRD Pro system for it's potential ride quality improvements on our (local) trashed highway system and secondary roads. I can't claim to off-road this particular truck, but there are plethora gravel and Forest Service roads that are potentially traveled. I'm not necessarily interested in "leveling" or lifting the front of my truck; I don't "need/want" the "extra" ground clearance, but if it's part of the situation, so be it. All this leads up to my question of... is the lift that is the result of installing the Fox TRD Pro front system "built in", or is there a spacer of some nature that could be removed to maintain nearer to my current stock ride height. I've stared at some of the photos of the system, but it's still not clear to me. o_O
    Thanks. :thumbsup:
  5. Jul 25, 2020 at 11:33 AM
    2019-1794
    You wont be disappointed if you go that route, same exact reason I got them. The lift I guess is built in, there’s definitely no spacer involved to my knowledge. The lift height got me almost level which is perfect for my needs....I’d say 2” is all your gonna gain
    Wynnded likes this.
  6. Jul 25, 2020 at 11:42 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Copy. Did you have your alignment checked? I know that the additional cost compared to the system itself is minor, but it'd be nice to not have to deal with that aspect as I've had one recently enough. But again, it's what it is so the question is asked. Visually, my preference is the stock rake, but to each our own. :)
    Thanks for the feedback!
    2019-1794[QUOTED][OP] likes this.
  7. Jul 25, 2020 at 11:54 AM
    2019-1794
    Yeah the install included the front end alignment.... Aligned out great.
    Wynnded likes this.
  8. Jul 25, 2020 at 12:07 PM
    SM 2018 1794
    On the alignment the dealer I had my pro suspension installed at did do an alignment and they told me to drive it a few hundred miles to set the suspension and bring it back in for another free alignment check.
    Hey 2019-1794 did they set your fronts with the letter (L) and (R) facing forward with the notch as you look at the shocks from the side?
    Also did you ever install or remove the rear swaybar?
    Thanks
    Wynnded likes this.
  9. Jul 25, 2020 at 12:14 PM
    2019-1794
    I’ll have to double check on the front coil overs , I know they mounted them on the sides that they were supposed to be mounted on as far as left and right. I didn’t have a rear sway bar on mine.
  10. Jul 25, 2020 at 12:17 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    How did you get the LC Heritage BBS wheels? I heard they're exclusive for LC Heritage owners - meaning you need to own a LC Heritage to purchase them from the dealership.
  11. Jul 25, 2020 at 12:22 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What's the skinny on the speed sensor extender? I don't see how it would be needed...:monocle:
    Ordered system before I changed my mind! :spending::bananadead::goingcrazy:
    Edit: Gonna skip the speed sensor extender, I can get or make one if I find it applies to my application.
  12. Jul 25, 2020 at 1:13 PM
    SM 2018 1794
    The speed sensor bracket actually just extends the factory non Pro Sensor bracket up.
    I have the rear swaybar on my truck so I had to notch one leg of mine.
  13. Jul 25, 2020 at 1:14 PM
    SM 2018 1794
    Oh ya if you look at the first page of the posting you will see photos of the sensor bracket.
  14. Jul 25, 2020 at 2:24 PM
    2019-1794
    My local dealer had a set in stock not sure if someone had ordered them and didn’t end up buying or if they were takeoffs...
    Tundra1078 and Wynnded like this.
  15. Jul 25, 2020 at 3:00 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yep, I gathered that much, but for some reason I can't seem to recognize why this would be needed. I have the rear sway bar on my truck as well.
    I certainly took a gander at that, but I'm not picking up on how changing the rear shock absorbers changes the range of motion of the rear suspension, only the rate. I could see it if lift block were added or the springs were changed out for something with more arch, but...just the shocks?
  16. Jul 25, 2020 at 3:54 PM
    SM 2018 1794
    Ya I was thinking the same thing, but when I went to the dealership and looked at two brand new Pros both had the extension brackets.
    I just made mine the same as what’s factory. Also the dealership asked if I had the bracket as well.
    Wynnded likes this.
  17. Jul 25, 2020 at 3:57 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Fair enough. When I get and put mine on, I'll share what I find. Thanks.
  18. Jul 25, 2020 at 4:08 PM
    2019-1794
    Don’t forget to post pics!
    Wynnded[QUOTED] likes this.
  19. Jul 25, 2020 at 4:09 PM
    #49
    2019-1794
    I honestly don’t have any idea what that bracket is for. But I installed it.
    Wynnded likes this.
  20. Jul 26, 2020 at 6:12 PM
    #50
    2019-1794
    Couple more pics
    Watson, rv740, Tundra1078 and 3 others like this.
  21. Jul 26, 2020 at 7:29 PM
    #51
    SM 2018 1794
    Looking good really like the wheel and tire combo. Fills up those wheel wells now.
    That’s something I still need to do for mine. The Pro Suspension with the stock Michelin’s is leaving just a little to big of gap for me.
    Let me know how the truck handles and corners with the suspension, bigger tires and no rear bar.
  22. Jul 27, 2020 at 7:36 AM
    #52
    2019-1794
    Truck drives and handles way better than stock....I think the pro suspension with the lighter weight 18” pro wheels is the perfect combo, probably why they put it on the pros lol.... the larger sidewall tires with the 18” rims plays a big roll to in soaking up extra bumps.... I came from the 20” wheels and it’s night and day better with 18’s
  23. Jul 27, 2020 at 7:59 AM
    #53
    SM 2018 1794
    Nice thanks for the info. Yep I need to save up some more $$$ and get my PRO rims and bigger tires.
    Out here in bay area Ca the roads are just as bad as going off road half of the time. But yes I did feel a big difference myself as well.
  24. Jul 27, 2020 at 8:06 AM
    #54
    2019-1794
    You would think as heavily as y’all are taxed California would have the best roads in America.
    ericnvb likes this.
  25. Jul 27, 2020 at 8:56 AM
    #55
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    LOLLOLLOLOLLOLOL!!! That made my day. Not in California.
  26. Jul 27, 2020 at 10:46 AM
    #56
    SM 2018 1794
    Ya tell me about it. Especially our gas tax out here.
    I own a home in AZ as well and when ever I drive out there I wish I had a huge bladder bag in the bed of the truck on top of 38 gal gas tank in the truck. I could probably save few thousand a year just buying gas out of state.
    We get taxed on everything out here.
  27. Jul 28, 2020 at 5:16 AM
    #57
    2019-1794
    Well we’ll gladly welcome you in Texas, home of the Tundra.
  28. Jul 28, 2020 at 6:01 AM
    #58
    SM 2018 1794
    Why thank you.
    The girl friend thought I was nuts, last year I took her to Austin lake Travis, then told her I wanted to take a trip to San Antonio where we went to a Jay Leno show.
    However my whole plan was really to get her to Texas so we could take a tour of the Toyota 1794 Ranch and check out the factory. That was cool. She keeps saying that I just had to see where my only child (Tundra) was born.
    It was a fun trip. We even got engaged there in Texas.
    TundraLLama, RobertD, ericnvb and 2 others like this.
  29. Jul 28, 2020 at 8:37 AM
    #59
    2019-1794
    That's awesome man congrats on the engagement! The lakes and rivers in the hill country are incredible, We're headed to lake LBJ next weekend!
  30. Jul 28, 2020 at 9:29 AM
    #60
    SM 2018 1794
    Thank you.
    Yes the hill county was pretty cool around there.
    Have a great weekend at the lake, have fun with your new setup on the truck and take some cool pics.
