Found cause of p/s leak. Not good :(
Discussion in '1st Gen Tundras (2000-2006)' started by Shellback, Oct 21, 2018.
  1. Oct 21, 2018 at 7:58 PM
    Shellback
    Shellback [OP] New Member
    Pink/Silver 2001 Tundra TRD
    Peeling door window trim.
    Decided to start a new thread instead of thread jacking SouthWestGA's thread:
    https://www.tundras.com/threads/rack-and-pinion.33255/
    Week 2 of ownership and already finished 2 quarts of Dexron III. So finally got some time and crawled under and found the problem. The actual steering rack is rusted and leaking. Problem is where the rack and pinion is attached to the subframe. Same location where bushing clamp surrounds the rack.
    Mustie1 (awesome video!) Video screen shot:
    My 2001:
    What I need:
  2. Oct 21, 2018 at 7:59 PM
    Shellback
  3. Oct 21, 2018 at 8:01 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I like the hack stands :yes:
    DalTee, NewImprovedRon and Darkness like this.
  4. Oct 21, 2018 at 8:05 PM
    Shellback
    Junkyards always preaching: safety first!
  5. Oct 21, 2018 at 8:24 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's gonna be fun
  6. Oct 21, 2018 at 8:30 PM
    Shellback
    Not sure what approach I'm going to take. Replacing the entire subframe means cutting it out and welding in a new one to the ladder frame. But I'm also thinking on keeping the original subframe as it is and taking it to a body/frame shop and have them fabricate a bracket where the old one rotted. No matter what, this is going to suck.
  7. Oct 22, 2018 at 4:39 AM
    Professional Hand Model
    Hand Protectors
    My intial thought was like you said, to fabricated a new bracket. Thanks for the new thread and pics as they are helpfull for us others here. Glad you figured out the problem.
    Black Wolf likes this.
  8. Oct 22, 2018 at 4:51 AM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    That there is some funky rust. The picture of the Junk yard doner is hella clean compared to your ride. To bad the bracket was gone.
    GNTundra likes this.
  9. Oct 22, 2018 at 8:01 AM
    15whtrd
    15whtrd Mr. Blonde
    I say find a good donor in the junkyard and bring your grinder or sawzall. Cut the bracket off of the donor truck and bring the truck to a welding shop.
  10. Oct 22, 2018 at 3:20 PM
    Hand Protectors
    Crawled up mine today to check that post support. Its like it should be. These rust pictures get me paranoid a bit.
    NewImprovedRon, GNTundra and 15whtrd like this.
  11. Oct 22, 2018 at 7:25 PM
    Shellback
    I think the flash made the photos look really bad. Don't get me wrong - its ugly. But the rest of the truck is actually pretty good. At least the rust is getting lubed by Dexron III :rolleyes:
    The rack is also being held by the two other attachment points. But not planning on going wheelin any time soon until this is fixed.
    15whtrd likes this.
  12. Oct 25, 2018 at 7:29 PM
    Shellback
    Just a quick update. Toyota records show truck was inspected in 2010 for frame recall. No issues found. Re-inspected in 2012 and frame was replaced at dealer.
  13. Oct 25, 2018 at 7:50 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Wow
    15whtrd likes this.
  14. Oct 25, 2018 at 7:54 PM
    Casper421
    In the woods
    06 DC
    Glad there’s no rust in Cali.
  15. Oct 25, 2018 at 8:20 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    :fistbump:
    Sunnier and Casper421[QUOTED] like this.
  16. Oct 26, 2018 at 3:48 AM
    Hand Protectors
    Wonder if they will replace frame again? This is a first time hearing a replacement went bad.
    lsaami likes this.
  17. Oct 26, 2018 at 4:55 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Wow that’s nuts. So much for the replacement frames solving the rust issue...
  18. Oct 27, 2018 at 9:26 AM
    Shellback
    I called Corporate. Only one frame replacement during the recall campaign. You don't get a second frame :(
  19. Oct 27, 2018 at 1:00 PM
    Hand Protectors
    Wow! Thats terrible.
  20. Oct 28, 2018 at 5:31 PM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    Damn. So now what?
  21. Oct 28, 2018 at 5:39 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    I’m afraid for those stands
  22. Oct 28, 2018 at 5:41 PM
    DalTee
    DalTee New Member
    Dal
    That’s what they said
  23. Oct 28, 2018 at 8:05 PM
    Shellback
    I'm taking her to a shop and welding a new bracket on. I'm probably not going to bother cutting one off from a donor. Just have the shop fabricate a replacement as close as possible to factory.
  24. Oct 29, 2018 at 1:54 PM
    15whtrd
    15whtrd Mr. Blonde
    I’d like to see the work when they are finished if you could.
  25. Jan 7, 2019 at 12:53 PM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    @Shellback , how did it turn out?
