Rack and Pinion
Discussion in '1st Gen Tundras (2000-2006)' started by SouthWestGA, Oct 19, 2018.
  1. Oct 19, 2018 at 8:50 AM
    SouthWestGA
    SouthWestGA [OP] New Member
    So the shop tells me I have a leaking rack and pinion
    What is the consensus on replacement racks? I’m seeing OEM $650-$800, and Detroit Axle New $255, Refurb DA $225
  2. Oct 19, 2018 at 9:42 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  3. Oct 19, 2018 at 10:02 AM
    TTCrewmax
    TTCrewmax New Member
    I haven't had to replace the one on my truck - but bought a refurb unit off of ebay for my Camry. It's been in for a few years with zero complaints. Good luck.
  4. Oct 19, 2018 at 10:40 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    check RockAuto. they have reman units at like $350, and aftermarket units starting at like $230.
  5. Oct 19, 2018 at 10:52 AM
    SouthWestGA
    I am checking around
    Just gathering knowledge and first hand experience
    I know some people only say OEM and you hear horror stories about junk racks
  6. Oct 19, 2018 at 10:58 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
  7. Oct 19, 2018 at 11:10 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  8. Oct 19, 2018 at 11:54 AM
    SouthWestGA
    I read that thread,and visited rack doctors website
    Their part number for my truck,and my in laws mini van is the exact same part number Detroit Axle uses
    Coincidence? LOL
  9. Oct 19, 2018 at 12:17 PM
    csuviper
    Broomfield, CO
    No clue there. Rack Dr was recommended to me by a Toyota tech. Have not had any issues since i had it installed.
  10. Oct 19, 2018 at 3:17 PM
    Professional Hand Model
    Hand Protectors
    The way I look a most things when it comes time to repair be it trucks, homes, body parts etc. is to consider the overall lowest cost.
    In this case of your rack, the labor to remove and replace is the same. The premium is the extra cost for the part. I will always install OEM unless its some smaller repair where if a part goes bad it can be swapped out easily without being out of service for a few days.
    Here are two prices for a 2006 from this website. Go there and pick your vehicle type and narrow it down.
    An extra $250 is cheap peace of mind.
  11. Oct 19, 2018 at 3:31 PM
    SouthWestGA
    I just spent $2k worth of parts and repair done on my truck in the last 3 months and there’s More to go.
    $800 for an OEM rack plus labor isn’t reasonable right now,and with work and two babies I’m not tearing it apart myself
  12. Oct 19, 2018 at 3:38 PM
    Hand Protectors
    Yours is the $800 dollar one? Figures. You can still buy the part from this site and have the mechanic do the install.
    I’m looking at the OEM rear muffler for the 02’ which is around $550 versus $130 for a Walker. Guys here say good things about the Walker, but I’ve been leery of all after market mufflers I’ve ever had in the past on other vehicles. They don’t seem to last.
    The 02’ is still on its original, buts its time is coming. Question is do I pay $420 extra for it? I’ll be doing the install.
    Let us know how it goes!
  13. Oct 20, 2018 at 11:42 PM
    Shellback
    Shellback New Member
    Pink/Silver 2001 Tundra TRD
    Peeling door window trim.
    Can someone please chime in, what is the name of the part or crossmember where the steering rack attaches to. Is this part of the frame (welded to the ladder frame) or is it attached to the frame with bolts - that is, can it be replaced?
    Thanks.
  14. Oct 21, 2018 at 6:13 AM
    Hand Protectors
    Hope this helps.
  15. Oct 21, 2018 at 7:48 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    It’s called the rear cross member assembly. Check out rock auto,summit racing,jeggs, or your local auto parts store for a rebuilt model
  16. Oct 21, 2018 at 9:34 AM
    Shellback
    Thank you Hand Model for the images. I'm going to raise the truck on a lift and compare the images. It's really hard to tell when you are on your back and only get a limited field of view. I think its also the same part of the frame that holds the lower control arms.
    MH, thanks for the vendor info. Going to check.
  17. Oct 21, 2018 at 4:59 PM
    Shellback
    I forgot to ask if it was ok to piggy back on this thread...:oops:
  18. Oct 22, 2018 at 10:47 AM
    SouthWestGA
    Sure i don’t mind
    After all it’s a resource and info community right!
  19. Oct 22, 2018 at 11:20 AM
    Shellback
  20. Oct 25, 2018 at 8:54 AM
    SouthWestGA
    I made a decision
    Today i bought a Detroit Axle rebuilt rack off EBay
    $226.45
    Minus 10 percent off coupon today,plus a $25 core charge credit (with free return shipping)
    It should cost around $175 after rebates and coupon applied
    It does come with a new Bushing kit,but I ordered Energy Suspension Bushing kit for $27 Off eBay as well just in case.
    Still,it’s about 1/2 the price of Rack Doctor,which would be a refurb unit as well plus Rack Doctor makes you pay for your own return shipping
    I will update when it arrives and also when it’s installed
  21. Oct 25, 2018 at 8:59 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    If only someone had made a thread about this issue....
  22. Oct 25, 2018 at 9:03 AM
    SouthWestGA
    What exactly does that mean
  23. Oct 25, 2018 at 9:37 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
  24. Oct 25, 2018 at 9:38 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    fair enough that was a vague reference to another forum, ill make a new one here
  25. Oct 25, 2018 at 9:42 AM
    SouthWestGA
    Thank you
    That is very informative
    I have an 06 First Gen Double Cab,so hopefully it’s just bad from hitting a deer
  26. Oct 25, 2018 at 9:58 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
  27. Oct 25, 2018 at 11:02 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Not to be a jerk but a lot of that doesn't apply to the 1st gen trucks, great if you have an 07-up though.
    1st gen part #'s are
    01-06 with rear sway
    44250-0C020 original
    44250-0C050 1st revision
    44250-0C041 2nd revision
    03-06 without rear sway
    44250-0C030
    00-02
    44250-0C010
    The rack replacement is also a lot less time intensive since the rack is easily accessible since it's on the back of the crossmember.
  28. Oct 25, 2018 at 11:05 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    didnt even notice it was a 1st gen, sorry for the confusion.
  29. Nov 3, 2018 at 4:45 PM
    Tundrat78
    Tundrat78 New Member
    Erik
    2000 tundra sr5
    Wheels and tires 1.25" wheel spacers
    I put a detroit axle rack in my truck 3 years ago and no leaks super high quality part would recommend to anyone for sure!!
  30. Apr 19, 2022 at 9:38 AM
    txlonghorn85
    txlonghorn85 New Member
    2004 Tundra SR5 AC
    Bringing this back from the dead....
    Does anyone understand the difference between the racks w/ and w/o rear sway option (44250-0C030 vs 44250-0C041)? There is a significant price difference.
    Thank you.
