First Tundra DIY oil change, lessons learned
Discussion in '2.5 Gen Tundras (2014-2021)' started by CallsignKodiak, Sep 2, 2023.
  1. Jan 23, 2024 at 8:26 AM
    #91
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Yes, exactly.....there are actually illustrations on the OEM filter boxes (ask me how i know.....hahaha).
  2. Jan 23, 2024 at 8:45 AM
    #92
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Okay how do you know????
  3. Jan 23, 2024 at 8:55 AM
    #93
    shawn474
    MoCo, Maryland
    Well lets just say my first attempt at this did not go as planned......I THOUGHT I knew where the o-ring went. Apparently i put it in the wrong groove or it migrated while I was screwing in the filter housing. Started my truck and backed out of the garage leaving a spray of oil all over the garage floor, driveway and bottom of my truck. Took me days to degrease the floor of the garage and driveway and a good hour to clean up the bottom of the truck. I hope to never make that mistake again.
    After posting about my tribulations, a polite forum member informed me that the proper placement of the o-ring was and sure enough it was there when I looked. Might have saved me a lot of time, effort and money
    OHwendTrd, agrestic1 and Damie Street like this.
  4. Jan 23, 2024 at 8:59 AM
    #94
    joe_from_iowa
    joe_from_iowa New Member
    Iowa
    2021 Tundra Double Cab SX
    Peeled off the SX stickers from the bed sides. Tyger running boards. A.R.E. DCU topper
    For whatever reason.. when I remove the plug on the filter housing to drain the filter, there is oil between the plug and the filter drain valve. The dealership did the first 2 oil changes and I've done every one since and it's been that way every time.
  5. Jan 23, 2024 at 10:31 AM
    #95
    Bobscrewmax
    Bobscrewmax New Member
    Bob
    Black Crewmax
    N/A
    So one thing I’ve always wondered, if you pull your vehicle up on ramps does the oil pan drain completely while on the ramps?
  6. Jan 23, 2024 at 11:09 AM
    #96
    AZBoatHauler
    So.Arizona
    There is a nut welded inside the pan for the bolt so the pan never completely drains.
  7. Jan 23, 2024 at 11:42 AM
    #97
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Now you know ! Thanks to the "polite forum member " !
  8. Jan 23, 2024 at 12:24 PM
    #98
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    I cut a trap door on my skid plate so I don't have to pull my skid plate, and, yes Fumoto valve and screw in funnel keeps it cleaner, but still spill oil pulling my oil filter
    WILLINH and Randyundra like this.
  9. Jan 23, 2024 at 12:26 PM
    #99
    joe_from_iowa
    Iowa
    I'm ready to cut the trap door in my skid plate too. Did you make a hinged door for it or just leave the hole open?
  10. Jan 23, 2024 at 12:41 PM
    #100
    shawn474
    MoCo, Maryland
    i purchased the rci skid plate with cat protectors and it has an access door secured by two button head bolts. Makes it very easy especially with the fumoto valve to drain.
    Tyman likes this.
  11. Jan 23, 2024 at 12:43 PM
    #101
    shawn474
    MoCo, Maryland
    yes shout out to @TundraMcGov.
    I am stubborn and don’t necessarily read directions all the time…..just ask my wife. I will say that as my eyes have gotten worse, the box directions are pretty hard to see without my magnifiers!!!!!
  12. Jan 23, 2024 at 1:49 PM
    #102
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    I made a trap door with hinges and a thumb screw
  13. Jan 24, 2024 at 12:27 PM
    #103
    Bobscrewmax
    Bob
    Black Crewmax
    N/A
    I’ve never jacked the truck up or used ramps when I change my oil, but it has crossed my mind. Seems that it would be easier. May sound like a silly question but, does all of the oil drain from the pan with the front end elevated?
  14. Jan 24, 2024 at 12:48 PM
    #104
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    not all of it, there will always be a small amount of old oil left no matter what. but raising the front will direct the oil to the back of the oil pan where the drain is located
  15. Jan 24, 2024 at 12:57 PM
    #105
    Bobscrewmax
    Bob
    Black Crewmax
    N/A
    I agree with the little bit of residual oil left over. So lifting the front end doesn’t leave enough residual oil to matter then I assume?
  16. Jan 24, 2024 at 1:19 PM
    #106
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    And using ramps allows you to fit a 5 gal bucket under there so you're not trying to aim your drain stream toward a pan on the ground (and the associated splash of oil onto the inside of the passenger tire/wheel/brake/etc).
  17. Jan 24, 2024 at 1:26 PM
    #107
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    You are correct, not enough to worry about
  18. Jan 24, 2024 at 1:30 PM
    #108
    Bobscrewmax
    Bob
    Black Crewmax
    N/A
    What ramps do you recommend that are strong enough to safely drive up on and support the weight please?
  19. Jan 25, 2024 at 6:15 AM
    #109
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
  20. Jan 25, 2024 at 6:33 AM
    #110
    Bobscrewmax
    Bob
    Black Crewmax
    N/A
    Thanks so much for the info. Just made my oil changes much easier. Bless all who chimed in. :)
  21. Jan 26, 2024 at 12:32 PM
    #111
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I've got a question.
    Last time I changed the oil, I installed a fumoto valve. This will be my first time changing it with the valve installed. What size tubing are you all using to attach to the valve?
  22. Jan 26, 2024 at 1:08 PM
    #112
    Damie Street
    Edsel
    South Carolina
    Does anyone have the link to the aluminum filter housing?
  23. Jan 26, 2024 at 1:19 PM
    #113
    AZBoatHauler
    So.Arizona
    Pretty sure it’s 3/8”
    Jaypown[QUOTED], TILLY and Ebrperk like this.
  24. Jan 26, 2024 at 1:19 PM
    #114
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    Damie Street[QUOTED] likes this.
  25. Jan 26, 2024 at 1:33 PM
    #115
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    As stated above, 3/8 ID is correct.
    Jaypown[QUOTED] likes this.
  26. Jan 26, 2024 at 3:14 PM
    #116
    agrestic1
    2016 CrewMax
  27. Jan 27, 2024 at 4:03 AM
    #117
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
  28. Jan 27, 2024 at 4:12 AM
    #118
    shawn474
    MoCo, Maryland
  29. Jan 27, 2024 at 3:21 PM
    #119
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    Not very fancy, but they were cheap, and very strong
  30. Jan 27, 2024 at 3:34 PM
    #120
    Bergy24
    Bergy24 New Member
    They look like they work well. Do you happen to know the lengths you used? I plan to make something similar and just looking for ideas.
    Thanks
