First time self oil change. Tips/advice?
Discussion in '2nd Gen Tundras (2007-2013)' started by 2Good4You, Oct 17, 2019.
  1. Oct 22, 2019 at 8:15 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I buy the case of assorted copper crush washers from Harbor Freight. Swap them out as needed. Haven't bought OE crush washers in awhile. No problems to report.
  2. Oct 22, 2019 at 8:26 AM
  3. Oct 22, 2019 at 8:43 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Well, when you do have a problem to report...it's going to be a BIG one. :rolleyes:
    Jrharvey02 and Zebruaj[QUOTED] like this.
  4. Oct 22, 2019 at 11:11 AM
    MRM937
    MRM937 New Member
    2007 limited 5.7L
    Why would you not use the 3/8 square to loosen the filter housing? I do that every time because I never had luck using the wrench on the plastic housing. (too slippery) The 3/8 square does not back out the smaller aluminum plug but drops the entire cap for me.
  5. Oct 22, 2019 at 11:19 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    It has been known to crack using that inferior method. The 3/8 square should back out the smaller aluminum plug, so you can drain the filter housing before removing. It does work your way, just messier...
  6. Oct 22, 2019 at 11:26 AM
    MRM937
    MRM937 New Member
    2007 limited 5.7L
    Yes it is messy, I wish there was a Fumoto valve available for the bottom of the filter cap to make draining that easier.
  7. Oct 22, 2019 at 11:30 AM
    Jrharvey02
    There is a small, plastic drain that comes with every filter you buy that is meant to drain that...72340BE8-8FBE-42C8-90E3-35A82DB0C6C1.jpg
    omgboost likes this.
  8. Oct 22, 2019 at 11:33 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Yep. Shove a piece of hose into it too to direct the flow and its even less messier.
    Jrharvey02[QUOTED] likes this.
  9. Oct 22, 2019 at 11:39 AM
    MRM937
    MRM937 New Member
    2007 limited 5.7L
    I understand, my issue is when I turn the 3/8" square to remove the plug that the plastic drain piece is supposed to snap into the whole cap comes off. I am going to upgrade to the aluminum filter cap so maybe that will help.
  10. Oct 24, 2019 at 6:56 AM
    Apollothetundra
    Apollothetundra New Member
    Trevor
    07 Super White 5.7l V8 337,000
    It is definitely worth upgrading to the aluminum one. When I got my truck mine was all stripped out couldn't even turn the filter socket on it. Now comes off no probelm . Also like TXrails said swap out inside tube .
  11. Oct 24, 2019 at 7:56 AM
    ACguyx3
    ACguyx3 New Member
    2013 Black Tundra SR5
    Trd rims 20x9
    Yes I got fumoto valve, Toyota filter housing, removal tool , and and hose and screw in tool to empty oil in housing housing, takes 15 min to change, longest part for me is taking off skid plate lol.
  12. Oct 24, 2019 at 7:59 AM
    ACguyx3
    ACguyx3 New Member
    Trd rims 20x9
    I got a kit like this to stop the oil mess when taking off filter
  13. Oct 24, 2019 at 9:29 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Damn some of you guys get fancy. The first time I pulled the housing then just cranked the drain plug for the filter into the housing. Now I can just turn the drain plug with a normal wrench and the whole housing unscrews easily. Saves time and it's not that messy if you just hold a drain pan under the housing as you unscrew it. Makes the whole process as fast and simple as a normal filter.
  14. Oct 24, 2019 at 9:45 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I can second using a socket and not the 3/8" drive. That is the one I broke after the goons at Toyota of Rockwall over tightened mine 6x+. The filter drain hose helps but it is still messy.
    ACguyx3 likes this.
  15. Oct 24, 2019 at 11:11 AM
    Apollothetundra
    Trevor
    Yes I do the same just unscrew the who thing a little messy but I just wipe the whole filter holder up and put a new filter on it and boom .
    snivilous[QUOTED] likes this.
  16. Oct 26, 2019 at 2:35 PM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    Pay close attention to the location of the o-ring on the oil filter cap.
    It fits into a groove on the cap and not at the bottom like most o-rings/gaskets do.
    I found this out the hard way on my first oil change.
  17. Nov 19, 2020 at 12:04 PM
    bigo_m
    bigo_m New Member
    2012 Pyrite Mica SR5 Crewmax
    It's been a year and just like Jrharvey02 & JohnLakeman said, The metal housing does fit the Tundra. Just make sure to replace the shorter center tube with the longer center tube on your plastic housing.
  18. Nov 19, 2020 at 6:33 PM
    Black4X2
    Black4X2 New Member
    Bill
    2007 Black Tundra Limited 4X2
    First time prepare for a mess. Second time still a mess but not as bad. Third time much better than before . Fourth time finally learned how to do it without making such a mess.
