First time self oil change. Tips/advice?
Discussion in '2nd Gen Tundras (2007-2013)' started by 2Good4You, Oct 17, 2019.
  1. Oct 17, 2019 at 5:09 AM
    2Good4You
    2Good4You [OP] New Member
    Theron
    2010 Tundra 5.7
    I’ve been watching YouTube videos on how to change the oil on my 2010 Tundra. Doesn’t look too complicated. Are there any tools, tips, or tricks you guys Recommend?? Is taking that plate off a pain in the @ss?!? Thanks
    cpc0812 likes this.
  2. Oct 17, 2019 at 5:35 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Just a few extra minutes over an old school oil change, but nothing complicated. On a scale of 1-5, It's a 1 unless you have never done an oil change before.
    MyFj08 likes this.
  3. Oct 17, 2019 at 5:53 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The hardest part is having to buy the oil filter tool and wait for it to arrive
    Bob, MyFj08 and 15whtrd like this.
  4. Oct 17, 2019 at 6:07 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Taking off the skid is nothing more than 6 12mm bolts. You have to slide the skid a few inches to one side, once unbolted, for it to drop. You will need this oil filter removal tool to get the oil filter housing off. Don’t use the 3/8” square to turn it, use a 22mm socket...
    ABN 6-8 Cylinder Oil Filter Wrench for 2.5L to 5.7L Engines - 64mm Cartridge Style -fit for Camry, RAV4, Highlander, Sienna, Tundra, Toyota, Lexus https://www.amazon.com/dp/B00L84EKI0/ref=cm_sw_r_cp_apip_v3p9rGMC6FNQw
    MyFj08, Toyotoholic, omgboost and 2 others like this.
  5. Oct 17, 2019 at 6:11 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    A search using "oil filter housing" yields most of the valuable information (plus some of questionable value). That link is shown below. Read what you need, ask if you have any questions. Ignore any threads obviously on peripheral subjects like steering rack removal, which is only listed because the oil filter housing has to be removed to get the rack out:
    https://www.tundras.com/search/2196133/?q=oil+filter+housing&t=post&o=date
    2Good4You[QUOTED][OP] likes this.
  6. Oct 17, 2019 at 6:40 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Thanks for the heads up. I'm still a ways out on my 1st change but will go ahead and grab this along with a couple of filters to get the free shipping
    Jrharvey02[QUOTED] likes this.
  7. Oct 17, 2019 at 6:45 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    The cartridge filter kits come with a plastic bleed nipple for the oil canister. Shove a piece of hose into before you use it to direct the drainage otherwise have some rags around. Also make sure you know where the 2 gaskets go.
    Don't go ham on the plastic canister. They can crack. Upgrade to the aluminum can if you need to. There's a OEM and a Dorman version.
    JLS in WA, MyFj08 and Jrharvey02 like this.
  8. Oct 17, 2019 at 6:47 AM
    Jrharvey02
    2Good4You[OP] and 7.62Tundra like this.
  9. Oct 17, 2019 at 3:15 PM
    Jrharvey02
    One more thing you’ll need to buy, the oil plug o-ring...if I had a link I’d give it to ya, but I unfortunately went with an Amazon buy, and they suck. They deteriorate over 5k and cause my drain plug to be torqued back down. Go with OEM from a dealer, you can get a pack of many that’ll last years...
  10. Oct 17, 2019 at 4:12 PM
    JohnLakeman
    Some Toyota filters may not have the o-rings, but these do:
    https://www.amazon.com/Set-Toyota-0...1571353732&sprefix=04152-YZZA4,aps,187&sr=8-6
    Not an o-ring, but these are what you need for the oil drain plug:
    https://www.amazon.com/Genuine-Toyo...6Q8GY1TR2WP&psc=1&refRID=SYY75YQXB6Q8GY1TR2WP
  11. Oct 17, 2019 at 4:14 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    The best tip you could get is to properly torque the filter housing and the drain cover when you reinstall them. Replace the drain plug gasket as @JohnLakeman mentions above.
    Really simple job. I actually prefer it to the old filters as it's really easy to keep everything perfectly clean.
    JLS in WA likes this.
  12. Oct 17, 2019 at 5:10 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    70m4h4wk likes this.
  13. Oct 17, 2019 at 7:02 PM
    Jrharvey02
    I would personally avoid those from Amazon, that’s what I got. They’re junk. Maybe they work for others, not me.
  14. Oct 17, 2019 at 7:06 PM
    JohnLakeman
    Those are Toyota filters, exactly the same as the ones you get from the dealer. How did they not work for you?
  15. Oct 17, 2019 at 7:34 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I ordered 10 filters from mcgeorge Toyota for around $3.65 each. Along with the oil drain plug gasket. The oil filters come with the 2 rubber gaskets and the plastic drain piece for the oil filter. I had to get a dorman oil filter housing since the previous owner or oil change, it was missing the middle piece on the oil filter housing.
  16. Oct 17, 2019 at 7:44 PM
    Jrharvey02
    2 oils changes with them and each time, the oil drain plug is slightly loose and the gasket is essentially disintegrated, there’s very little of anything left, causing the slightly lose plug. Thought the first was a fluke.
  17. Oct 17, 2019 at 8:22 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    First change on a 2015? If you recently bought the truck change it right away unless you have a receipt proving the last time it was done
  18. Oct 17, 2019 at 8:25 PM
    JohnLakeman
    There is more than one listing of two Toyota filter packages on Amazon. Some of the case quantity (10) listings are being sold by Toyota dealers. Can you go into your orders and find the listing you bought from? This is important for the rest of us to avoid boot-leg filters. I am assuming the filters you bought came in the red/white Toyota boxes?
  19. Oct 18, 2019 at 4:41 AM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Dealer certified. They changed it before I bought it
  20. Oct 18, 2019 at 4:56 AM
    Jrharvey02
    Yes, filters are genuine w/ Toyota box. I’ve tried finding where I bought there drain plug washers and can’t... otherwise I would alert others...I completely agree that I think I got knock-offs, but must have ordered from a site other than Amazon or eBay.
    JohnLakeman[QUOTED] likes this.
  21. Oct 18, 2019 at 5:00 AM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    I would get a Fumoto oil drain valve F103N and never have to worry about having to get an oil drain plug gasket each time. Makes changing your oil much cleaner as well.
    Fumoto F103N with LC-10 Lever Clip FN-Series Engine Oil Drain Valve https://www.amazon.com/dp/B07D9DXCHP/ref=cm_sw_r_cp_apap_YQeWzEDzfq5CY
    I also bought a 10-pack of oil filters off Amazon from DaytonaToyota.
    Get the Motivx filter wrench and drain tool as well. They are well built and should last a lifetime. They are having a sale on them right now.
    https://www.motivxtools.com/collect...mx2341-drain-tool-bundle?variant=895099699225
  22. Oct 18, 2019 at 5:24 AM
    JohnLakeman
    I believe all genuine Toyota 04152-YZZA4 filters will have a small diameter (1/2"?) reflective sticker on the top of the box. I can't think of any reason for that sticker unless Toyota IS having some problems with knock-off filters being sold, and it's a way of discovering knock-offs (like the stripe in $100 bills). Of course, the sticker could also be faked, but that is another step pirates have to discover and duplicate.
    Buy Toyota filters that have the o-rings and plastic drain gizmo in them. Buying from a Toyota dealer on Amazon would be preferable (less $), but most of the Amazon outlets are also selling genuine Toyota filters for less. Buying o-rings from a separate source will cost you more, and can lead to all kinds of problems. O-rings used in oil systems have to be hydrocarbon resistant (Viton or Buna-N). Materials that are not compatible with hydrocarbons, or of poor quality may have the problem you experienced.
    JLS in WA and Jrharvey02[QUOTED] like this.
  23. Oct 18, 2019 at 11:22 AM
    Jrharvey02
    So, I just went to the dealership to pick up genuine oil drain gaskets. They are totally different than the ones I have been using, which are eerily similar to those you posted. The dealership gaskets are black and have a much thinner, more rubbery coating on the washer, whereas my counterfeit(?) ones were blue, with a much thicker, drier type of gasket feeling to it. I installed the new one today and I’m glad I did. With less than 300 miles on my fake gasket, this is what it looks like...the outside rubber is nearly gone while the inside, which was against the oil pan, was melting away. I read a few of the reviews on Amazon for those and other guys have experienced what I did. Here’s some pics of the blue ones (Less than 300 miles since oil change)...9850944B-2DDD-40E3-A441-235D6F17DC41.jpg23F991C6-08A2-48DA-9E44-0476EA096AC0.jpg And here’s a pic of the gaskets I picked up from the dealer...6771B06F-E702-48A2-893D-A57DFAD018ED.jpgAfter install, I feel so much more confident about this one. It looks different when installed, my fake gasket could barely be seen once torqued to 30ft/lbs and this new gasket is super apparent it’s there and doing its job correctly. That’s all I have to say about a $1 part, lol.
  24. Oct 18, 2019 at 2:09 PM
    JohnLakeman
    Interesting. The drain plug gasket listing in my first post is what I purchased, and those are apparently the real deal, Toyota part number and packaging. All the Toyota drain plug gaskets I've used for 30 years have had a dry, papery gasket material (as you describe, not rubbery) on both sides of an aluminum washer. Sometimes they are called "crush washers", but they are stamped from sheet aluminum...they DO NOT crush. In a pinch, they can be reused. The color used to be black, now appears they are blue. Your description of a rubbery coating is different from my experience. Something wanky is afoot. I think you bought some ringers...raise hell with Amazon to protect the buying public.
    Jrharvey02 likes this.
  25. Oct 19, 2019 at 11:09 AM
    bigo_m
    bigo_m New Member
    2012 Pyrite Mica SR5 Crewmax
  26. Oct 19, 2019 at 11:11 AM
    Jrharvey02
    Yes, I do. The 5.7 is the same 2007-Current
    Scroll thru some reviews and questions on the Amazon link and you’ll find plenty of Tundras with it...
    bigo_m[QUOTED] likes this.
  27. Oct 19, 2019 at 11:22 AM
    bigo_m
    bigo_m New Member
    Thanks!
  28. Oct 19, 2019 at 11:59 AM
    JohnLakeman
    It is a Toyota filter housing that was used on other engines, like the Venza, instead of the plastic housing. Toyota won't tell you it will fit, because you have to exchange the original center tube in your plastic housing for the short one in the aluminum housing. You have to do this because using the longer Tundra filter with the short center tube will cause the top of your long filter to collapse, possibly leading to filter media debris in your engine. It has happened. Not a good thing.
    bigo_m[QUOTED] and Jrharvey02 like this.
  29. Oct 22, 2019 at 8:03 AM
    Black4X2
    Black4X2 New Member
    Bill
    2007 Black Tundra Limited 4X2
    My first two oil changes made a mess. That 0-20W oil comes gushing out. I was using the same drain pan I had always used on my other vehicles. I finally took a 5 gallon bucket and cut it down so it would just fit up under the oil pan. Now I don't have a mess any more.
  30. Oct 22, 2019 at 8:11 AM
    Jrharvey02
    I do the same, but fill the bucket w/ a 13gal. trash bag. I can then hang the bag-full-o-oil on my tree, poke a hole in the bottom and drain back into something for disposal. Very little mess.
    db52282 and Black4X2[QUOTED] like this.
