First Gen Brake Bleeding Advice?
Discussion in '1st Gen Tundras (2000-2006)' started by baltimorebirds2, Mar 8, 2021.
  1. May 9, 2025 at 8:04 AM
    His brake theory is correct. The FSM describes how to achieve what he is talking about. His description will likely also work as it’s pretty close. If the rears are not adjusted properly, the fronts are doing more work than they should and you get exactly what he describes. Warping rotors and mushy pedal.
    bmf4069 and PNW15 like this.
  2. May 9, 2025 at 8:31 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Fuck those rear drums.
    KNABORES[QUOTED] likes this.
  3. May 10, 2025 at 7:39 AM
    StrawberryBlowpopPrincess
    StrawberryBlowpopPrincess New Member
    2002 sequoia RWD
    Im about to bleed my brake system as well and thought I’d ask my question here.
    When doing the brake flush, my car needs to be turned completely off, keys out of the ignition correct? (Im pretty sure the answer is yes, but better safe than sorry)
  4. May 10, 2025 at 8:31 AM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    Not entirely, after bleeding system. if you have abs, switch key to acc. Let the abs pump cycle, push pedal then rebleed system. Or whatever the fsm describes for your vehicle. Often this is not needed for our vintage of vehicle, but check to be certain.
