FINALLY! 2018 Cement Tundra Upgrade!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Silv333, Jan 5, 2019.
  1. May 4, 2019 at 9:03 AM
    2chains
    2chains New Member
    Southern Ablerta
    Looking great! Did you decide to do the from bumper? Did you go with black or cement?
  2. May 6, 2019 at 8:51 PM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    Lookin good! Can you please post a side shot on level ground? I’d like to see how level it is with the shackles. Debating getting them with same suspension.
  3. May 6, 2019 at 10:20 PM
    Silv333
    Silv333 [OP] Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    I will try tomorrow
    Travo60[QUOTED] likes this.
  4. May 8, 2019 at 12:00 PM
    KeetAz
    KeetAz New Member
    Gilbert AZ
    2020 SuperWhite PRO
    How’s the ride on the 2.5 setting? I’m really struggling to decide on 1.9 or 2.5. I think the stance came out really awesome on your truck.
  5. May 8, 2019 at 3:01 PM
    _bm27
    _bm27 New Member
    Los Angeles
    21 Tundra aka Tank
    @Silv333
    I also had to do the BMC recently due to rubbing about 3/4's lock, and especially in reverse. I drove it like this for about 1.5 weeks until I could get it in to the shop and noticed on the very outside where rubbing was scuffing up the tires so yes it will do some damage to the tires if you continue.
    BMC is cut up to the body mount itself but doesn't alter or harm it at all, and new plate is welded on then painted. I don't see this causing any issues w/ the body mount itself. Attached is a couple pictures for reference ..
    Cost: $200
    Front Liner -
    Mine also rubbed a decent amount so I simply unbolted what's holding them to chrome corner pieces then pushed the liner to inner portion of chrome corners and put a screw through to hold and no rubbing issues since .. Here's a couple pictures to give you an idea
    This is how it looks in original positioning
    Here is w/ the liner pushed to inside
    Wheels/Tires -
    A + offset will bring face in, and - offset will bring face out, also look at the back spacing (might not be correct technical term) which will tell you distance from hub to inner portion of wheel. These will all have a role in how much poke you get.
    I have 17x8.5 0 Offset on a true 34 305/70/17 and has what I think is the right about of tire poke... In which from the pics I don't think your's looks bad and actually is right amount of poke / meat. Just my opinion though
    Hope this helps
    4RunnerKid likes this.
  6. May 10, 2019 at 12:26 PM
    Novajess1972
    Novajess1972 New Member
    Jesse
    2019 MGM TSS OFF ROAD
    Ready Lift 4in/20x10 Fuel Triton/35x12.50 BFG KM3
    Looks good my man. Great wheel/tire setup on that cement.
    Silv333[OP] likes this.
