Fiberglass Fender and Bedside Install
Discussion in '2.5 Gen Tundras (2014-2021)' started by tundra_kc, Jul 18, 2018.
  1. Mar 31, 2019 at 8:56 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Looks like you didn't unbolt the bed? Interesting to see the pics, I'll be doing this very soon so thanks. I notice you cut a lot more than Bruce did.
    Looks like you're using either McNeil or Fiberwerx. Looking good.
    papasmurf likes this.
  2. Mar 31, 2019 at 9:04 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    Wow you cut a lot... why?
    831Tun likes this.
  3. Mar 31, 2019 at 10:27 PM
    TXTundra2722
    2015 Black Tundra
    Which brand of glass did you go with and did it come with instructions for the rear? I also thought you leave more material, especially around the tail lights. Very interested in this and hope that you keep us updated. Looks good
  4. Mar 31, 2019 at 10:48 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    I didn’t move the bed at all. That’s how I started, the way Bruce did his. The glass didn’t fit at all and I got tired of trimming so I went all out lol. Actually, I got that advice from other folks that did their own. Both front and rear glass are Advanced.
    Lol :sawzall: I went angle grinder happy :yay:
    Advanced :thumbsup: Only instructions it came with was Chop Chop Chop.. lol Unfortunately, no instructions..:( Yes I kinda over chopped the rear section lol . Now I’m stuck with this, will need to make my own brackets for the top and bottom part..
    smslavin and 831Tun[QUOTED] like this.
  5. Mar 31, 2019 at 11:19 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks a lot, really helpful info and pics. I'm dreading doing this. I mean what's scarier than taking a grinder with a cutoff wheel to your 40k+ truck?
    joonbug, vq35721[QUOTED] and smslavin like this.
  6. Apr 1, 2019 at 6:28 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    So something I realized recently is that gluing the bedsides could suck if you ever have to replace the entire bedside for some reason. Mine are bolted on so replacing is super easy.
    vq35721 and 831Tun like this.
  7. Apr 1, 2019 at 6:58 AM
    roypark
    roypark Semi-pro High Fiver
    Roy
    Orange County
    2016 Tundra
    A little of this and a little of that. Its pretty run of the mill.
    Give us an example of why you might need to replace the bedside? Mine are bolted as well.
    831Tun and osidepunker[QUOTED] like this.
  8. Apr 1, 2019 at 7:07 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Lets say, just as an example, that you flop your truck on its side and you have extensive fiberglass damage. Its much cheaper to replace it then to fix it. ADV sells a single bedside for around $300
    Now, imagine trying to remove a bedside that was glued on...
  9. Apr 1, 2019 at 7:10 AM
    roypark
    Roy
    Orange County
    2016 Tundra
    Valid point. How’s the repairs coming along?
  10. Apr 1, 2019 at 7:15 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I'll know later today, should be done soon
  11. Apr 6, 2019 at 5:17 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Never again lol She turned out clean though. Now I need 37s :(2A0A0C0C-BC2C-4B5A-98E4-CA9272B7ED63.jpg1EE92CFA-5094-472D-8108-35B7F7AF49AB.jpg
  12. Jan 28, 2020 at 9:18 PM
    astrotx_
    astrotx_ New Member
    Jonathan
    2019 Black Tundra SR5 4x4
    Already did the front need help some info with rear
    Pinay likes this.
  13. Jan 29, 2020 at 8:45 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  14. Sep 15, 2021 at 2:53 PM
    pandapro
    pandapro New Member
    Reviving this thread. I'm looking to DIY some front fenders in a few weeks, but don't want to F them up. How difficult is it to fit and line these up to the body lines and headlight? If some of you have taken these to a shop, it would be great to have a recommendation or two for some place in northern CA.
  15. Sep 15, 2021 at 4:54 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Stellar in Sac has done some. Pretty easy to DIY.
    If @dcsleeper408 isn't too busy he might be able to do 'em.
    pandapro and joonbug like this.
  16. Sep 15, 2021 at 7:13 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Which brand you getting? Can’t speak for the other brands but the SDHQ glass was straightforward and fairly easy to install. They have little dimples where the bolts go through that you have to drill out. I didn’t trust the dimples so I spent a lot of time test fitting them to make sure it would all line up. After all that, the dimples did line up correctly. If I were to do it over again, I’d skip the test fitting and go straight into drilling and installing.
    Couple other things to note off the top of my head, where it mounts under the hood near the hood hinge, you’ll have to bend the metal there to make it fit. Or fab some kind of L bracket to make it work. Also, you’ll have to drill out 2 square holes in front for the grille to attach to. The 2 long tabs that stick out the grille, they almost snap in. Take your time drilling those out, if the hole gets too big it won’t secure the grille very well. And last thing I can think of is, don’t forget to move the rubber seals and stuff over from the old fenders. Mine are still on my stock fenders. :D
    831Tun likes this.
  17. Sep 15, 2021 at 7:18 PM
    pandapro
    pandapro New Member
    I went with the advanced fiberglass fenders. Their YouTube instructions seem pretty straight forward, but it doesn’t go into too much detail about how to actually test fit them or what to watch out for. I leaning towards installing them myself so this is great. Appreciate it!
    joonbug[QUOTED], 300BLK and 831Tun like this.
  18. Sep 24, 2022 at 3:42 PM
    whitemikemac
    whitemikemac New Member
    2019 limited tundra LT
    Total chaos long travel Ss built bumper Bed cage with dual spares Baja designs lp9’s Deaver rear with stock kings and bumps
    Dumbest idea ever.
    I did the fronts myself a while back. Took 4 hours or so….
    I’m 8 hours in with disassembly, and still on the driver side. F*%kin blows…..
    831Tun, TXTundra2722 and J&ATundra like this.
  19. Sep 24, 2022 at 3:44 PM
    #49
    whitemikemac
    Mentally the hardest thing to do. Literally take a grinder too the truck and paint you’ve tried to keep perfect for 3+ years now.
    no going back now! Lol
  20. Sep 24, 2022 at 4:22 PM
    #50
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Fronts suck rears are even worse
  21. Sep 24, 2022 at 7:04 PM
    #51
    whitemikemac
    Just a few things to button up on driver side. Hopefully passenger side is a bit easier tomorrow.
    i really had to cut a lot of the rear around the tail light. It’s like the flat vertical piece that fits flush against the tailgate section was in my way… so I cut it. All of it. ‍♂️
    heckler66, vq35721 and TXTundra2722 like this.
  22. Sep 24, 2022 at 7:17 PM
    #52
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea mine needs more trimming there to sit flush also. Great work!
    whitemikemac[QUOTED] likes this.
  23. Sep 26, 2022 at 7:02 AM
    #53
    whitemikemac
    Well. It’s “done”. Drivable at least but needs little odds and ends.
    1.Gas tank cap is tight in the fiberglass recess.
    2.Filler neck for gas tank needs raised about an inch
    3. tailgate test fit is too tight, need to trim passenger side fiberglass
    4. install bumper
    5. heavy cutting anticipated to the shell to put that back on one day. That will be fun.
  24. Sep 26, 2022 at 8:46 AM
    #54
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Looking Good!
