FFV not available in CA ? What's up with that ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 4sallypat, Aug 9, 2018.
  1. Aug 10, 2018 at 12:19 PM
    Stig
    Stig New Member
    FFV is known to cause cancer in the state of CA, so it is illegal. In the United States you can buy and drive FFV without issue. If I had the choice, I'd still buy FFV so that in a disaster situation when all the pumps are dry or lines are 10 cars deep I can still find flex fuel and fill up and be on my way.
    4sallypat[QUOTED][OP] likes this.
  2. Aug 10, 2018 at 12:46 PM
    reaper3030
    reaper3030 New Member
    Charles
    Tundra 2018 SR5 4X4 Concrete Crewcab
    Rock star wheels, off road tires, LED interior lights, LED fog lights, and .50 cal antenna.
    And if you use flex fuel your exhaust smells like popcorn...
  3. Aug 10, 2018 at 2:07 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    There are no differences in the oiled engine parts between the 2 motors. At least this is what I have been told. My Tacomas were 5k on dino. I just switched to a good syn and went 7500 - 10 with no problems.
  4. Aug 10, 2018 at 2:12 PM
    15whtrd
    15whtrd Mr. Blonde
    Also to add, if you are running flex fuel I thought it was recommended that you try to use all of your regular gasoline up before filling with flex. Same goes in reverse so that the computer knows to switch between the two. Also thought I read that people have issues when switching between the two.
  5. Aug 10, 2018 at 2:47 PM
    4sallypat
    4sallypat [OP] New Member
    Ha ha - EVERYTHING in CA causes cancer but not the 49 other states !
    Another reason I hate California....
    Tierhog likes this.
  6. Aug 10, 2018 at 3:55 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    I can't speak to the Tacoma, and I'm no engineer. I did read the oil change requirement for the 3UR-FE is 10k and the 3UR-FBE is 5k. This is set by Toyota. You can of course run extended drain Intervals without noticing short term problems, but I'm unaware of a 10k option for the FBE even with synthetic.
    A few have mentioned why, but I can't remember specifically.
    http://toyota.custhelp.com/app/answers/detail/a_id/7604/~/what-are-the-oil-change-intervals-using-synthetic-oil?
