Explain like I'm 5, why are some 2022 Tundra lifts sub-par?
Discussion in '3rd Gen Tundras (2022+)' started by DBWA, Aug 21, 2022.
  1. Aug 22, 2022 at 8:45 PM
    BrennanHuff
    BrennanHuff New Member
    Toyotas
    And every 911 until the 992 GT3, and every BMW, etc.
  2. Aug 22, 2022 at 9:06 PM
    DBWA
    DBWA [OP] New Member
    Dave
    2022 Tundra TRD Limited 6.5' Bed
    @mass-hole @KroppDuster
    What are the Bilstein 5100s? Why would they be a cheaper and better upgrade? Do they more readily fit with the rest of the stock suspension on the 3rd Gen?
  3. Aug 22, 2022 at 9:53 PM
    mass-hole
    mass-hole New Member
    They are drop in replacements for the OEM shocks. The fronts typically accept the OEM springs, and the lower spring perch has an adjustable collar so you can change the amount of lift in the front. The ones on my F150, for example, have 5 settings from 0 to 2.1" of lift I believe. They are usually around $400 for all 4, but you use you reuse stock front springs and top hats usually.
  4. Aug 22, 2022 at 11:28 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Toyota like all manufactures can deny a warranty claim IF they believe the claim is related to a modification of the vehicle and the modification is related to the failure.
    That why they offer OEM parts to modify with, esp suspension parts and kits that when installed by a toyota dealer do not void the warranty of the vehicle or the parts installed.
    I think all of us at one time have modified our vehicles as soon as we got them, its a risk we take.
  5. Aug 23, 2022 at 4:36 AM
    tundradelapat
    tundradelapat New Member
    '22 MGM Limited
    Whoops, good catch, thanks!
  6. Aug 24, 2022 at 8:50 AM
    Mchalk13
    Mchalk13 New Member
    2022 SR5 OR Army Green
    You aren't wrong, on either account, BUT I do prefer the look of a leveled out truck and if I can get away with it for a decent price and no loose a crap ton of ride quality I'm all for that. Thank you.
  7. Aug 24, 2022 at 9:07 AM
    DBWA
    Dave
    Thanks to @KroppDuster's other thread on the voiding of the suspension warranty, I feel like I have a better grasp now of how Toyota can void a warranty on parts that one modifies themselves. It does make sense to me that if I replace the muffler with an aftermarket muffler and then have an exhaust problem Toyota would be like: that's not our muffler and we aren't responsible for fixing it.
    KroppDuster likes this.
  8. Aug 24, 2022 at 9:15 AM
    DBWA
    Dave
    After reading this thread y'all inspired me to do some research, I found this video helpful for explaining the different parts involved and some of the features available on the market even though it's geared for coilover's on a sports car. If you have the equivalent of this video for trucks please post it below. https://www.youtube.com/watch?v=xmr14nCivZA
  9. Aug 24, 2022 at 9:42 AM
    DBWA
    Dave
    First assumption I need to check and general question to verify something here. Putting a 3" coilover lift on a truck would provide better tire clearance, but ground clearance may remain the same? I'm assuming the lowest point on the 2022 Tundra is the bottom of the axle housing?
    Second assumption. Being able to fit larger tires actually lifts the ground clearance? I'd guess that going from 33" tires to 35 inch tires would only provide 1" of lift since it's half the increase in diameter?
  10. Aug 24, 2022 at 9:48 AM
    Your lowest point on the truck is technically your limiting ground clearance in some situations. But having more “ground clearance” for the bumpers, rockers and body by lifting the suspension increases those clearances and improves your approach, departure, and break over angles. Only your rear differential and lower A arm at the ball joint clearance remains unchanged with the suspension lift. Larger tires will increase the clearance there.
    des2mtn and DBWA[QUOTED][OP] like this.
  11. Aug 24, 2022 at 9:50 AM
    DBWA
    Dave
    That makes alot more sense. The context of the truck determines clearance, and so the approach/departure angles can play a big role and the amount of clearance you have in those relative to your obstacle. Thanks for the verification.
    PapaDave418 likes this.
  12. Aug 24, 2022 at 9:51 AM
    Don’t drive directly over the boulder centered up.
    DBWA[OP] likes this.
  13. Aug 24, 2022 at 10:11 AM
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    What he said.
    It’s counterintuitive but when faced with obstacles you WANT your tires to roll on top of the big rocks, that will lift the truck up higher and over other rocks, increasing your clearance. On the highway if there’s a small object we tend to drive over it splitting it between our wheels. But off road (depending on the obstacle) get your wheels onto the big rocks and it tends to be easier to pass than you initially thought.
  14. Aug 24, 2022 at 10:27 AM
    mass-hole
    The lift does help on independent suspension and raises anything besides a solid rear axle up higher. Chances are, the first thing you are gunna hit on a long truck like the Tundra is the running boards or door sills and a lift will help there. I actually folded up the running board on my lexus GX landing on a rock a few weeks back.
    But I am a fan of tires first. Then lift if you feel like it. I am running 285/70's on my Lexus GX with the stock suspension. I didnt have to trim, just used a heat gun to mold some plastic out of the way. Most people wait to run the same size tire until they have a 2-3" lift. While their trucks might be slightly more capable, I bet 99% of the time mine would go anywhere they would, especially with some decent skids and sliders.
    On my F150 I am running 315/70R17 Raptor tires on a nearly stock suspension. I am running Bilstein 5100's but the fronts are on the lowest setting. You wouldnt be able to tell it from a stock truck without looking really close.
    DBWA[QUOTED][OP] likes this.
  15. Aug 24, 2022 at 10:39 AM
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    I believe the burden is on the manufacturer to prove that the aftermarket part is directly causing the issue according to the Magnuson-Moss Act.
    With that said, Toyota has better litigation power than your average consumer; so they would likely be able to prove an aftermarket lift to be the cause of any related driveline part failure should it occur.
    LukeS likes this.
  16. Aug 24, 2022 at 10:42 AM
    mass-hole
    Exactly. If they decided to push back, what are you gunna do? Take them to court over a $200 part and hope that they don't absolutely steam roll you with evidence that your $75 spacer lift wouldn't cause additional stress on the suspension to cause early failure?
    Its great that the Act exists, but my guess is in the real world its pretty worthless.
    DFS, MSU Tundra[QUOTED] and LukeS like this.
  17. Aug 24, 2022 at 5:42 PM
    LukeS
    LukeS New Member
    Luke
    Northeast PA
    Army Green Limited TRD OR
    I think you're right on the money there. If I lift my truck and something breaks that the dealer won't cover should I just pay the $2k bill out of pocket or should I pay my lawyer $3k to fight it and after a year of back and forth finally, maybe get it fixed for "free".
    MSU Tundra likes this.
  18. Aug 24, 2022 at 5:50 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    MSU Tundra and csuviper like this.
  19. Aug 25, 2022 at 9:31 AM
    #49
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    I have had warranty refused over aftermarket items before, I bring in a printed copy of the act and my attorneys card and ask to see the service manager. 99% of the time it gets fixed right then and there. Being nice about it goes a long ways.. and bring doughnuts.
  20. Aug 25, 2022 at 9:33 AM
    #50
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    He's glossing over it, but this is really the key to getting $hit done.
    LukeS and DexterL[QUOTED] like this.
  21. Aug 25, 2022 at 10:16 AM
    #51
    mass-hole
    Honestly, I've never tried nor needed too. The only vehicle I have ever owned that had a warranty was my F150 and the only warranty work I ever had to have done was a replacement microphone for the entertainment system. But it hasnt been in warranty for 3-4 years.
    Every other car I have owned was either too old or to many miles to still be under warranty. I generally do all of my own work.
    KNABORES likes this.
