Everything you need to know about Upper Control Arms (UCA)
Discussion in 'Suspension' started by csuviper, Mar 29, 2016.
  1. Apr 27, 2018 at 1:17 PM
    #181
    TundraDude772
    TundraDude772 Shake N’ Bake, Ricky Bobby
    Eric
    FL
    2010 & 2020 SR5
    2010 SR5 CrewMax Silver Sky Metallic 7” BDS/Fox 17x8.5 Method MR705 40x13.50 Toyo M/T Transfer Flow 46 gallon ICI Magnum front bumper PML Transmission Pan Hooke Road 18” bed rack Nature Nest Hard-Shell RTT Ironman 4x4 awning Coachbuilder upgrades SuperPro LCA Bushings Total Chaos UCA’s Energy rack bushings Moog LCA Cams 2020 SR5 Double Cab Voodoo Blue 40/20/40 Front Bench TRD Pro Grille TRD Pro headlights 17x9 Vision 351 285/70 Toyo A/T3 PML Transmission Pan RCI Skidplates eBay bumpers TRD rear sway bar
    E1774814-A3D1-4E0C-A0C1-338749581A0A.jpg Had the alignment done Thursday. Numbers came out good:yes:
    Erichudgins, trayday and Jsena like this.
  2. May 18, 2018 at 7:49 PM
    #182
    kirk1963
    kirk1963 New Member
    New JBAs installed - 3/3.4 caster
    HazMatt, Sas, OBXTundra and 2 others like this.
  3. May 20, 2018 at 5:31 PM
    #183
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    I dig the red on red.
    kirk1963[QUOTED] likes this.
  4. Jun 24, 2018 at 2:06 PM
    #184
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    TXRailRoadBandit73 likes this.
  5. Jun 27, 2018 at 5:47 PM
    #185
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    This is a great thread. I'm learning a ton.
    I have an OME lift of about 3 inches max. with stock UCA's. As far as I know my alignment is fine.
    The only reason I would want to replace my stock UCA's would be for something more rugged and beefier. I do a fair amount of driving on rocky rough roads, mainly by myself, and I don't want to get stranded.
    Or, are there other parts of my stock suspension that are more prone to breakage that I should think about upgrading first.
    Thanks so much, I'm a complete noob on this stuff.
    Cheers, Rick
  6. Jun 28, 2018 at 8:53 PM
    #186
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have Fabtech uppers and love them. Makes alignments easy for the guys at the garage too.
    I see plenty of talk about uppers but very little on lowers. In my mind, they’re both equally important...what options are available on lower upgrades?
  7. Jun 28, 2018 at 9:01 PM
    #187
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If you held a stock upper in your hands then picked up an upgraded version, you’d wonder how toyota even thought it was a good idea to use such a wimpy upper on these trucks.
    The lift changes the angle the ball joint articulates on so it can add stress to the limited range of movement OEM arms have. Not to mention harder to maintain alignment. 3” probably isn’t anything to worry about but it can still wear that ball joint out prematurely imo. I’d definitely upgrade the UCAs.
  8. Jun 29, 2018 at 7:21 AM
    #188
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    Thanks so much for your reply.
    This is precisely what I wanted to know.
    Now which one should I get?...:)JK.
  9. Jun 29, 2018 at 8:08 AM
    #189
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I’m partial to the Uni-ball design
  10. Jul 3, 2018 at 11:33 AM
    #190
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Like Texas already said, replacing the upper at 3" of lift is probably a good idea. You'll clear the uniball/balljoint better and avoid possible bind. Which one you want is kind of a crapshoot. If you want to run tires in the 37" range, stay away from the Camburg as they induce quite a bit of caster and that pushes the tire closer to the body mount
    I don't know anyone who has broken or bent a lower on a Tundra - they're beef as fuck. We jump our Tundra almost every time we go off road and we're still on stock lowers. Here's the upper half for reference.
    We did however weld in spindle gussets and cam tabs since those are known to bend or snap off.
  11. Jul 15, 2018 at 4:38 AM
    #191
    Like a PRO
    Like a PRO New Member
    Rodney
    Slidell Louisiana
    2016 lifted 4×4 SR5
    6 inch Rough Country lift fuel 20×9on 35s , TRD Pro Grill TRD Pro exhaust dual Extang 2.0 tonneau cover
    Any pointers on installing these BDS UCA's?????? I've put the 7" 2.5 fox coilovers front and rear just wanted to do i20180424_180703.jpg t myself hoping I don't run into any suprising stuff in the process
  12. Jul 15, 2018 at 4:41 AM
    #192
    I wanna say or believe the battery has to come out for driver side, for the bolt to come out, I could be wrong, someone else will chime in to assist
  13. Aug 3, 2018 at 1:23 PM
    #193
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    image.jpg Just got this in!
    csuviper[OP] likes this.
  14. Aug 15, 2018 at 6:56 AM
    #194
    Jermalex
    Jermalex New Member
    Central Idaho
    2011 Tundra 5.7L DC LTD
    Billstien 6112/5160 shocks, EBC Rotors and Pads, lots of little tweeks
    How do you think your tire clearance compares with other UCAs? It looks like the JBAs protrude a bit more past the centerline of the ball joint post than some of the more conventional designs (TC, Camburg, Icon, etc. )
  15. Aug 15, 2018 at 7:03 AM
    #195
    OBXTundra
    OBXTundra Member
    Southeast USA
    I have stock wheels with 1.5" wheel spacers. clearance is only about an inch at full droop.
    This will be different for all setups. But I know mine would be really close, or touching, without the wheel spacers.
  16. Sep 25, 2018 at 1:57 PM
    #196
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    How do ya like em, and what alignment figures are ya seeing? Kinda wondering about those, would like to upgrade from stock UCA’s sometime in the near future.
  17. Sep 25, 2018 at 2:40 PM
    #197
    anthonygan
    2017 Cement TRD PRO
    They are super nice!!! Look amazing ! Alignment is good!!!
  18. Sep 25, 2018 at 2:54 PM
    #198
    trdprobped17
    trdprobped17 New Member
    @csuviper I didn’t see True Travel Dynamics on your list of UGA manufacturers, do you know who makes it?
  19. Oct 3, 2018 at 5:10 PM
    #199
    dejabrown
    dejabrown New Member
    Dave
    Gilbert, AZ
    2010 Crew Max Platinum
    Backflip cover, OME suspension, Smittybuilt M1 rear bumper, Move front bumper
    Excellent write up! Thanks for the education. Any idea who makes the UCA for Slee Offroad? I have them and am waiting to have them installed next Friday. How do they compare?
  20. Oct 17, 2018 at 1:21 PM
    #200
    Mgmtundra
    Mgmtundra MGM Crew
    Kirk1963 - specs on your wheel tire combo? Looking at the JBA’s but haven’t seen them with anyone running 35”+
  21. Oct 17, 2018 at 1:33 PM
    #201
    anthonygan
    2017 Cement TRD PRO
    BAED2C85-B524-48D3-B13B-F4A66B4D7772.jpgInstalled now
  22. Oct 17, 2018 at 2:25 PM
    #202
    KevinK
    Tundras to Sedona
    The best stock length UCA in my opinion. The on-truck adjustable heims make them a game changer.
  23. Nov 6, 2018 at 7:59 AM
    #203
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Sheesh, such a ton of info and I think I’m more lost now than before lol. If anyone wants to chime in, I plan on doing a fox 2.5 for 3” up front. I have rebounds that are 17x8.5 with I think 5.75 backspace (or close to it). Looking at getting 34-35”s x 11.5-12.5” on. 90% pavement driving right now but have plans for increasing the off-road %. Was leaning between Camburg, bds, or spc for the UCA. Mcm fab has entered my realm of thought now as well. Any suggestions on which route to go for this setup? I’ve seen most on here talking about 6”+ lifts and that is def not my style.
    831Tun likes this.
  24. Nov 6, 2018 at 8:16 AM
    #204
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    MCM or Total Chaos are gonna yield the best alignment #s IMO. That's for non-heim. I've had several sets of UCAs and currently have MCM. It's important to note that alignment #s for a lifted truck are not the same as for a stock height truck.
    bigzrs01[QUOTED] likes this.
  25. Nov 6, 2018 at 8:40 AM
    #205
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Totally get it. I just want to get the best results out of the gate, although I know our trucks are a never ending money pit and I’m sure things will change as we go. I’m going to eye hard the MCM.
    831Tun[QUOTED] likes this.
  26. Jan 25, 2019 at 4:20 AM
    #206
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Old thread but didn’t see an answer. Most UCA’s show applications for 2-3”. What can be used in that grey area of 3-4”? Can I still grab the total chaos on the group buy? Or will they not work?
  27. Jan 25, 2019 at 7:41 AM
    #207
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Total Chaos will still work for 4"
    LT75[QUOTED] likes this.
  28. Feb 19, 2019 at 1:03 PM
    #208
    Landodnal
    Landodnal New Member
    Ryan
    2008 Toyota Tundra Limited Slate Grey 4WD
    2" Leveling Kit
    Hi everyone. New member here. I have a 2008 Tundra Limited 4WD. I bought it in 2017. When I got it, it already had what I believe is a 2" spacer in the front. I believe the spacers were the only additions. The alignment was not great when I bought it. It had pretty bad positive camber. The naked eye could see that the front tires were angled in. It also would get squirrely on the road with any rain or snow. Five months later it had worn the outside of the tires pretty bad. I replaced the tires with BF Goodrich AT KO2's. When I got the tires replaced I also got an alignment. It drove much better. But now after a year of having the new tires, they are beginning to wear on the outsides again. And you can still see that it has too much positive camber. Too boot, the upper ball joints are beginning to squeak really bad when I turn. I believe the angle of the ball joint after the alignment has caused them to wear faster. I am in the market for aftermarket control arms. I want the camber issue fixed. I'm not too worried about the caster. It drives pretty smooth. I only drive on the road. It's my daily driver. My question is, do I have to get adjustable UCA's to fix this issue? Will I be ok getting the SPC UCA's? If I do get the SPC's, will they have enough camber adjustment to fix the issue? Also, the non-adjustable UCA's, do they do anything to the camber (add or subtract from), or are they set to the factory camber? Thank you for any and all help.
  29. Feb 19, 2019 at 2:24 PM
    #209
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I just installed the SPC adjustables with my 4” lift up front. They can be had for around $475 online. Can’t Beat the price and I couldn’t be happier with my alignment.
    Landodnal likes this.
  30. Feb 19, 2019 at 6:42 PM
    #210
    Landodnal
    Ryan
    2" Leveling Kit
    Thanks LT75. If you don't mind me asking, where did you find them for $475? I will most likely be getting a set.
    BabyBlackYota likes this.
