Everything you need to know about Upper Control Arms (UCA)
Discussion in 'Suspension' started by csuviper, Mar 29, 2016.
  1. Mar 29, 2016 at 3:13 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Starting this thread because i was doing some research that started from a FB post and i wanted to know the facts behind each.
    What is a control arm suspension?
    In automotive suspension, a control arm, also known as an A-arm, is a hinged suspension link between the chassis and the suspension upright or hub that carries the wheel.
    The inboard (chassis) end of a control arm is attached by a single pivot, usually a rubber bushing. It can thus control the position of the outboard end in only a single degree of freedom, maintaining the radial distance from the inboard mount. Although not deliberately free to move, the single bushing does not control the arm from moving back and forth; this motion is constrained by a separate link or radius rod.
    This is in contrast to the wishbone. Wishbones are triangular and have two widely spaced inboard bearings. These constrain the outboard end of the wishbone from moving back and forth, controlling two degrees of freedom, and without requiring additional links.
    Most control arms form the lower link of a suspension. A few designs use them as the upper link, usually with a lower wishbone. The additional radius rod is then attached to the upper arm
    What is the upper control arm used for:
    • Free-er movement vs stock arms.
    • Wider range of movement = increased travel.
    • Helps to achieve alignment specs. They provide more caster because of the placement of the pivot point being moved upward. This helps you out because when you lift, you lose caster, without caster your truck will want to wander.
    There are two types of upper control arms; Ball Joint and Uniball
    Difference between ball joint and uniball....
    Ball Joints are the same as what comes standard on the Tundra. Aftermarket are typically stronger and provide additional travel.
    Uniballs are really just a version of a heim joint.
    Upper Control Arm Manufacturers
    • Toyota Stock UCA - Ball Joint
    • SPC Light Racing - Ball Joint
    • Total Chaos - Uniball
    • Camburg - Uniball
    • All-Pro - Uniball
    • Icon tubular steel - Uniball
    • Icon machined aluminum - Uniball
    • Pro Comp - Uniball
    • MCM Fab - Uniball
    • Fabtech – Uniball
    • Tuff Country
    • JBA - Ball Joint
    • PRG - Uniball
    • Mevotech - Ball Joint
    • Zone Offroad - Ball Joint
    • ReadyLIFT - Uniball
    • Rogue Racing - Uniball
    • Blitz Auto - Uniball
    SPC Light Racing Ball Joints
    Manufacturer -
    Part Number -
    Size - 36mm (1.417")
    Type of lubricant -
    Adjustment range:
    Camber ±2.0°
    Caster -1.0° to +3.0°
    Greaseable ball joint and SpecRide™ bushings
    • A new Greaseable design
    • A new hybrid 2-piece race and internal spring compensate for wear and maintain turning torque and OE lash requirements for life of vehicle
    • A massive 36mm ball that is highly polished and Electroless-nickel plated to provide a hard, smooth wear surface for a long service life
    • Sealed boots to retain grease and protect from the elements
    • 80 degrees of joint articulation to maximize travel without bind
    • These ball joints are a direct replacement for the original joints that came with many of our Toyota and Nissan truck upper control arm sets.
    Camburg Uniballs
    Manufacturer - FK Bearings
    Part Number - COMH-24T
    Size - 1.5" ID
    Type of lubricant -
    COMH which stands for Commercial series, low carbon steel.
    The body is 52100 Steel Heat Treated Hard Chrome Plated.
    The race is low carbon steel oil coated.
    • Increases usable wheel travel
    • Corrects camber & castor
    • Eliminates weak factory joints
    • Stainless steel heat-treated uniball spacers
    • FK 1.50 Uniballs
    • Made in the USA
    • Designed for 1″-3″ Lift Suspension Systems
    Total Chaos Uniballs
    Manufacturer -FK Bearings
    Part Number - WSSX16T
    Size - 1" ID
    Type of lubricant -
    WSSX-T series stands for Wide series, stainless steel, self lubricating.
    The ball is 440C Stainless Steel Heat Treated
    The race is 17-4PH Stainless Steel Heat Treated
    • 4130 chromoly tubular upper control arms are 100% bolt on and hand crafted in the U.S.A.
    • UCA's are designed with added caster to aid in retaining factory alignment specs when aftermarket lift kits are installed. This reduces the darting or wandering in the vehicle's steering when 2.5"-3" lift kits are installed.
    • CNC machined tapered spindle adapters convert the factory ball joint to a 1" uniball for added component strength & maximum wheel travel.
    • TOTAL CHAOS includes 1" I.D. uniballs that feature a heat treated stainless steel ball & heat treated stainless steel race for maximum corrosion resistance and component longevity. These uniball's also features a military grade PTFE woven fabric liner that helps prevent noise.
    • Custom profile upper and lower hi-misalignment spacers maximize droop wheel travel and are machined from heat treated 17-4 stainless steel.
    • Upper control arms combined with extended length coil over shocks will allow for up to 2" of additional wheel travel.
    • Urethane bushings reduce bushing deflection compared to stock rubber bushings.
    • Control arm pivots include zerk fittings to grease the urethane bushings & inner sleeves without disassembly.
    • 2 stage powder coat process includes a durable clear coat to provide a long lasting finish.
    • Complete grade 8 hardware kit is included.
    All-Pro
    Manufacturer -
    Part number -
    Size -
    Type of lubricant -
    Icon tubular steel - uniball
    Manufacturer -
    Part number -
    Size -
    Type of lubricant -
    • 1026 Thick Wall DOM Seamless Tubing
    • CNC Bent Tubing
    • CNC Machined Bushing Housings and Sleeves
    • 4130 CNC Machined Uni-ball Cup
    • 1" Stainless PTFE Lined Uniball Bearings
    • 17-4 High Grade Stainless Steel Uni-ball Adapter System
    • High Precision CNC Machined Pin Provides OEM Like Fitment
    • Professionally Precision Welded
    Icon machined aluminum - uniball
    Manufacturer -
    Part number -
    Size -
    Type of lubricant -
    • 6061 Billet Aluminum
    • Precision CNC Machined
    • 1” PTFE Lined all Stainless Uniballs
    • Easily Adjustable on the Vehicle for Perfect Wheel Alignments
    • 17-4 High Grade Stainless Steel Uni-ball Adapter Pin
    • Forged PTFE Lined 3/4” Rod Ends
    • O-ring sealed uniball cover cap
    • Made in the USA
    MCM Fab - Uniball
    Uniball Manufacturer - FK Bearings
    Uniball Part number - could be WSSX16T
    Uniball Size - 1"
    Uniball Type of lubricant -
    Our uniball UCAs are made from 1.5" DOM tubing and TIG welded. Energy suspension bushings, and only use 1" stainless FK bearings for the best corrosion resistance in all weather conditions.
    MCM Fab Uniball Upper Control Arms for the 07+ Toyota tundra. These arms are designed to increase caster for lifted applications and improve drivability both on and off the road. Combined with an aftermarket bolt in coilover, 12.5" Of travel is possible. These come with a standard satin black powdercoat finish. Includes UCAs, High Quality FK Stainless bearings, and all neccessary hardware for installation
    JBA
    PRG
    The control arms have heim inner pivots (instead of polyurethane bushings) for alignment purposes, and a 1" uniball to replace the stock balljoint. prgproducts.com
    This is a work in progress. Stay tuned for more info.
  2. Mar 29, 2016 at 3:26 PM
    csuviper
    Broomfield, CO
  3. Mar 29, 2016 at 5:25 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Awesome right up Brian. Camburg had ball joint uca's also.
    AnonVet likes this.
  4. Mar 29, 2016 at 5:27 PM
    Sefferston and TRON like this.
  5. Mar 29, 2016 at 5:28 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Glad you made a write up on this. Explains it to the know-nothing's like myself lol.
    Krezz and Eclipsed & Floating like this.
  6. Mar 29, 2016 at 7:42 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Great thread, I'll be following..
    Thanks for taking the time to write it.
  7. Mar 30, 2016 at 4:04 AM
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Subd. I grabbed some MCM Fab uniball uppers for mine but it's all basically the same thing
    AnonVet likes this.
  8. Apr 6, 2016 at 7:48 AM
    Gregman
    Gregman New Member
    Greg
    2005 Tacoma DCLB SR5 4.0 4x4
    Firestone RideRite air bags with on board compressor, Tekonsha P3 brake controller, Leer cap, Thule rack, Mickey Thompson Classic III wheels, Michelin LTX AT2 LT tires
    Stormtrooper81 and Black Wolf like this.
  9. Apr 6, 2016 at 10:03 AM
    YotaDan
    YotaDan New Member
    Grants Pass, Oregon
    Nice Write Up!
  10. Apr 6, 2016 at 10:18 AM
    csuviper
    Broomfield, CO
    Its still in the works. Really haven't fine tuned anything yet.
    Still missing the differences, why you need it, further list of companies and trimming the verbiage from the websites on each UCA description.
    zcarpenter92 likes this.
  11. Apr 6, 2016 at 5:33 PM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    Forgot about the heim joint option from TC. Not really sure many people would run them over bushing but I've been looking into it....
  12. Apr 6, 2016 at 5:40 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Good lord Brian you have alot of spare time.....
  13. Apr 6, 2016 at 5:44 PM
    You won't. You will be putting on my UCA's soon enough. Money tree is starting to bear fruit. (Which one's to get???....still thinking SPCs)
    Stormtrooper81 and zcarpenter92 like this.
  14. Apr 6, 2016 at 7:38 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I dig spc for normal drivin trucks. Rugged enough for the occasional offroad and low maintenance for the dd's
    Black Wolf likes this.
  15. Apr 6, 2016 at 9:39 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    before i got my tundra i had a great little tacoma that i installed a set of total chaos uca's on. a couple things i could say about them is that they were very time consuming to install but allowed me to correct my camber once aligned following a 3" lift. it doesn't hurt that they looked fantastic too.
    a3419457-5afa-4302-a5bc-7dc217dc6cfc_zps_fba6a8f842ffc679ff2da010d8cab163269baeda.jpg
    Stormtrooper81 likes this.
  16. Apr 12, 2016 at 6:06 PM
    Apparently new SPC LR's are shipping with greaseable ball joints for around $540. Hmmm.....
  17. Feb 13, 2017 at 7:49 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I'm an alignment and lift noob. I have a 3/1 level with front coilovers and rear shackles. I would like to install control arms as my caster is a little out of spec. Will the SPC control arms provide the additional suspension travel that the TC UCAs advertise as well? Additionally, I have read that uniball UCAs require more frequent maintenance and wear out faster. Is that a rebuildable item on the TC UCAs? What kind of additional maintenance are we talking about?
    I want to pull the trigger on a pair today, but I'm trying to figure out what is best for me. The majority of my driving is on the street, but I do go offroad a reasonable amount. I would like to be well-equipped for desert driving on both hard and occasionally soft substrate..
    Any help from some of the pros is appreciated!
  18. Feb 13, 2017 at 8:40 AM
    csuviper
    Broomfield, CO
    Yes, slightly less than the TC.
    Wash out often and I thought apply dry lube. Someone recently said TC doesn't recommend the dry lube but I thought they did.
    Yes if the ball wears out it can be pushed out and replaced. It's held it by a retaining ring.
    You can replace with a standard 1" stainless uniball from FK Bearings or pay the premium from TC. $80-$180 for replacement pair.
    Backslider[QUOTED] likes this.
  19. Feb 13, 2017 at 10:12 AM
    Jus got edgemicated wow!!! I will look further into n get me a pair thanks Brian!!!!
  20. Feb 13, 2017 at 11:56 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Good write up Brian, not sure how I didn't see this earlier. I'm thinking about the SPC UCA's also. I just want something with low maintaince.
  21. Feb 13, 2017 at 3:13 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I really needed something like this. I'm thinking on the ToyTec 3/1 leveling kit. I have stock UCA's, will I need new UCA's in order to get an alignment after the 3/1?
  22. Feb 13, 2017 at 3:37 PM
    Backslider
    Tooele, UT
    You won't absolutely need them, but I think at 3" it's a really good idea. It's hard to get an in spec alignment without aftermarket UCAs on a 3" lift.
  23. Feb 14, 2017 at 6:42 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Great thread idea.
  24. Mar 7, 2017 at 12:39 PM
    SikYota
    SikYota New Member
    Northport, AL
    2014 Platinum
    7" bds suspension lift with fox coilovers 37/13.50r20 cooper discover stt pros 20x10 -24 fuel mavericks with machined faces Nitro 4.88 gears Ekstrom design tie rod ends Zone carrier bearing drop Amp research steps Retrax pro bed cover http://www.gearinstalls.com/Chris2014Tundra.htm http://www.gearinstalls.com/Chris2014Tundrafront9.htm https://youtu.be/2P3yKKwG1ig
    • Brand-----------------------Type-----------------Alignment
    • SPC Light Racing-----------Ball Joint----------------Adjustable
    • Zone Offroad---------------Ball Joint----------------Fixed
    • Camburg--------------------Ball Joint----------------Fixed
    • Brand-----------------------Type-------------Alignment-----Sealed or open top-----Uniball size
    • Icon machined aluminum--Uniball--------------Adjustable-----Sealed top------------------1"
    • Total Chaos Heim-----------Uniball-------------Adjustable-----Open-------------------------1"
    • PRG--------------------------Uniball-------------Adjustable-----Open-------------------------1"
    • SVC Offroad-----------------Uniball-------------Adjustable------Open------------------------?
    • Pro Comp--------------------Uniball-------------Fixed-----------Sealed top-------------------1.5"
    • CST--------------------------Uniball-------------Fixed-----------Sealed top-------------------1.25"
    • Icon tubular steel-----------Uniball-------------Fixed-----------Sealed top-------------------1"
    • ReadyLIFT------------------Uniball--------------Fixed-----------Sealed top-------------------1"
    • Camburg--------------------Uniball--------------Fixed----------Open--------------------------1.5"
    • Total Chaos Urethane------Uniball--------------Fixed----------Open--------------------------1"
    • All-Pro-----------------------Uniball--------------Fixed----------Open-------------------------1"
    • Fabtech---------------------Uniball--------------Fixed-----------Open-------------------------1"
    • Rogue Racing---------------Uniball--------------Fixed----------Open--------------------------1"
    • Tuff Country----------------Uniball--------------Fixed----------Open--------------------------?
    • MCM Fab--------------------Uniball--------------Fixed----------Open--------------------------?
    • Dirty Deeds Industries-----Uniball--------------Fixed----------Open--------------------------?
    Added some more info to what you already had. We should keep this list updated, very useful.
    - Just realized this post doesn't look nearly as nice on mobile or tapatalk. May want to view it from a pc
    TXTundra89, csuviper[OP] and YotaDan like this.
  25. Mar 13, 2017 at 6:50 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Since I need an alignment, I figured I might as well order UCA's and get that outta the way but I've read a few times that people have been having trouble aligning with Camburg's. Is there a reason why? Are people having problems with TC and Icon's? I'm leaning towards these over the TC and tubular Icon's due to price, durability and size of the balljoints.
  26. Mar 13, 2017 at 10:57 PM
    csuviper
    Broomfield, CO
    Awesome man. I will update the OP.
    SikYota[QUOTED] likes this.
  27. Mar 13, 2017 at 10:58 PM
    csuviper
    Broomfield, CO
    I have the 3/1 Toytec Boss lift with TC UCAs. Did not have any trouble with alignment.
    Patriot likes this.
  28. Mar 14, 2017 at 3:54 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Same lift, no UCAs and honestly no issue with wandering at highway speeds...I must be lucky. Alignment at factory numbers no, but all in the green.
    myt1 likes this.
  29. Mar 14, 2017 at 8:20 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    I'm getting a UCA from toytec with my complete lift kit...which is the better option...SPC or TC? Mostly just a road driver but will go wheeling as well. Not to the extent that some of you guys do or even close to it but every once in awhile. Pros and Cons of both those 2 please
    Toytec Lifts likes this.
  30. Mar 14, 2017 at 8:32 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Total Chaos arms: Full tubular design, Grease-able zerks for the poly bushings, 1'' stainless steel uniball. Great flow and durable control arm, but they will require more maintenance. More aimed at the off road enthusiast.
    SPC: Factory style control arm, Factory style ball joint, made to be adjustable to insure your alignment is spot on. Grease-able ball joint is the only maintenance you will have to worry about with those. These arms are more for the Daily driver/weekend warrior style driver.
    Shoot us a call anytime if you have any questions!
    -David
    An1malSTYL3, Trm904, Hasteen and 7 others like this.
