Everything you need to know about Upper Control Arms (UCA)
Discussion in 'Suspension' started by csuviper, Mar 29, 2016.
  1. Apr 17, 2018 at 7:37 AM
    #151
    TundraDude772
    TundraDude772 Shake N’ Bake, Ricky Bobby
    Eric
    FL
    2010 & 2020 SR5
    2010 SR5 CrewMax Silver Sky Metallic 7” BDS/Fox 17x8.5 Method MR705 40x13.50 Toyo M/T Transfer Flow 46 gallon ICI Magnum front bumper PML Transmission Pan Hooke Road 18” bed rack Nature Nest Hard-Shell RTT Ironman 4x4 awning Coachbuilder upgrades SuperPro LCA Bushings Total Chaos UCA’s Energy rack bushings Moog LCA Cams 2020 SR5 Double Cab Voodoo Blue 40/20/40 Front Bench TRD Pro Grille TRD Pro headlights 17x9 Vision 351 285/70 Toyo A/T3 PML Transmission Pan RCI Skidplates eBay bumpers TRD rear sway bar
    I originally had a 3” level with stock spindles as well, so I know where you’re coming from.
    My BDS 7” kit comes with replacement spindles that are taller than oem. They aren’t just for 2wd trucks or lifts past 3” wouldn’t be possible. The control arms and tie rods require relocation after ~3” of lift. (Some people go 3.5”, but that’s pushing it)
    Jsena likes this.
  2. Apr 17, 2018 at 7:47 AM
    #152
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Ahh, if you’d of said you were doing a bracket lift I wouldn’t of been mixed up lol. My bad.
    Jsena likes this.
  3. Apr 17, 2018 at 7:59 AM
    #153
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    Haha all good brotha, I had mentioned it in a few of my previous posts so I assumed you had already saw my lift set up. I’ll be keeping the page updated with how it all works (or doesn’t) out!
    Jsena and zcarpenter92[QUOTED] like this.
  4. Apr 17, 2018 at 12:23 PM
    #154
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    BDS new UCA’s aren’t Heim Joints.. and BDS Lift will fit their new UCA’s.. so why does having Heim Joint matter??
    TundraDude772 likes this.
  5. Apr 17, 2018 at 12:24 PM
    #155
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Here now at a BDS vendor..
  6. Apr 17, 2018 at 12:38 PM
    #156
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    @TundraDude772 so did you use the aftermarket UCA’s did they work?
  7. Apr 17, 2018 at 12:44 PM
    #157
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I have 6112s maxed out up front.
    Will I gain noticeable travel with those shocks after going to a UCA like total chaos? Or will my benefit be more in the area of alignment?
    Jsena likes this.
  8. Apr 17, 2018 at 12:50 PM
    #158
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  9. Apr 17, 2018 at 12:50 PM
    #159
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    Most of my front end is still completely torn apart, so I can’t say for sure. I will note that if anyone uses these control arms with a reservoir shock set up, the UCA WILL contact the fitting coming off of the shock. The only way to fix this is to VERY slightly loosen the fitting so its angled more in-board. This may not apply if you aren’t using my exact set up, I will continue to update this thread as I find learn more.
    Jsena[QUOTED] likes this.
  10. Apr 17, 2018 at 12:53 PM
    #160
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What UCA are you going with?! I also spoke to BDS nad they said their UCA will work with their 7 inch lift with our withou the fox extended CO’s. Cause I’m eventually pulling out the extended strut spacer and putting the 7inch Fox CO’s
  11. Apr 17, 2018 at 12:53 PM
    #161
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    You should gain noticeable travel in the droop position if your angles are pretty bad with factory ball joints. I had no issues getting a alignment with my 3” level kit on stock UCA’s.
    Jsena likes this.
  12. Apr 17, 2018 at 12:56 PM
    #162
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    See post #139, I have the total chaos uniball with standard bushings. I’m sure their UCA will work with their 7” kit, but I have a 2.5” spacer on top of the coil. It’s too much angle for a standard ball joint.
  13. Apr 17, 2018 at 2:09 PM
    #163
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    OKAY!!! Im at Toyota now... .........
  14. Apr 17, 2018 at 3:12 PM
    #164
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    The BDS UCA's are different than the TC UCA's.
  15. Apr 17, 2018 at 3:18 PM
    #165
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I was at 4 The Truck all day today and Toyota.. so I got the scoop on all this stuff..so you’re rigjt about the Heim Joint part on other Aftermarket UCA. They will fit but it over corrects the position of the spindle,, I think that’s what he said.. and you can get them on but you’ll have a terrible alignment.. thus having the Heim Joint gives you all the movement you need to correct it... the BDS UCA doesn’t have the HEIM Joint BUT.... it’s designed specifically for their Lift with the way the spindles are and there for doesn’t need to have the Heim Joint, since it will be sitting already OEM Spec... I think that’s what I got out of all that today.. I hope that makes sense
  16. Apr 17, 2018 at 4:31 PM
    #166
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Do you know if there's additional travel with the BDS arms? Installing the TC arms from stock I noticed an improvement off road.
  17. Apr 17, 2018 at 4:33 PM
    #167
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Yea, the bds rep told me you’ll get an additional 2 inch plus or so , and it leaves room for Coilover reservoir won’t get hit like others
  18. Apr 21, 2018 at 9:20 AM
    #168
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    26EC8AA4-3B96-4EAB-9799-4BC108D0C41A.jpg C709ADC0-BBBA-492B-A7BC-9725AF234352.jpg EEC1BBA9-AA0B-4EEE-ADA1-997A63346AC9.jpg
    Level spacer and UCA’s on :thumbsup::bananadance:
    TRDPROSean and Jsena like this.
  19. Apr 21, 2018 at 9:22 AM
    #169
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Nice !!! You already lifted befored you put spacer on?
  20. Apr 21, 2018 at 9:41 AM
    #170
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    Yes sir, it had the bds 7” with a 1” spacer. Now it’s the 7” with a 2.5” spacer (Plus a .75” body lift).
  21. Apr 21, 2018 at 9:45 AM
    #171
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Wow, a little crazy I see lol.. you have the fox extended Coilovers ?
  22. Apr 22, 2018 at 7:01 PM
    #172
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    The ones that come with the bds 7” kit, yeah.
  23. Apr 22, 2018 at 9:56 PM
    #173
    TheBeast The Beach
    damn that's a lot of pre load
    zcarpenter92 likes this.
  24. Apr 24, 2018 at 2:02 PM
    #174
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    I have 6112's set at 1.9" up front and zero alignment issues. Question is: would I actually feel a difference on the road with upgraded UCA's? I know with upgraded UCA's you'll get increase in travel, and free-er movement, but would that actually be noticeable?
  25. Apr 24, 2018 at 4:59 PM
    #175
    TRDPROSean
    TRDPROSean New Member
    Hattiesburg, MS
    2017 CM TRD PRO
    275/70r18 Nitto Ridge Grapplers, TRD rear bar and intake, Coachbuilder +2 shackles, Corsa 14916 exhaust, UWS lo pro toolbox, Craven Speed stubby, tint
    I'm glad you asked that. I have been curious about that since my last Tundra. The one that I own now is the first vehicle that I've ever owned with any sort of notable suspension on it. I am very interested in learning more about suspension as it is definitely something I know NOTHING about. So, to the forum, I pose the same question: would it benefit my PRO at all to install a good set of UCA's or is that something that I just need to leave alone? TIA
    OP, thanks for the write-up.
    TundraDude772 and Jsena like this.
  26. Apr 24, 2018 at 5:06 PM
    #176
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    :popcorn::popcorn:
  27. Apr 24, 2018 at 8:22 PM
    #177
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    If your not going up in height then no it wouldn't really benefit you much. Money could be spent better elsewhere.
  28. Apr 25, 2018 at 5:13 AM
    #178
    Jrmysell
    Jrmysell New Member
    2014 DC 4X4 TSS SR5
    Does this apply to 6112/5160s at 1.9"?
  29. Apr 26, 2018 at 5:32 PM
    #179
    TRDPROSean
    Hattiesburg, MS
    2017 CM TRD PRO
    Thanks for the response. I appreciate it.
  30. Apr 27, 2018 at 9:30 AM
    #180
    Broncobroke
    Broncobroke Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    How much space is typical between the stock UCA and the tire? Just installed Michelin 285/65 r20 and I have approximately 5/8". Is that good or to tight?
    Never mind. Found an old thread with the same question.
