Everything you need to know about Upper Control Arms (UCA)
Discussion in 'Suspension' started by csuviper, Mar 29, 2016.
  1. Mar 26, 2018 at 5:24 AM
    #91
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Negative, 3" Eibach coilovers up front.
    GORDO661[QUOTED] likes this.
  2. Mar 26, 2018 at 1:08 PM
    #92
    GORDO661
    GORDO661 New Member
    08 White tundra SR5
    6" rough country lift 34" tires, Air Aid intake, Spacer, Smoke LED tails, Spyder black housing head lights
    @trayday So Toytec said they’ll do the return and I just place the order for the hemi joint ones. The mas for the info
    trayday likes this.
  3. Mar 26, 2018 at 1:23 PM
    #93
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Definitely! Glad I was able to save you a headache.
  4. Mar 26, 2018 at 3:10 PM
    #94
    GORDO661
    GORDO661 New Member
    08 White tundra SR5
  5. Mar 27, 2018 at 12:59 AM
    #95
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    Great thread!
  6. Mar 29, 2018 at 12:37 PM
    #96
    OcotilloSR5
    OcotilloSR5 New Member
    Southern California
    2013 Double Cab 4x4
    - 37x12.50r18 Yokohamas - Body Mount Chop - Hitch plug relocate - White Knuckle Rock Sliders - Fog Light Anytime Mod & HID kit - Energy Suspension Poly Rack & Pinion bushings - Sway Bar Delete - Coachbuilder leaf spring bushings - Coachbuilder strut spacers - Rear lift shackles - Wheeler's Superbumps - Limit straps - Diamond Eye 3.5" Cat-back - Aluminum Oil Filter Housing Mod
    01erionracing likes this.
  7. Mar 29, 2018 at 12:47 PM
    #97
    OcotilloSR5
    Southern California
    2013 Double Cab 4x4
    The Pro Comp arms use a high quality FK bearing. Are you doing your own work? Make sure all bolts are torqued to spec. I have 30k miles on these arms including thousands of off road miles. I do my own work and have zero problems. They are a high quality arm built here in California and my alignment guy got my truck driving nice with no problem. A little negative camber is a good thing.
  8. Mar 29, 2018 at 1:13 PM
    #98
    OcotilloSR5
    Southern California
    2013 Double Cab 4x4
    Same as Camburg.
  9. Mar 29, 2018 at 1:20 PM
    #99
    OcotilloSR5
    Southern California
    2013 Double Cab 4x4
    What specs are they trying to align to? A lifted truck with a performance alignment will not be within factory spec. A small amount of negative camber is fine and 3-5* of positive caster is what you want. 1/16-1/8" toe in.
  10. Mar 29, 2018 at 1:28 PM
    #100
    OcotilloSR5
    Southern California
    2013 Double Cab 4x4
  11. Mar 29, 2018 at 5:08 PM
    #101
    OcotilloSR5
    Southern California
    2013 Double Cab 4x4
  12. Mar 29, 2018 at 7:58 PM
    #102
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    OcotilloSR5[QUOTED] likes this.
  13. Apr 4, 2018 at 5:34 PM
    #103
    GORDO661
    GORDO661 New Member
    08 White tundra SR5
    Just installed them last night and just picked it up and taking it for a test drive
    trayday likes this.
  14. Apr 4, 2018 at 5:51 PM
    #104
    Anyone on here have UCA'S with a 6" lift?
  15. Apr 4, 2018 at 6:47 PM
    #105
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    That’s about where I am with TC UCAs.
    Black Wolf and GORDO661 like this.
  16. Apr 8, 2018 at 7:04 AM
    #106
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Ok so based on my reaserch so far I’ve screwed up and bought the wrong UCA for my desired application. But since I already have them and don’t exactly feel like buying a new set. Trying to make them work. I’ve gotten 2 alignments so far and still have 6.2* caster. Would like 3-4ish range like the total chaos arms provide. Or even stock geometry and I can bring my coils back down. Truck pulls and drives uncomfortable on road. when I added the uca I adjusted my coil 4 turns for more lift but the rebound stroke is really jarring since the coil is so stiff.(showing about 12 threads)
    Is there anyone who is successfully running these Camburg UCAs with decent alignment numbers?
    Or am I just out of luck? I have trimmed my inner tie rods 1/4” for more toe adjustment and might try one more alignment. Wanted some feedback here first from you experts. Thanks!!
    Black Wolf likes this.
  17. Apr 8, 2018 at 8:34 AM
    #107
    250rdave
    250rdave like I told the guy on ABC DANGER IS MY BUSINESS
    David
    surprise az
    2014 blue trd dbl cab
    Borla cat back Airraid cai raptor grill pro comp at sport
    I purchased a pro comp 6" lift and jba ucas and king c/o for a pro comp 6" lift( not installed yet). I did ask Marlin at jba if the arms will work with the pro comp lift before I bought them. Marlin said they will work with the bds 7" lift so the pro comp should be no problem.
  18. Apr 8, 2018 at 8:48 AM
    #108
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Have you had any rust issues with the bj housing on your JBA's? They're (JBA) doing a recall on arms/bj's sold before 3/15/18, I believe, due to the clear powder coating peeling off and allowing them to rust. They use Cerakote now and they look sweet. The recall swap is free once you return the old bj's to them.
  19. Apr 8, 2018 at 8:50 AM
    #109
    I just checked out those new JBA's. Nice. I'm thinking about getting the SPC's but those JBA's are in my budget range....Almost the same price point.
  20. Apr 8, 2018 at 8:56 AM
    #110
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I say go with the JBA's unless you really want the adjustability of the SPC's. The JBA's are beefier, perform well, look awesome, and good customer service. The ball joints are a breeze to swap out.
  21. Apr 8, 2018 at 9:01 AM
    #111
    Tough choice. ToyTec is minutes away from me and they have the SPC's in stock and do alignments now. Need to find out if the GM at ToyTec can find out if they can get JBA's...
  22. Apr 8, 2018 at 9:03 AM
    #112
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Ah yea, if you're right next to Toytec, I'm sure they have lots of experience with the SPC's.
  23. Apr 8, 2018 at 9:04 AM
    #113
    Oh yeah... SPC's are made a few miles further north in Longmont, CO..:thumbsup:
    UTTundra[QUOTED] likes this.
  24. Apr 8, 2018 at 9:52 AM
    #114
    Tundra4us
    Tundra4us New Member
    "D"
    Bannock452, remove and sell them. I too made the same mistake. I tried running them W/ BDS 4.5" lift and it was waaaayyy too much caster. I have since installed Icons billet with hiem end links. Its a lot better but not 100%. Problem now is trying to find someone that can align the truck with them.... I have asked Icon if they can recommend someone that is familiar with them and they said SoCal Super Trucks does all of there alignments. So, I may be taking a road trip( I am in NorCal) for a simple alignment.
  25. Apr 8, 2018 at 10:20 AM
    #115
    @T-Rex266.............You know I'm getting the SPC's soon. Can ToyTec get the JBA's by chance???
  26. Apr 8, 2018 at 10:42 AM
    #116
    Bannock452
    Brandon
    Murrieta, CA
    Thanks for the input brotha! Definitely think I’m going to remove them and go back to stock at least for now. No since in waisting my time and effort if they do not work for anyone!
    Sorry to hear about your alignment but guess you could make a fun weekend out of it if you wanted!
  27. Apr 8, 2018 at 11:46 AM
    #117
    250rdave
    David
    surprise az
    No I did notice a tiny spot where there was small blemish in the powder coat looked like the arm was nicked but I noticed this when I was at the local powder coater. I want the arms to be close to the same color as my king spring color. If its a powder coat problem I don't think Marlin is going to exchange a set that has had a color change. I did order mine just before the 15 th.
  28. Apr 8, 2018 at 11:48 AM
    #118
    OBXTundra
    OBXTundra Member
    Southeast USA
    I do have rust starting on both of the balljoints, clearcoat started flaking about a month ago. I am in contact with Marlin now. Apparently they're taking care of this issue. Thanks for the heads up.
  29. Apr 8, 2018 at 11:53 AM
    #119
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Oh did you have yours re-coated? Got any pics? It’s actually the ball joint housing itself (the part that’s not colored from JBA) that has the issue. Takes a few months to show up. But if you just bought them you might not have an issue. Maybe check with JBA and see if you got the Cerakote.
  30. Apr 8, 2018 at 11:54 AM
    #120
    UTTundra
    UTTundra New Member
    Lou
    Utah
    No problem. I’m looking forward to swapping in the new ones this week. My originals look pretty beat up.
    OBXTundra[QUOTED] likes this.
