Engine swap
Discussion in '2.5 Gen Tundras (2014-2021)' started by Thomaskwood, Dec 2, 2022.
  1. Jan 30, 2023 at 1:25 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    To add to this, I bought my Salvaged JK from copart in Denver, but you are only allowed to bid on certain vehicle types here. Others you have to have a license or broker.
  2. Jan 30, 2023 at 4:42 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Check the knock sensor wiring harness under the intake plenum. Mice like to get in there and chew on it. You'll need the intake gasket if you take it off to check the harness.
    Also, change your thermostat, coolant and sparkplugs while you're at it. And get some red locktite for the torque converter bolts.
