Eibach 3/1
Discussion in 'Suspension' started by Stroke250, Apr 3, 2018.
  1. Jun 15, 2019 at 6:26 PM
    #121
    DUGIE FRESH
    DUGIE FRESH New Member
    Ventura
    2016 Crewmax TRD 4WD SR5 5.7 White
    Rough Country floor mats, lumin X fog lights, amber fog light bulbs, LED headlights, 3” Eibach front lift, 35” Hercules Terra Trac AT2 tires, 1.5” front wheel spacers, Line X Bedliner...
    I have 4 neighbors with Tundras so I thought you might be serious.
    2chains likes this.
  2. Jun 15, 2019 at 6:29 PM
    #122
    Amnesiac
    Amnesiac When I am king, you will be first against the wall
    PDX
    2019 Superwhite TRD Sport
    Same here in Portland, so glad we aren’t wasting our already stretched resources enforcing such a worthless cause. But that’s a discussion for a different thread!
    DUGIE FRESH[QUOTED] likes this.
  3. Jun 15, 2019 at 6:52 PM
    #123
    DUGIE FRESH
    Ventura
    798AB921-BD39-4525-B53D-8724EE6F8197.jpg 798AB921-BD39-4525-B53D-8724EE6F8197.jpg Got stickers?
  4. Jun 15, 2019 at 6:53 PM
    #124
    DUGIE FRESH
    Ventura
    I’m originally from Eugene Oregonian here!
    Amnesiac[QUOTED] likes this.
  5. Jun 15, 2019 at 7:27 PM
    #125
    Amnesiac
    PDX
    Nice! I lived there for many years while I attended U of O. Love Eugene, minus the allergies.
    GATORthaBEAST likes this.
  6. Jun 15, 2019 at 7:32 PM
    #126
    DUGIE FRESH
    Ventura
    Oh dude hay fever yep, I used to get steroid shots yearly for that shit
  7. Jun 15, 2019 at 7:33 PM
    #127
    DUGIE FRESH
    Ventura
    And the hippies
  8. Jun 17, 2019 at 10:45 AM
    #128
    DUGIE FRESH
    Ventura
    [4A42C870-ADC4-4B52-8800-0407E6D0606C.jpg 022E7180-7D54-4C38-B3E1-984D9270C5E0.jpg
    Couple of before and after lift heights, not quite 3” but close enough for my needs and truck is perfectly level front to rear, I did nothing to the rear and for now plan on leaving it this way, going to stick with the stock wheels, just go with larger tires, 35” if I can or 33”
    Stroke250[OP] likes this.
  9. Jun 18, 2019 at 9:04 PM
    #129
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    You guys are too forgiving when it comes to not getting what's advertised. Companies need to be held accountable for the products they sell. I'll never buy from Toytec again...fool me once.
    TuFerLife likes this.
  10. Sep 25, 2019 at 2:02 PM
    #130
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    Just order this ToyTec /Eibach kit for my 2014 tundra. after reading all the post i made my mind. @Stroke250 thanks for the picture u posted up. Should be here next week going to have the shop do it before i mess it up( and i dont have the tools to do it)
  11. Sep 25, 2019 at 2:07 PM
    #131
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Man.. I'm sorry, but that tape measure is all kinds of f*cked up!
  12. Sep 25, 2019 at 2:30 PM
    #132
    DUGIE FRESH
    Ventura
    You’ll be happy with it. It sits perfectly level with the rear. I did absolutely nothing in the rear, completely stock, I’m running true 35 x 12.50 tires, no issues
  13. Sep 25, 2019 at 2:35 PM
    #133
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    @DUGIE FRESH I order the 2" Block kit for the back. I pull a RV so i just decided to get it. If it looks to Jack Up from the rear i will remove it better. It was recommended, lets see how it look. Will updated next week
  14. Sep 25, 2019 at 2:44 PM
    #134
    Stroke250
    Stroke250 [OP] New Member
    Todd
    Idaho
    2023 Ford F-350
    You will love it!
  15. Sep 25, 2019 at 2:44 PM
    #135
    DUGIE FRESH
    Ventura
    Yeah I pulled a small pop up trailer last weekend and it sagged maybe a 1/2” if that.
    yoshi82[QUOTED] likes this.
  16. Sep 25, 2019 at 2:55 PM
    #136
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    what size tire fit? or Whatz the biggest i can go without cutting nothing or taking the mudd flaps off? Someone had 33 x 12.50 x 20 and it looks mean. This is the next updated after i do the lift
  17. Sep 25, 2019 at 9:16 PM
    #137
    DUGIE FRESH
    Ventura
    If you look at “35’s on 18” rims” forum I posted all the trim work done to get the 35”s not to rub. It was very minimal, used a die grinder and got about 3” out of the way. It barely rubbed to begin with, I just wanted plenty of room.
  18. Sep 25, 2019 at 9:22 PM
    #138
    DUGIE FRESH
    Ventura
  19. Sep 25, 2019 at 9:24 PM
    #139
    DUGIE FRESH
    Ventura
    This is it on 35” tires, Hercules AT2, great tires. I did put 1.5” front spacers on to get the tire away from the upper control arms or (UCA)
  20. Sep 25, 2019 at 9:26 PM
    #140
    DUGIE FRESH
    Ventura
    Sorry the title is “fit and trim for 35” tires on 18” stock rims”
  21. Sep 25, 2019 at 9:29 PM
    #141
    DUGIE FRESH
    Ventura
    I get a lot of compliments because I kept the stock wheels (which I think look good) and wrapped a 35 on them. I think the stance is probably 1/2” higher than the TRD PRO and I’m running larger diameter tires I believe. I just wanted to keep it clean, no ridiculous 6” lift, no side steps for me, just clean, level and simple. I do plan on off roading it, but not hammering on it, been there, broke that. I’m stoked. Might do an exhaust and be done with it.
    yoshi82 likes this.
  22. Oct 3, 2019 at 8:31 PM
    #142
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    DUGIE FRESH likes this.
  23. Oct 3, 2019 at 8:34 PM
    #143
    DUGIE FRESH
    Ventura
    There you go! Start modifying it
    what lift did you go with?
  24. Oct 3, 2019 at 8:35 PM
    #144
    DUGIE FRESH
    Ventura
    Looks good
  25. Oct 3, 2019 at 8:35 PM
    #145
    DUGIE FRESH
    Ventura
    So much better than stock stance right?
  26. Oct 3, 2019 at 8:36 PM
    #146
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    ToyTech/ Eibach Boss 3 front and 2.5 block on rear
  27. Oct 3, 2019 at 8:39 PM
    #147
    DUGIE FRESH
    Ventura
    Nice
  28. Oct 3, 2019 at 8:41 PM
    #148
    DUGIE FRESH
    Ventura
    I notice all the Tundras our on the road now, I look to see if they are properly lifted, have a spacer or are stock
    yoshi82 likes this.
  29. Oct 3, 2019 at 8:42 PM
    #149
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    Definitely looks better than stock. I’m going to stay with the original factory rims 20, getting them painted GunMetal Gray and maybe for 34 or 35.
  30. Oct 3, 2019 at 8:48 PM
    #150
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    @DUGIE FRESH hey u got 35 on ur Tundra, But they are 35 by what?
    I believe u said 18, looking for the Forum u posted about Fit and Trim 35, can’t find it
    Rica25 likes this.
