ECU Tuning
Discussion in 'Performance and Tuning' started by TruckyTruck, Jan 18, 2017.
  1. Jan 19, 2017 at 8:00 PM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    Thats a bad mf'er
    GNTundra likes this.
  2. Jan 19, 2017 at 8:15 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    You and I have been on the same page about literally everything, but I have to disagree on this one. Not all tuning has to be done for power. If HP Tuners type software existed for Tundra ECMs, I bet you I could get the truck to run a handful more mpgs consistently and still have good power. Then create a separate map completely when the ECM sees the Tow/Haul signal for power and holding gears while towing. Remember, lean = more power and more fuel efficient, but it also creates NOX and high combustion chamber temps which big brother doesn't like.
    I put down 300lb ft of torque to the tires starting at 2300rpm and hold it until 5700rpm on my jeep and it's still fat, somewhere in the 12:1, but during cruising it will do 18mpgs with one ton axles and 37s. The tundra could significantly benefit from a more refined VE map. I'd be curious to see how many cells are actually available to see how refined the tune could actually be. Just pipe dreams though....
    Even with all the access I have through work, I still can't do what this guy claims to have done.
    WatTundra and ColoradoTJ[QUOTED] like this.
  3. Jan 19, 2017 at 8:16 PM
    Vizsla
    Vizsla 2 = 2.5
    Email tunes can be pretty good, depends on the tuner. Most people can't and won't get a live tune done, and a tune from a tuner who is spending time building a database of the different calibrations SHOULD be much improved over a canned tune(for us Bullydog). Building the database is important, but it is not like building tunes for every calibration, generally pick the best one, use it, and build the tune. Some calibrations may not play well with others so the custom tuner sorts this out, hence the need for the calibration database. The dyno is only a small part of tuning(mostly quantifying results), actual drivability is the goal, and those two don't always translate very well. My Dyno tunes where not driveable on the street, only for making a big number. It would be great to have more tuning options, hopefully this works out.
  4. Jan 19, 2017 at 8:23 PM
    I agree, not all tuning is for max HP/TQ. Drivability is another aspect to tuning.
  5. Jan 19, 2017 at 8:30 PM
    Vizsla
    Vizsla 2 = 2.5
    Here is proof, expensive proof... watch under the front. 511hp pull, email tune from one of our locals.
  6. Jan 19, 2017 at 8:43 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Giggidy
  7. Jan 19, 2017 at 8:45 PM
    Yep. To make 511 hp out of a PSD motor (7.3 or 6.0), the motor is coming out. I have driven a 490 hp 2000 F350 and it was pretty bad ass. He had a wad of cash in it as well.
    I'm on my phone, was that oil dropping out onto the ground?
  8. Jan 19, 2017 at 8:46 PM
    Oh, was that performance wise?
  9. Jan 19, 2017 at 8:46 PM
    TruckyTruck
    TruckyTruck [OP] Dumbest Username
    Gary
    Honestly, I would have been very happy with the 87 octane tune (yes, I know Luis) that Bullydog put out. I ran it until I realized my truck started thinking it was running ethanol and had to have Toyota flash it back to the stock program ending in 600 that solved those problems. No, I didn't have it on a dyno, but you could tell there was more low end tq. I was very happy with that and the changes made to the transmission. It made the truck feel responsive and not stock/lazy. Unfortunately, every call to them about incorporating the correct algorithm for ffv went unanswered.
    I'm hopeful, but just waiting to see.
  10. Jan 19, 2017 at 8:52 PM
    Vizsla
    Vizsla 2 = 2.5
    Yes, that truck made 600hp a little$$$ later. One of my nastier creations, so much fun. Used to work beside the White House, it was not the wisest choice for that commute, but it was fun, and I have some indispensable memories!
    Oh it was coolant, every year new heads, gaskets etc.. 6.leaker...
  11. Jan 19, 2017 at 8:56 PM
    So what was dropping out the front?
  12. Jan 20, 2017 at 1:41 AM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    Hmm, I'm going to send my ECU to Russia. I'm quite certain they can crack the codes. :thumbsup: :oldglory:
    Mountun Goat likes this.
  13. Feb 1, 2017 at 7:22 PM
    bstundra
    bstundra New Member
    James
    Eastern Long Island NY
    2008 Blue Streak metalic DC tundra
    3 inch rough country lift, lift uniball ball joint UCA's 35x12.5's, ultra maverick 18x9 , 17% tint, Jensen v7022 with factory style back up camera in tailgate handle, led interior lights, led plate lights, led fog lights, magnaflow catback
    I just bought a bully dog gt for my truck, I really don't need the tunes though its nice. I want to be able to adjust tire size, watch parameters, and turnoff my damn seatbelt alarm I wear my seatbelt anyways before anyone says anything. cant beat the $175 I paid for it used!
  14. Feb 1, 2017 at 7:31 PM
    bstundra
    bstundra New Member
    James
    I know the GT does meaning speedometer/odometer and mpg calibration
  15. Feb 1, 2017 at 7:40 PM
    bstundra
    bstundra New Member
    James
    throgs neck bridge?
  16. Feb 1, 2017 at 7:43 PM
    bstundra
    bstundra New Member
    James
    yes I do not very often but have many times
  17. Apr 1, 2019 at 3:21 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Sooooo.... how did this all turn out?
  18. Apr 24, 2019 at 7:59 PM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    Check out OV Tuning on FB. They have released a few videos
    KevinK[QUOTED] and Mountun Goat like this.
  19. Apr 24, 2019 at 9:18 PM
    #49
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I blew my ford ecoboost up with a mail tune haha.
  20. Apr 24, 2019 at 9:20 PM
    #50
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I am interested in this though. Just the fact that someone new is tuning for us is nice to see.
    the_midwesterner and Fspmdt like this.
  21. Apr 25, 2019 at 6:35 AM
    #51
    OVTune
    OVTune New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Edit* this post is way older than I realized. sorry
  22. May 3, 2019 at 8:44 PM
    #52
    KevinK
    Tundras to Sedona
    No worries.
    I necro’d it recently looking for info. Found your thread. :thumbsup:
