Ebay Aftermarket TRD Pro Grills with surround
Discussion in '2.5 Gen Tundras (2014-2021)' started by cotten, Jun 12, 2018.
  1. Jun 14, 2019 at 8:36 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Your 2019 DCL will swap easy with another grille that uses the sensor eg; 2019 Pro grille, however from the threads I read, swapping it with a 2014-2017 TRD Pro grille or any 3rd party that has no sensor hardware supports requires extra parts and might be tricky. Maybe someone who's done it can chime in.
  2. Jun 16, 2019 at 8:56 AM
    Helipilot2
    Helipilot2 New Member
    2019 Cement Limited CrewMax 4x4
    Sorry I am new here and trying to catch up on all this. I just bought a 2019 Limited and ordered parts from Sparks. One of those being a TRD Pro grille, bulge, grille surround, and sensor cover. Being that the sensor is located so much lower on the TRD grille than all the others will it create issues with my TSS? Do I need any other parts for the install or should it all go right on? Parts are currently off at paint being matched along with door handles and mirror caps, I hate chrome lol
  3. Jun 16, 2019 at 9:06 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Welcome!
    They are referring to the old 2014-2017 Pro Grille, but read post 14 which would be applicable to the 2019 Pro Grille
    https://www.tundras.com/threads/2018-tss-with-trd-pro-grille.21120/
    Helipilot2[QUOTED] likes this.
  4. Jun 16, 2019 at 9:16 AM
    Helipilot2
    Hmm so it seems like I shouldn't have any issues as it will still be centered left and right, it will just sit lower in the grille. Worst case scenario I guess they re-calibrate it at the dealer. Stupid sensors make everything difficult, wish there was a way to shut it off entirely without a code being thrown on your dash.
  5. Feb 6, 2020 at 4:29 AM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
  6. Feb 6, 2020 at 5:45 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    If your surround is chrome, combining both will literally make the latest TRD Pro Grille. The 2nd one is the insert, they’re finally selling them on eBay. And it comes with a sensor cover!
    I’m assuming the first one matches the Tundra basic black, not speckled one (forget the codes/names).
    Then all you need is the black hood bulge.
    Edit: I see you have a Platinum so you’re color matched already, all you need is the 2nd one, the clips are tricky but the middle is exchangeable. The first one won’t match your black.
  7. Feb 6, 2020 at 6:06 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    LED headlights, Rigid fogs, grille
    TheBeast likes this.
  8. Feb 6, 2020 at 6:22 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    Is that an eBay grill? It looks great from what’s visible in the picture
    JoshuaA[QUOTED] likes this.
  9. Feb 6, 2020 at 7:02 AM
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Look good! Want to change out mine too.
  10. Feb 6, 2020 at 8:19 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Thanks! The black surround is eBay, I took the older version TRD Pro insert that was there out, the new honeycomb insert is pulled from a new 2019 OEM TRD Pro grille (I have a speckled black surround unused) and the sensor cover is 3rd party. That’s how I know the black doesn’t match.
  11. Feb 6, 2020 at 8:24 AM
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    is it hard to change out the old insert to a new TRD pro insert?
  12. Feb 6, 2020 at 8:27 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    I got a 2019 or 2020 trd pro grill for my truck in Ontario...its not cheap, and its not 202 black...but it looks great :) I'm going to see how much the attitude black contrasts with my regular black before I decide if I'm going to paint the grill surround. I ended up painting my own bulge and making my own garnish. Good quality paint to do my bulge cost me about 100 bucks canadian.
  13. Feb 6, 2020 at 8:32 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    There’s a post here somewhere, it’s not hard, iirc it’s pressured half moon clips and maybe a couple of screws, I may be wrong. Took me 10-15min, not long.
  14. Feb 6, 2020 at 8:33 AM
    Durania
    Durania New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
    Offaxis2015 likes this.
  15. Feb 6, 2020 at 8:40 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    The metallic flaking definitely makes it look different in the day, even when dim because of the street lights reflecting off it.
  16. Feb 6, 2020 at 8:41 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    crap. Well that’s fine...I have my original grill to put back on while I’m painting the surround 202 black :). My bulge turned out great
  17. Feb 6, 2020 at 8:42 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    It will be a lot easier to repaint a painted grill surround than a chrome bulge
  18. Feb 6, 2020 at 8:47 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    In theory yes, the risk is it’s an eBay part and more importantly those with TSS may need something else done (recalibration? OEM cover? can’t remember). You might want to read up on adapting TSS to 2019 TRD Pro grille, thread here somewhere.
  19. Feb 6, 2020 at 8:50 AM
    #49
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    FYI, this is exaclty the front end look I am going for on my truck :) I like your taste! did you have your bumper corners color matched or are they TRD or SR bumpers?
    #49
  20. Feb 6, 2020 at 8:51 AM
    #50
    Durania
    Durania New Member
    Crossville, TN
    Got ya. Thank you.
    #50
  21. Feb 6, 2020 at 9:18 AM
    #51
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Anyone know where I can get the 2019 TRD pro insert?
  22. Feb 6, 2020 at 9:23 AM
    #52
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Thanks, they are wrapped chrome. The square bezels are sold by Toyota. If you have chrome, get them painted properly, wish I did that. Wrap gets chipped and fades.
  23. Feb 6, 2020 at 9:57 AM
    #53
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    as has been mentioned, you have to get the whole grill. You can’t just get the insert.
  24. Feb 6, 2020 at 9:58 AM
    #54
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    Cool. Mine are currently protect-dipped (I think it’s a crappy tire product) and I’m happy for now, but was going to paint them eventually.
  25. Feb 6, 2020 at 10:40 AM
    #55
    spicychickentundie
    spicychickentundie New Member
    Danny
    SOMD
    2014 Barcelona Red Tundra SR5 CM 4x4
    TRD RSB
    Anyone get a Barcelona Red Ebay grille? Curious how good the color match is.
    #55
  26. Feb 6, 2020 at 10:48 AM
    #56
    TheBeast The Beach
    would be nice to have something similar for gen 2 Tundras :)
  27. Feb 8, 2020 at 3:08 PM
    #57
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I just got notified that ebay item reduced $30 ($270 now), item is located in Texas.
    Note the whole part including surround is $313+tx+ship
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-trd-pro-grille-040-super-white-531010c070a0
    https://parts.toyotaofcoolsprings.c...rd-pro-grille-218-attitude-black-531010c070c0
    https://parts.toyotaofcoolsprings.c...trd-pro-grille-magnetic-gray-1g3-531010c070b0
    If you live in the NE, BochToyotaSouth is less than Cool Springs including shipping (that's where I bought and shipped to Buffalo).
    #57
  28. Feb 8, 2020 at 7:02 PM
    #58
    Dadsrule
    Dadsrule New Member
    Jersey Shore
    2016 SR5 Tundra
    1G3 grill just posted on market place for any members in MD... wish i wasn't 4 hrs away
  29. Feb 10, 2020 at 5:24 AM
    #59
    spicychickentundie
    Danny
    SOMD
    TRD RSB
    Good price. Only like 30-40 min from me, but the wrong color :(
  30. Feb 10, 2020 at 5:26 AM
    #60
    browntundra77
    browntundra77 New Member
    Devon
    DMV
    2017 SBM Tundra Platinum CM
    wish i saw this before i overpaid for oem, haha
