Dual Battery Setups
Discussion in '2.5 Gen Tundras (2014-2021)' started by Delmarva, Aug 24, 2016.
  1. Jun 4, 2020 at 8:05 PM
    #61
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Do you have a write up on your system?
  2. Jun 5, 2020 at 7:45 AM
    #62
    cooper4x4
    cooper4x4 New Member
    2016 Tundra SR5
    I'm definitely going to find a way to insulate that positive terminal by the core support.
  3. Jun 5, 2020 at 7:57 AM
    #63
    Vizsla
    Vizsla 2 = 2.5
    I don’t know right now, and I’m not switching anytime soon. Have a ridiculous amount of time and money into the truck, need to just enjoy it for awhile.
    I don’t, but it’s really simple. 2 MRBF fuses one at each battery, 150 amp Battery Doctor smart isolator, and XS Power 750 deep cycle battery.
    Porschetech29[QUOTED] likes this.
  4. Jun 5, 2020 at 8:11 AM
    #64
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    where did it touch? i am considering switching to their tray because the one i have is even tighter. it's starting to make me nervous.
  5. Jun 5, 2020 at 8:37 AM
    #65
    cooper4x4
    2016 Tundra SR5
    I'm guess right here at the core support
    Sunnier likes this.
  6. Jun 5, 2020 at 11:23 AM
    #66
    Theonlyway
    Theonlyway New Member
    User
    Right at the front positive terminal. Sucks because the system is great but I wouldn’t run in a tundra for this reason. Killed a $300 battery and would have to constantly jump the battery to start my truck. I’ve been really hesitant on selling it because I don’t want anyone else to run into this issue.
    Also, this was on a fire road with some bumps, not true off roading
    Sunnier and smslavin[QUOTED] like this.
  7. Jun 5, 2020 at 12:03 PM
    #67
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    hmm.
    all i would be doing is the tray. i have all the other required pieces (ml-acr, etc). my only reasoning for wanting to do this tray is that my current one houses the batteries vertically with the terminals up against the fuse box. it's too tight and i've had modify quite a few things in order to make it fit. i zap myself just about every time i have to work on it.
  8. Jun 5, 2020 at 12:16 PM
    #68
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Here’s my setup. I used SDHQ’s basic idea and windshield washer fluid relocation kit, a 3rd gen intake and an Artec battery tray. I basically sourced the rest of the parts through Amazon.
    JayMax03, Occidentalis, Mixb7 and 7 others like this.
  9. Jun 5, 2020 at 12:27 PM
    #69
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I need this in my life.
  10. Jun 5, 2020 at 6:40 PM
    #70
    Damie Street
    Edsel
    South Carolina
  11. Jun 5, 2020 at 6:40 PM
    #71
    Damie Street
    Edsel
    South Carolina
    Thanks for the info. I feel I could do my own setup now.
    jc153[QUOTED] likes this.
  12. Jun 5, 2020 at 7:00 PM
    #72
    Vizsla
    Vizsla 2 = 2.5
    Very nice John I’m a little jealous :jellydance:
    This is soo stupid imo.. No way the sheet metal structure can hold that, the airbag sensor in front of that hates everyone that could or would bother with such foolishness. Complete wrong place for dual batteries and all around bad idea. Looks like monkeys butt also lol.
  13. Jun 6, 2020 at 9:15 AM
    #73
    Theonlyway
    User
    Genesis’s response was for my to cut the metal off my truck lol. F that
  14. Mar 11, 2021 at 7:43 PM
    #74
    Mixb7
    Mixb7 New Member
    Napa Valley California
    2010 4x4 Tundra Platinum Crew Cab
    Bilsteins all around,110v and 12v in the bed, Rocklights, Dual Batteries, Trailer Brake Controller Mod, Lots of DIY Mods
    Man this is nice work! Did you have to move the power steering reservoir or did this fit right in there? Also is this a group 34 battery? My 2010 CM looks like it wouldn’t fit one.
  15. Mar 11, 2021 at 8:32 PM
    #75
    Mixb7
    Mixb7 New Member
    This is a really nice set up! What was the actual Artec battery tray you used? It looks like there is a tab for the PS reservoir. Did you add that or did that come that way? Also what group battery did you use? Sorry for all the questions but this is exactly what I am wanting to do. Thanks
  16. Mar 11, 2021 at 8:48 PM
    #76
    typerlegend
    typerlegend Will work for Mods
    Will
    SoCal, North Orange County
    2020 Super White Tundra SR5 TRD Sport
    Kicker sound system. Kings 2.5 Adjustables Total Chaos UCA Total Chaos 3/4' Rear Shackles 17' Methods 703s KO2 35/12.5/17 Baja Design Amber Squadron Sport Fogs
    How do you know when you would need a dual battery setup?
  17. Mar 11, 2021 at 11:01 PM
    #77
    jc153
    San Diego
    Thanks for the compliment.
    This is the battery tray I used. https://www.artecindustries.com/oypc1500 It’s a group 34 battery.
    I made The PS fluid reservoir tab out of flat bar and counter sunk it to the battery tray. I did a couple trial fits to get the length correct.
    I also had to add a piece of metal tube to the PS return hose to lengthen it slightly for the new reservoir location.
  18. Mar 12, 2021 at 9:05 AM
    #78
    Mixb7
    Mixb7 New Member
    John, thank you for the info. That definitely looks like something I can handle. I'm only nervous about the PS extension since I don't want to screw that up. I am so glad I saw your post. I have my wires for a winch and 110v already run into the engine compartment from the bed. Was just waiting for some more ideas from guys for the battery install. I knew I could do it, but I am visual so I wanted to see it done first before I tackled it. Thanks again.
  19. Mar 12, 2021 at 11:07 AM
    #79
    jc153
    San Diego
    I’m glad someone got something out of the post.
    The hose extension was easy. I just used a sleeve and two hose clamps. It only needs to be about an inch longer. You just need to cut the return hose in the correct spot to avoid the pulley. Once you start test fitting it you’ll see where you need to cut it and how to orient the clamps to clear everything.
  20. Mar 12, 2021 at 1:32 PM
    #80
    Mixb7
    Mixb7 New Member
    Thanks John for the heads up.
    jc153 likes this.
  21. Mar 13, 2021 at 5:04 AM
    #81
    Mixb7
    Mixb7 New Member
    John are you using a group 35 battery for your main? Hard to tell in the pic. I have a Platinum CM so I have the 27F over there. I really like that size, but I’ve read to keep the same size on dual battery systems. I see your using the Blue Sea isolator like I would so I assumed that using an isolator would negate needing the same size on both sides. Your thoughts?
  22. Mar 13, 2021 at 6:06 AM
    #82
    jc153
    San Diego
    Hey Mike, I have the same battery on both sides.
    It’s not required but I would stick with the same battery for each side if possible and buy them as close together as you can. I knew I was going with this setup eventually so when my main battery died I started the process and bought the first PC1500. I think I bought the second one a couple months later as I was putting parts together for the dual battery setup.
    The Blue Sea ML-ACR has been great and works seamlessly connecting and disconnecting the batteries as voltage changes.
  23. Mar 13, 2021 at 7:41 AM
    #83
    Mixb7
    Mixb7 New Member
    Ok John that looks like what I will do then. I just wish I could fit an 27F on that side! Glad to hear about the Blue Sea. I bought a different isolator early on in planning stages, shouldn’t have but I was too stupid excited to get going and after reading and studying more the Blue Sea looks the only way to go. Buddy I appreciate all the help you’ve given. Hopefully I won’t have to bug you anymore.
    jc153 likes this.
  24. Mar 13, 2021 at 8:03 AM
    #84
    jc153
    San Diego
    No worries Mike, feel free to reach out if you have any other questions.
    Mixb7[QUOTED] likes this.
  25. Apr 12, 2021 at 7:52 AM
    #85
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    SpeshulED likes this.
  26. Feb 5, 2023 at 3:44 AM
    #86
    FrozenTundra83
    FrozenTundra83 New Member
    @Theonlyway I know this is old, but what mount was this?
