Dual Battery Setups
Discussion in '2.5 Gen Tundras (2014-2021)' started by Delmarva, Aug 24, 2016.
  1. Aug 24, 2016 at 12:27 PM
    Delmarva
    Delmarva [OP] Former Mayor
    Tucson, AZ
    12 TRD RW
    Hey folks -
    My company owns 4 2105 Tundras and have 3 more on the way. We'll be adding a few extras to upfit them for the work they do. Our customer has asked for the 3 new ones to have a dual battery setup in addition to a few other things. (It should be noted that the other 4 already have dual battery setups but the customer's upfitting shop did custom installs).
    Looking for a kit that I don't have to piece together that's good quality. Haven't dealt with purchasing or installing one before so wanted to get some opinions from you all.
  2. Mar 9, 2017 at 2:36 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Did you ever figure this out or find a better place to mount a 2nd battery?
  3. Mar 9, 2017 at 2:42 PM
    Stig
    Stig New Member
  4. Mar 9, 2017 at 4:28 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Someone needs to seriously make a tray for a second battery in the engine bay for these trucks. Who has a 3D printer?
    Major adventure and pearlpower like this.
  5. Mar 9, 2017 at 11:57 PM
    Spvrtan
    Kris
    San Diego, CA
    The only spot in the engine bay would be where the windshield wiper and power steering fluid containers are.. so a kit would need to relocate those, too.
    Major adventure likes this.
  6. Mar 10, 2017 at 1:06 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    If it were me I would have a box added under the bed near the rear axle clear of obstruction. My GMC had a 2ndary battery box mount under the hood. I wish Toyota did this.
    pearlpower likes this.
  7. Mar 10, 2017 at 1:13 AM
    Spvrtan
    Kris
    San Diego, CA
    Yea, that's what I'd prefer to do, too, since it helps -- albeit very slightly -- keep the center of gravity low(er) but I'd need it to be waterproof.
  8. May 11, 2017 at 1:16 PM
    kurtwp
    kurtwp What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
  9. Jan 14, 2018 at 12:29 PM
    Theonlyway
    Theonlyway New Member
    User
    Wanted to bump this. Any one have a dual battery setup? Would like to start working on this
  10. Jan 17, 2018 at 3:10 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    haven't started on mine yet. trying to figure out a decent location. not too excited about putting it under the truck. maybe in the bed but i have some doodling to do. either way, i'll be using the ibs controller.
    Theonlyway[QUOTED] likes this.
  11. Jan 17, 2018 at 3:12 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Laat dual battery setup on a tundra I saw was two Optimas stacked sideways on each other in the factory battery holding area
    4x4WarriorOfRocks likes this.
  12. Jan 17, 2018 at 4:54 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Thinking about doing the same to run a inverter if needed. Was think of isolating two batters in my tool box in the bed. have the room for it all but not sure if the stock alternator will keep up with everything. To much research to do along with to many mod's to figure out and not nearly enough time or money.:(:(:(:(:(:(
    aperezsh and NewImprovedRon like this.
  13. Jan 17, 2018 at 4:59 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    A company that buys quality work trucks.
    Not very common..
    Cobshop, TRD-tv and zcarpenter92 like this.
  14. Jan 17, 2018 at 5:05 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    you'll probably want to avoid the inverter. puts more strain on the system than it's worth. once i get mine figured out, i'll share all the info.
    NewImprovedRon likes this.
  15. Jan 17, 2018 at 6:57 PM
    Theonlyway
    User
    I have two of the leitner gear pods and was considering one in there but, I’m going to have a shop look at the truck and see if they can think of a better spot.
  16. Jan 17, 2018 at 7:02 PM
    Theonlyway
    User
  17. Jan 19, 2018 at 8:49 AM
    SoCalDave
    SoCalDave New Member
    Dave
    2016 DC 4x4
    We'll be releasing it soon!
    wjtvet and nk1794 like this.
  18. Jan 19, 2018 at 5:14 PM
    Theonlyway
    User
    Do you have an estimated time frame?
  19. Jan 26, 2018 at 11:55 AM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    wjtvet, d0zer, gosolo and 2 others like this.
  20. Jan 26, 2018 at 11:59 AM
    Theonlyway
    User
    Much thanks. Look forward to seeing it
  21. Jan 26, 2018 at 2:45 PM
    n2deep
    n2deep Pavement Princess
    Kevin our setup with the Lipo is a little different because the batteries are small and only 13lbs so easy to stuff in smaller spots. Mine is located behind the rear seats in my DC.
    KevinK likes this.
  22. Jan 26, 2018 at 2:52 PM
    Sunnier
    Sunny
    San Diego, CA
  23. Jan 26, 2018 at 2:54 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Looking forward to seeing this
  24. Jan 26, 2018 at 2:58 PM
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    You going to run another AGM, or something that will last a little longer in AZ?
  25. Jan 26, 2018 at 3:01 PM
    KevinK
    Tundras to Sedona
    Agreed - the LiPo is the way to go in my opinion after running it for a year. The convenience is amazing.
    We decided on LiPo @d0zer
    Post is up
    https://www.tundras.com/threads/kom...h-speed-overland-rig.16989/page-3#post-491077
  26. Feb 14, 2018 at 10:50 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    My dual bat set up is deff not a commercial setup, all custom.
    But for argument sake here are some pics... oh and the second bat is in a bat box under the bed.
  27. Jun 20, 2018 at 9:46 PM
    Tundrado
    Tundrado New Member
    2018 dblcab
    Is this still a thing? Looking for an under hood dual tray...
  28. Jun 20, 2018 at 10:48 PM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    I had dual batteries in my Tacoma before I sold it. I’m pretty sure the kit was by “Painless”
  29. Jun 21, 2018 at 8:10 AM
    Stig
    Stig New Member
    Dual battery systems are nice but they aren't always needed. If you're just running a fridge and a few accesories, as long as you drive every other day you will have no problem. Just get a single 27f agm battery and carry a jump pack for insurance. 100 or 200 watts of solar wouldn't be a bad idea in this case. Worry free.
    If I were to camp in the same spot without driving for a few days I'd definitely go duals plus solar plus jump pack.
    Just wanted to throw that out there for those wanting to start running a fridge.
  30. Jun 21, 2018 at 9:26 AM
    RoninPro
    RoninPro Abecedarian BASTRD
    East Bay
    17 CM TRD Pro
