Drop bracket mid travel
Discussion in 'Suspension' started by Basemodel07, Sep 4, 2018.
  1. Nov 26, 2018 at 5:50 AM
    #751
    Lindenwood
    Lindenwood New Member
    2002 and 2016 4Runners, Selling 2002 for a Tundra
    2002 4Runner: Custom full rmor, 33 MTs, Fridge, drawers, OBA, flat paint (for easy touch-ups). 2016 4Runner TRDP: Wheels, 32 ATs, 2" Lift F/R
    I have done a lot of reading on this subject, but it has been tough to find the level of specificity I'm seeking. Could you speak to those limits?
    More pointedly...
    1) What parts broke or didn't perform properly (i.e. including "death wobble," suspension misalignments, or whatever)?
    2) Have those parts been upgraded on recent versions to prevent this? Or, perhaps, did you make any modifications to fix these issues (besides removing the kit :p )?
    3) How did you break, damage, or otherwise find the limits of those parts? Please be specific if it was whoops, jumps or anything that could be described by us mortals as "prerunning" :) .
    More hypothetically (or perhaps in the original spirit of this thread)...
    Consider a BDS 7" kit, with coilovers set to ~7" of total lift (i.e. establishing the same static LCA angle as a non-bracket truck lifted 3"), coachbuilder OTRs to correct steering angle issues, and TC UCAs to allow further droop. This technically becomes a MT system (~12"+ inches of travel), correct? Big picture, the only functional differences are that the frame and bumpers are now 3-4" higher off the ground, and one faces a likely decrease in durability (at the crossmember) against hard hits?
    @osidepunker and @n2deep and @M C M
    for good measure ;)
  2. Nov 26, 2018 at 6:07 AM
    #752
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
  3. Nov 26, 2018 at 9:11 AM
    #753
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
  4. Nov 26, 2018 at 12:42 PM
    #754
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    After wheeling with Bruce a good amount, I'd assume the limits he mentions are speed related. He's noticeably faster now than he was on his bracket, but that's to be expected anytime you go from MT to LT.
    Just from wheeling with a wide variety of Tundras, I'd say for outright speed through any terrain, slowest to fastest would be bracket, MT, LT.
    Your durability at the crossmember is one place to consider a weak point, but that could possibly be counteracted with links from the crossmember to the frame (at the cost of added weight).
    Another durability point to consider is the longer spindle. Most of us that run hard on MT and LT add spindle gussets to strengthen the stock spindles - longer spindles will be that much more prone to lateral forces on the tire. Possibly rectified with large gussets, but again at the expense of weight.
    Reading back through what I wrote, I don't think I answered your question per se, since Bruce didn't actually run the bracket to failure - I think it was a comfort and confidence decision. @papasmurf ?
    Sunnier, 831Tun, GiantsFanDan and 2 others like this.
  5. Nov 26, 2018 at 1:32 PM
    #755
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    So yeah... basically kevins got it. I never pushed the BDS kit to full failure. The two main issues with BDS is relating to the spindles. the spindles are weaker than stock due to being ductile iron (also very heavy). So in relation to adding gussets thats very difficult to weld onto ductile iron. it can be done, but is very complicated. Secondly the steering angles and tie rod connecting points. It slightly modifies the steering angles which adds excess stress on the steering rack.
    so yes i go much harder and faster now on LT but as to be expected.
    as far as what broke. i had a minor fender bender on the freeway and had to dodge a car and rode up a jersey wall about halfway up and bent both spindles which is highly surprising. The other issue was i was probably getting small bends in the spindles offroad because after every trip id have to get an alignment because I was throwing off the camber and toe. which i since havent had problems with, switching to stock spindles reinforced.
    I had upgraded the tie rods to CB tie rods, didnt change much. Sadly the same issues as mentioned above still existed.
    As far as limits i cant say anything specific in relation to the whoops, high speed etc. what i will say is a bracket lift has its purpose, you really want to go hard, build MT or LT
    all depends on use, and driving style. Im not saying dont buy it. I actually have my gen2 BDS spindles and whole kit sitting on a shelf if you are interested.
    and yes a BDS kit with coilovers extended travel will be a MT on BDS. Also the UCA's are a good idea, get ones with heims though for extra adjustment abilities.
  6. Nov 26, 2018 at 2:47 PM
    #756
    Lindenwood
    Thank you both for the great info! I have never done any wheeling that wasn't in 4Low--4Hi was always for just getting through to the fun stuff :p . So, I am just trying to understand my options as they apply to the type of wheeling that I have always done (and am actually considering whether I'd be interested in the higher-speed stuff).
    Thanks again!
  7. Nov 27, 2018 at 5:33 PM
    #757
    KevinK
    Tundras to Sedona
    When we go find camp, I’m not usually happy unless 4lo is required to get there, so I totally understand your point about the 4lo stuff.
    But,
    0C051358-4F14-40DB-B6F4-0205E886CCB6.jpg 697A37F3-1E7E-4A63-BEAB-E15D8C8198DD.jpg
  8. Nov 28, 2018 at 5:47 PM
    #758
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Drop bracket mid travel... Reminds me of a T4R i saw with a fabtech drop bracket and TC LT kit. Looked cray cray.
  9. Nov 28, 2018 at 10:00 PM
    #759
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    would love to see pics of that! LOL
  10. Nov 28, 2018 at 11:12 PM
    #760
    Spvrtan
    Kris
    San Diego, CA
    Not a 4Runner but there's this..
    KevinK likes this.
  11. Nov 28, 2018 at 11:17 PM
    #761
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Well interesting...
    So that’s a thing
    Sunnier and KevinK like this.
  12. Nov 29, 2018 at 3:31 AM
    #762
    Lindenwood
    Whooda thunk???
  13. Nov 29, 2018 at 5:29 AM
    #763
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Don't forget about this DB/LT FJ....
    KevinK likes this.
  14. Nov 29, 2018 at 5:44 AM
    #764
    14burrito
    2014 SR5 CM 4x4 5.7
    Don't forget this taco from TTORA either....
    KevinK likes this.
  15. Nov 29, 2018 at 7:19 AM
    #765
    KevinK
    Tundras to Sedona
    I remember seeing her ask questions on tacomaworld about if this could work. As you’d expect, she definitely got a mixed bag of responses.
    I’d be interested in seeing how these do off road. Anyone have pics or video of these things in action?
    TexasTundra27 likes this.
  16. Nov 29, 2018 at 9:06 AM
    #766
    GravityGear
    Aurora, CO
    I didn't talk to the guy with the T4R DB LT combo, but it was beat. Not daily driver, unkept beat, but trail damage beat. Looked like he'd done the Hammers. So I guess either he goes hard, or the suspension sucks so much that it beats his truck. I wanted to wait for the guy to come back, but it was a big Toyota truck gathering and a very busy restaurant, so I really didn't know when he was coming back to his truck.
  17. Nov 29, 2018 at 10:52 AM
    #767
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    I think that one of your call-outs is a little too subjective.
    Are we talking:
    Or:
    :worthless:
  18. Nov 29, 2018 at 11:10 AM
    #768
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    thank god this thread is still going. i need the distraction.
  19. Jan 15, 2019 at 3:11 PM
    #769
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    and lets bring this back again! LOL
  20. Jan 15, 2019 at 3:15 PM
    #770
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
  21. Jan 15, 2019 at 3:18 PM
    #771
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
  22. Jan 15, 2019 at 3:20 PM
    #772
    Basemodel07
    Basemodel07 [OP] New Member
    Evan
    2007 rcsb base
    Front bumper Leveling kit
    serious question is it possible to get the same amount of wheel travel out of a drop bracket as a mid travel setup? obviously not a spacer drop bracket
    papasmurf likes this.
  23. Jan 15, 2019 at 3:22 PM
    #773
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    ummm maybe with a proper extended travel drop bracket coilover.... as well as CB tie rods to allow more free travel of the outer tie rod
  24. Jan 15, 2019 at 3:43 PM
    #774
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    i forgot you will also need aftermarket UCA's as well
  25. Jan 15, 2019 at 3:43 PM
    #775
    Basemodel07
    Evan
    2007 rcsb base
    hmm actual tech lol its been awhile. I haven't seen a chart or listing of different lifts, bracket or no bracket and there expected wheel travel gains or loss. long travel gets in the 17ish range in the front I want to say?
  26. Jan 15, 2019 at 3:44 PM
    #776
    Basemodel07
    Evan
    2007 rcsb base
    oh yes def upper ucas also
  27. Jan 15, 2019 at 3:44 PM
    #777
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    depends on a few factors but 16-17" for LT
  28. Jan 15, 2019 at 4:24 PM
    #778
    Basemodel07
    Evan
    2007 rcsb base
    that's pretty solid. I am really curious how much the old man emu gives you since I'm lookin at that kit while I'm fairly broke. I think my leveling kit hasn't helped my cvs or rack and pinion. so maybe ill have some numbers for that in the nearish future.
  29. Jan 15, 2019 at 8:17 PM
    #779
    lionix
  30. Jan 16, 2019 at 1:57 AM
    #780
    Lindenwood
    We decided on a full 30ft travel trailer, so I bought an F250 instead of a Tundra (I know :( ). But, I got an email notification for this thread haha.
    Anyways, it did actually occur to me today that a quality drop-bracket lift (i.e. a "drop-bracket mid travel" lift) has the exact same effect as lifting a solid front axle suspension. You don't gain clearance between the wheels, but if the clearance gained literally everywhere else had no benefit, nobody would bother.
    Of course, like a lot of things, it is still important to put things in context. Two different guys talking about being "hardcore offroaders" could have completely different situations in mind, and thus completely different priorities. One guy could be racing around over jumps and whoops, and genuinely need a low-slung truck with 800lb/in springs and 7 shocks on each corner, while the other guy really could need maximum breakover angles and the softest possible springs. And, they could both be correct.
    Sunnier likes this.
