Drop bracket mid travel
Discussion in 'Suspension' started by Basemodel07, Sep 4, 2018.
  1. Sep 13, 2018 at 7:53 AM
    #331
    M C M
    M C M New Member
    I recommend tightening the upper stem bushing until it bottoms up than back off a 1/4 turn. Also check the bolts on the deavers and verify they are all facing towards the center of the truck with the bolt head on the outside to help avoid the resi contacting the bolt.
    Tacotundra and dcsleeper408 like this.
  2. Sep 13, 2018 at 7:53 AM
    #332
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Got cha. I'll call ya if I see an issue.
  3. Sep 13, 2018 at 7:55 AM
    #333
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Testing was on the RR omegas
    831Tun and dcsleeper408 like this.
  4. Sep 13, 2018 at 7:57 AM
    #334
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It was on the non-bypasses. The bypasses is what hit the banjo bolt.
  5. Sep 13, 2018 at 7:57 AM
    #335
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I am running a different leaf pack, but I will keep that in mind as I get to install. Also gonna be putting in a custom u-bolt flip kit so I need to make sure I clear those as well..
    GodlessPro, 831Tun and joonbug like this.
  6. Sep 13, 2018 at 7:58 AM
    #336
    14burrito
    2014 SR5 CM 4x4 5.7
    Ah understood, thanks
  7. Sep 13, 2018 at 8:00 AM
    #337
    14burrito
    2014 SR5 CM 4x4 5.7
    Then make sure the leaf bolts don't wear through the sleeve on the parking brake cable
    831Tun likes this.
  8. Sep 13, 2018 at 8:00 AM
    #338
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yeah, I won't answer....:boink:
  9. Sep 13, 2018 at 8:01 AM
    #339
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    When I installed my ADS rears I double checked clearance and tightened enough for them not to rotate not ridiculously tight but tight enough. And I double check them every now and then. I dont off road as hard as other guys on here but I do use it offroad as much as I can.
  10. Sep 13, 2018 at 8:01 AM
    #340
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    nokia 3390 got face time right?
  11. Sep 13, 2018 at 8:06 AM
    #341
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    @831Tun are your leaf pack bolt head facing towards the wheel? are you having any clearance issues in that area?
    joonbug and 831Tun like this.
  12. Sep 13, 2018 at 8:09 AM
    #342
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yep, bolt head faces wheel and no issues there.
  13. Sep 13, 2018 at 8:10 AM
    #343
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    :thumbsup:
    joonbug likes this.
  14. Sep 13, 2018 at 8:26 AM
    #344
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    I had to flip mine around
    joonbug and dcsleeper408[QUOTED] like this.
  15. Sep 13, 2018 at 11:15 AM
    #345
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I'm fine with my 7" bracket lift for when I used the truck for off road and hunting, it's also saved my truck a few times. Now I wouldn't do it only because my hunting permit doesn't allow for taking the truck off the gravel or dirt roads and I have a YXZ for off roading. The Tundra is too damn big for what I like to do and the open diffs doesn't help either.
    zackbremer and papasmurf like this.
  16. Sep 13, 2018 at 11:21 AM
    #346
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    diffs can easily be locked... LOL just saying... :spending:
    dragos28 likes this.
  17. Sep 13, 2018 at 11:21 AM
    #347
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Warren doesn't have the nokia anymore, he upgraded last year.
  18. Sep 13, 2018 at 11:48 AM
    #348
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    That's the reason I locked my rear diff. It's still too big for where I like to go in a truck. We live in different climates and terrain so each vehicle setup is going to have it's benefits. Bracket lift suited my build at the time.
    papasmurf[QUOTED] likes this.
  19. Sep 13, 2018 at 12:23 PM
    #349
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    i get it, im not giving you shit.. totally understand just joshin ya
    831Tun and trayday[QUOTED] like this.
  20. Sep 13, 2018 at 12:33 PM
    #350
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    :cheers::thumbsup:
  21. Sep 13, 2018 at 1:02 PM
    #351
    I'm actually a little disappointed starting on around page 6. I'll be cleaning this up, and notify people.
    Then the thread will be opened up again and see how it goes.
    froggy78, 831Tun and dragos28 like this.
  22. Sep 13, 2018 at 1:02 PM
    #352
    Locked for review
  23. Sep 13, 2018 at 1:13 PM
    #353
    Bans are being issued here for some.
    froggy78, lionix and 831Tun like this.
  24. Sep 13, 2018 at 2:36 PM
    #354
  25. Sep 13, 2018 at 2:39 PM
    #355
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Thanks for being reasonable. We can get pretty opinionated, but it's only because we're passionate about our hobby and we want good information out there
  26. Sep 13, 2018 at 2:39 PM
    #356
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    SoCal619, joonbug, dragos28 and 7 others like this.
  27. Sep 13, 2018 at 2:40 PM
    #357
    Necessary ban was issued. If you’re still posting, it’s not you :thumbsup:
    Bob, smslavin, dragos28 and 5 others like this.
  28. Sep 13, 2018 at 2:42 PM
    #358
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
  29. Sep 13, 2018 at 2:42 PM
    #359
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
  30. Sep 13, 2018 at 2:42 PM
    #360
    roypark
    roypark Semi-pro High Fiver
    Roy
    Orange County
    2016 Tundra
    A little of this and a little of that. Its pretty run of the mill.
    Roll call. Check in to let us know you survived the ban hammer. Hahaha
