Driving down hwy and it dies
Discussion in '1st Gen Tundras (2000-2006)' started by Valler, Dec 31, 2018.
  1. Jan 5, 2019 at 5:54 AM
    Valler
    Valler [OP] New Member
    Ramon
    Daily driven 2000 toyota tundra
    16in M/T wheels with a 305 70 r16 tire 3in space lift front add a leaf in rear Led headlights upgrade OEM fog light delete replaced with 7in light bars in OEM locations Led interior lights and tag lights and cargo lights also Kenwood double din head unit self powered subwoofer under driver's seat
    The tension pulley at fault in this case
    Black Wolf likes this.
  2. Jan 5, 2019 at 5:59 AM
    That's a decent quote. Saving some $ there!
  3. Jan 5, 2019 at 6:00 AM
    That certainly would do it.
  4. Jan 6, 2019 at 4:12 AM
    RoujePN
    RoujePN New Member
    2019 Platinum CM 4x4 5.7L 1G3
    Would this be covered adding to potential benefits of purchasing long term EW?
  5. Jan 6, 2019 at 4:38 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    If it broke before the recommended interval probably. If you ignored the replacement though I wouldn't expect it to be covered and I can't see it being covered normally since it is a wear item.
  6. Jan 9, 2019 at 5:03 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Well if an amateur did the job, I doubt they changed the tensioner pulley, or if they did, sounds like they didn't tighten down tensioner when job was done, or tightened it way too much.
  7. Jan 27, 2019 at 7:12 PM
    Valler
    Ramon
    Well i was checking on the carfax and it said the timing belt was replaced back in 2007 with the truck having only 115k by a Toyota dealer, so guess the dealer or worker didnt do a good job
  8. Jan 31, 2019 at 10:28 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    It's debated on this forum and others, but the service manual says 9 years or 90,000 miles for the timing belt. You're right at the 11 year mark, give or take so, you might be one of these instances other posters refer to a "had a friend whose belt broke before 90k". I can say I called three dealerships here in the Baltimore area for a 2006 belt and water pump, $1200, $1300, and $1600. Ouch.dd.jpg
