Door check replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by DVCNick, Sep 9, 2020.
  1. Apr 6, 2021 at 9:37 AM
    SouthWestGA
    SouthWestGA New Member
    Buy OEM door checks
    I bought the Ebay knockoffs for 1/3 the price
    they’re junk
  2. Apr 11, 2021 at 6:32 PM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I just bought an eBay one and installed it yesterday. Works like a charm.
    WFD473 and NewImprovedRon like this.
  3. Apr 4, 2022 at 12:38 PM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    Just replaced mine, again. This one cracked last week at the A pillar mount. However I heard popping noises a few weeks prior. Check out the plastic backing difference between these two….. absolutely disintegrated.
  4. Mar 19, 2023 at 7:23 PM
    Bamapt
    Bamapt New Member
    Just attempted to replace my driver side with an aftermarket. My problem seems to be bigger. It appears the female end , where the bolt goes holding the stop to the truck frame has stripped out. I cant get it to catch and really don’t know how to fix that issue. Anyone run into this?
  5. Mar 20, 2023 at 6:40 AM
    NoRcptn
    NorCal
    2017 Platinum
    @Bamapt Be gentle and keep trying. You can try to chase the original size with a tap for the first few threads if they are bungled. Otherwise, you may have to try to get behind your kick panel a/ pillar to remove the weld nut and run a free nut or
    Double nut combo to avoid loosening.
    On my 04 I ended up going to a body shop and they welded a new plate in.
    Here’s some reference that may help.
    https://www.tundras.com/threads/door-check-mounting.47784/
  6. Mar 20, 2023 at 7:17 AM
    Bamapt
    Bamapt New Member
    thank you !
