Dobinsons leaf springs anything negative?
Discussion in 'Suspension' started by CharlestonJoe, Feb 6, 2021.
  1. Apr 29, 2022 at 8:08 AM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited *sold*
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    So what dobinsons front setup should i get? I will have a winch bumper and winch but its a 10k synthetic line at 60 lbs, and the bumper is only 121lbs. Should i just get the stockload since its under 220??
  2. Apr 29, 2022 at 8:19 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    I'd suggest the heavier rated coils that suit the bumper and winch. It's additional leverage over the front end, sticking pretty far out over the front suspension.
    Either the C59-610 or C59-578, depending what lift height you're looking for.
    AggiePhil likes this.
  3. May 3, 2022 at 7:05 AM
    crikeymike
    Sumo91 likes this.
  4. May 3, 2022 at 8:46 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I see they finally got the shackle end covered. When I replaced my leafs months ago I bought 2 sets of greaseable pins, and they only fit the fixed end properly. I called dobinsons and told them about the fitment issues, and sent them pictures. They said they were going to address the issue and they did! That's awesome! Now I need to the shackles though :spending:
    crikeymike[QUOTED] likes this.
  5. May 8, 2023 at 4:46 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I just noticed the greasable shackles came back into stock recently. I see that they now come with the greasable bushings for the top and bottom of the shackles. My question is if I want to buy the pins for the fixed side how would I come across the correct greasable bushings for just that spot?
    TIA Mike
  6. May 8, 2023 at 7:09 AM
    crikeymike
    Those are in the PB59-1102K bushing kit only. I haven't heard if Dobinsons will sell those as a new separate kit yet.
    Shanet421[QUOTED] likes this.
