Dobinsons leaf springs anything negative?
Discussion in 'Suspension' started by CharlestonJoe, Feb 6, 2021.
  1. Feb 6, 2021 at 6:16 PM
    CharlestonJoe
    CharlestonJoe [OP] New Member
    Joe
    Charleston,SC
    2020 White Tundra SR5 5.7 4x4
    TRD intake, Tow Mirrors, Under seat storage, Built in bed storage, Borla exhaust, 3” Icon lift, BFG’s, Method wheels, 1794 grille, Prinsu Roof Rack,
    The only negative issue I have found is that the heavy duty pack is stiff especially at first.
    I tried Icon’s add a leaf package and have lost everything I’ve gained in just a week. I had a 3 inch rear lift for a day or two.... One day of carrying 1,000 lbs of bagged concrete and another day of lumber and they have relaxed/ flattened out. I should have read up on them more, I was all focused on the shocks and assumed their springs were as good. Nope. I don’t like the idea of now adding airbags to compensate for what I lost. So, I’m leaning more towards a heavier spring pack for those some what heavy days (1,000 lb days) and then add airbags for the really heavy days. Really heavy days meaning loaded to the hilt and towing a travel trailer. In my mind, 1,000 lbs is a half ton and these are half ton+ trucks, throwing a 1,000 lbs in the back once a week or so shouldn’t permanently flatten a set of springs. The Icon add a leaf pack I had installed, removed 2 oem leafs and put in 3 Icon leafs, the installer was really impressed with them initially. On a good note, the truck rides awesome.
    So what I’m looking for is input on long term use of Dobinsons springs, anyone dissatisfied? I’m leaning towards Dobinsons because they are closer to me. If the general consensus is Deavers are better or OME’s are better please pipe in. I’m not saying money is not an issue because of course it is but, I would rather pay for quality once.
    Wixo and AggiePhil like this.
  2. Feb 6, 2021 at 7:04 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I just installed the road master active suspension heavy duty on my 2020. I got about 2inches of lift out of it. Hauled close
    To 2,000lbs the other day with just 1 inch of squat. Best $500 I’ve spent on the truck
    sorry that’s not an answer to dobinsons but it’s an alternative to new leaf packs or AALs
  3. Feb 7, 2021 at 5:03 AM
    CharlestonJoe
    Joe
    Charleston,SC
    Thanks Shawn, I appreciate all input! The Road Master system is a add on type set up isn’t it? I think I looked at it a couple months ago and wasn’t sure how it would hold up to off-road use. Do you have any pictures of it on your truck?
  4. Feb 7, 2021 at 5:13 AM
    CharlestonJoe
    Joe
    Charleston,SC
    Does anyone have pictures of their Dobinsons HD leaf pack? I read its 5+2, so its 7 leafs, why don’t they just say 7 leaf pack?? Or is it a 5 pack and you squeeze it in between two on the truck? I will go to YouTube and see if anyone posted a video on it. Also, does anyone have the promo code for Dobinsons?
    AggiePhil likes this.
  5. Feb 8, 2021 at 7:44 AM
    ckkone
    ckkone New Member
    SLC, UT
  6. Feb 8, 2021 at 8:07 AM
    Elduder
    Elduder New Member
    Overload leafs being listed at +2. They dont typically factor into the spring rate or are unused until the vehicle is either loaded enough or compressed enough. So technically not a constant use spring.
    crikeymike likes this.
  7. Feb 8, 2021 at 8:55 AM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 limited hybrid offroad
    I've heard the dobinson's leaf springs are super good. Thinking of going that route, but they're on the other side of the country for me, and the shipping would kill me.
  8. Feb 8, 2021 at 9:37 AM
    Elduder
    Elduder New Member
    $200 flat rate, at least per Exit Offroad when I checked a week ago. Does make them pretty spendy, with everything needed in the end the price balloons to ~$830.
  9. Feb 8, 2021 at 11:10 AM
    hinow41
    hinow41 New Member
    Rob
    I just did a Dobinson's lift, I did HD in the front and regular leaf. Got it from Exit Offroad, I was going to do the HD rear but was told if its not a constant load in the rear the ride would be a stiff. I only have a RTT on so decided to listen to Mike, Glad I did truck rides great.
    @Skey44 has the HD springs maybe he can chime in
    AggiePhil and crikeymike like this.
  10. Feb 8, 2021 at 2:47 PM
    TundraLaw
    Northern Nevada
    Just ordered the stock to medium load leaf springs. Should improve upon the flat OEM leaf springs, especially when I have my Thule xsporter bars, RTT, bike rack, and bike on the back. No amount of CB shackles can remedy that haha.
  11. Feb 8, 2021 at 3:01 PM
    ckkone
    ckkone New Member
    SLC, UT
    Flat springs do not mean worn out springs. Tundra springs are relatively flat when new. If you want bowed springs to make you feel better you should look into long travel under axle springs like Camburg. Not sure why people always think because their springs appear flat they are worn out.
  12. Feb 8, 2021 at 3:05 PM
    TundraLaw
    Northern Nevada
    Fully aware that the flat OEM springs come that way, but based off my lift, I need more rear lift to compensate for the amount of bed weight I have.
  13. Feb 8, 2021 at 5:45 PM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    If you haven't already ordered I would check with Josh at 1stgenoffroad.com. He has most of his items listed as free shipping and is located in Texas. If you don't see what you want on his site just contact him. He may have it
  14. Feb 8, 2021 at 6:21 PM
    TundraLaw
    Northern Nevada
    Great tip. Thanks!
    BroTun13[QUOTED] likes this.
  15. Feb 9, 2021 at 3:07 PM
    CharlestonJoe
    Joe
    Charleston,SC
    I went ahead and ordered yesterday from Dobinsons direct, the heavy duty pack, bushings, U-bolts, grease-able pins, etc with shipping came to $1,030. I will do an update once I have them and installed and let you know what I think.
    AggiePhil, jtwags, TundraLaw and 3 others like this.
  16. Feb 12, 2021 at 10:42 AM
    TundraLaw
    Northern Nevada
    How do the leafs ride unloaded?
    Bigboitundra likes this.
  17. Feb 12, 2021 at 12:59 PM
    hinow41
    hinow41 New Member
    Rob
    I always have my rtt on, but it feel great. Havent done any off roading yet with this setup but around town it feels good
  18. Feb 25, 2021 at 4:16 PM
    TundraLaw
    Northern Nevada
    How much lift did you get out of your regular dobinson's leaf springs with no weight in the back?
  19. Feb 25, 2021 at 4:40 PM
    TundraLaw
    Northern Nevada
    how long do you think oem leaf springs could last with little to no bed weight?
  20. Feb 26, 2021 at 11:01 AM
    ckkone
    ckkone New Member
    SLC, UT
    200K miles.
  21. Mar 28, 2021 at 3:37 AM
    CharlestonJoe
    Joe
    Charleston,SC
    Finally installed my Dobinsons leaf springs! It took me and my teenage son about 4 hours to install them. We took her for a test drive afterwards and I have speed bumps in my neighborhood so a pretty instant test. We thought it was just slightly stiffer. My Icon shocks are the 2.5 clicker adjustable ones so I had dialed them down to the softest setting in anticipation. I need to get some measurements, I know it sits higher, which I wanted so that when I carry a heavier load it rides level or close to it. I already have a constant load of 5-600 lbs with tools and built in storage.
    Kernal and crikeymike like this.
  22. Dec 9, 2021 at 1:24 PM
    McCrapper
    McCrapper New Member
    Anymore reports back on this leaf pack?
  23. Dec 10, 2021 at 8:32 AM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    I'm interested as well in how they do with a big load.
  24. Dec 17, 2021 at 4:47 AM
    CharlestonJoe
    Joe
    Charleston,SC
    I have had them about 9 months now. I love them even more! Handles all loads well, I am very pleased. As I mentioned previously, I have a constant load of around 5-600 lbs, I have added 1,500 lbs of tile on top of that, she squatted just a little. I have about a 2 inch rake with my constant load, with the extra 1,500 lbs she probably squatted 3 inches. I was very pleased.
    AggiePhil, rruff and crikeymike like this.
  25. Dec 17, 2021 at 10:11 AM
    rruff
    rruff New Member
    3 inches squat relative to your normal 5-600 lb load? You have the additional leaf?
    This is good info. I'm planning to add around 1500 lbs to my rear axle full time. I don't want more than 1 inch of lift vs stock. I'm actually considering the Ironman Pro kit which comes with leafs (only way to get the discount). I know it isn't ideal to simply overload the springs to get the lift I want, since the springs will eventually flatten from bottoming and likely fail... maybe? I know of several people hauling campers with OME/Dobinson springs though, and they seem happy with them.
  26. Dec 23, 2021 at 11:12 AM
    J.Clarke
    J.Clarke New Member
    2023 Tundra Crewmax SR5 L TRD off-road
    do you have photos? Loaded unloaded etc a lot to ask o know but looking into the medium duty ones as I don’t carry constant load but I do have loads and when pulling the enclosed or camper the squat causes the front to come up a bit don’t want to loose too much steering and that’s with a stabilizer I know airbags blah and 3/4 ton but I’m not ALwaYS pulling heavy is why I can’t justify it … yet
  27. Apr 24, 2022 at 8:39 PM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    Hi just wondering about how youre liking the springs? Considering a dobinsons full kit and torn between the medium and heavy duty rears. Right now i have a topper guessing 175-200 lbs constant but considering adding a drawer system. Whatever iget had to still perform well offroad though
  28. Apr 24, 2022 at 9:20 PM
    rruff
    rruff New Member
    Isn't it just an additional leaf? If so you could add it later if you wanted. I've seen guys with pretty heavy campers that didn't squat with that setup.
  29. Apr 24, 2022 at 9:31 PM
    Wixo
    Wixo The Best Member
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    You cant go wrong with an all dobinsons suspension. Heres my Tacoma review: https://www.tacomaworld.com/threads/dobinsons-review.652256/
  30. Apr 28, 2022 at 7:26 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Go with the standard leaf pack. Heavy duty would be overkill. I have the standard and it's great, though it was quite stiff for awhile until I had alot of weight in the bed and pulled my trailer fully loaded a few times. It takes about 4-500lbs before it starts to lower the rear end.
    ZPhilip and crikeymike like this.
