DIY RIGID TRD PRO Fog Lights Brackets
Discussion in '2.5 Gen Tundras (2014-2021)' started by tanabersx, Jan 13, 2019.
  1. Aug 9, 2019 at 4:26 AM
    #151
    mgates32
    mgates32 New Member
    Mitch
    2018 Toyota Tundra
    Does anyone happen to know if the 2018 SR Tundras are prewired for fog lights? I'd look, but I'm deployed right now so no access to my vehicle or anyone at home that knows what they're looking at. If yes, was thinking about buying these light (they are the ones that go in the bezel sold by Roman correct?): https://www.amazon.com/gp/product/B074TWVKQN/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
    And again, if yes I would be interested in a pair of brackets. Thanks.
  2. Aug 9, 2019 at 4:43 AM
    #152
    Matthewkort
    Matthewkort New Member
    Thanks for your service first of all.
    Second, im gona bite the bullet and say that im almost 90% positive that everythings prewired and just tucked away if not “in use” to save from having 5 different wire harness for 5 different models(I know my sr5 headlights harness has the led strip plug but it was tapped off cause I didn't have a limited or platinum or whatever model has the led strip)
    And finally if ur using those as fogs it probably will be a shitty outcome due to the spot pattern.
  3. Aug 9, 2019 at 5:10 AM
    #153
    tanabersx
    tanabersx [OP] New Member
    Miguel
    Puerto Rico
    2017 Tundra DC SR5 XP
    Agreed!
    I believe they all come pre-wired but the best way to find out is actually looking for the plug in the fog light area. Also the spot optics as fog lights will suck if you actually want them to work as fog lights.
  4. Aug 9, 2019 at 5:19 AM
    #154
    mgates32
    mgates32 New Member
    Mitch
    2018 Toyota Tundra
    What should I be looking for in fog lights that make them less shitty if spot lights suck? Also @Matthewkort, what length is your light bar that you have in your grill?
  5. Aug 9, 2019 at 5:24 AM
    #155
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I’d use 504813, they’re like a 2nd setup of low beams set lower and wider light pattern. In the city I can easily get away with using just the Rigids and the headlight strips at night, I don’t blind cars with my LED low beams (I still aim the driver’s side headlight lower as a courtesy when I do have them on). Member here with those like mine:
    mgates32[QUOTED] likes this.
  6. Aug 9, 2019 at 5:39 AM
    #156
    mgates32
    mgates32 New Member
    Mitch
    2018 Toyota Tundra
    Awesome. Only $50 so I guess I'll go with thoe instead.
  7. Aug 9, 2019 at 6:12 AM
    #157
    Matthewkort
    On my fj I had amber driving pattern and they did good, no issues with other drivers or police due to the amber factor, if you get them in white thats another story.. next option is DOT/SAE which they have in white and amber, im currently running the amber and have no issues and love them. The the bar in my grill is a 40” radiance(white)
  8. Aug 9, 2019 at 6:24 AM
    #158
    mgates32
    mgates32 New Member
    Mitch
    2018 Toyota Tundra
    Thanks! You've been a big help.
    Matthewkort[QUOTED] likes this.
  9. Aug 17, 2019 at 3:17 PM
    #159
    mr_data
    mr_data New Member
    Northern New York
    2016 Super White Tundra SR5
    Just did the install on my truck. The most difficult part was definitely getting my big hand in with a wrench to tighten up the bracket.
    Matthewkort and tanabersx[OP] like this.
  10. Sep 11, 2019 at 5:14 AM
    #160
    tanabersx
    Miguel
    Puerto Rico
    All shipped!
  11. Oct 11, 2019 at 5:50 PM
    #161
    Spotdog
    Spotdog New Member
    2016 inferno tundra
    Are these Bracket kits still available for sale ?
  12. Oct 11, 2019 at 6:03 PM
    #162
    tanabersx
    Miguel
    Puerto Rico
    Yes they are!
  13. Oct 15, 2019 at 6:17 PM
    #163
    Tundrahunt
    Tundrahunt New Member
    2016 crewmax platinum
    I would like a set of the brackets.
  14. Oct 15, 2019 at 6:53 PM
    #164
    tanabersx
    Miguel
    Puerto Rico
    PM’d!
  15. Oct 15, 2019 at 7:25 PM
    #165
    Spotdog
    Spotdog New Member
    2016 inferno tundra
    received today , wow , awesome shipping . excellent service . Thanks
  16. Oct 16, 2019 at 9:26 AM
    #166
    phabej
    phabej New Member
    Washington
    2018 Platnium
    are the Rigids brighter than OEM LED? just curious.
  17. Oct 16, 2019 at 9:38 AM
    #167
    tanabersx
    Miguel
    Puerto Rico
    The Rigid D-series are, don't know the exact numbers but are way brighter. The OEM rigids not that much.
    JoshuaA and phabej[QUOTED] like this.
  18. Oct 16, 2019 at 9:42 AM
    #168
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Considering it as a future mod for sure. Besides eventually, it will need to be replaced with rock chip/crack or whatever.
  19. Oct 16, 2019 at 9:42 AM
    #169
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I have the SAE Rigids and I don’t think they are much brighter than oem. I think they look 10x better.
  20. Oct 16, 2019 at 10:14 AM
    #170
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    phabej[QUOTED] likes this.
  21. Oct 16, 2019 at 10:34 AM
    #171
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    So I just came across this thread. I'm currently in the market for new fog lights since my Morimoto ones are flickering like hell now. I was looking into the Baja ones, but can't seem to get in touch with them. This set up looks to be a lot cheaper though.
    Anyway, so now I see these. Can you confirm with everything I'd need:
    -Bracket (sold here) - $20
    -Rigid lights 504813? - $202
    -Wire Harness - $25
    -Toyota TRD PRO fog bezels: ( PT228-34190-AA, PT228-34190-AB ) - $66
    So I'm looking at about $313. Sound about right?
  22. Oct 16, 2019 at 10:40 AM
    #172
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
  23. Oct 16, 2019 at 10:42 AM
    #173
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Yes, maybe bracket bolts if not included. Love this mod, do it!
  24. Oct 16, 2019 at 10:46 AM
    #174
    tanabersx
    Miguel
    Puerto Rico
    Stainless steel bolts, washers and nuts are included with the brackets!
    JoshuaA[QUOTED] likes this.
  25. Oct 16, 2019 at 11:19 AM
    #175
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
  26. Oct 16, 2019 at 11:38 AM
    #176
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
  27. Oct 16, 2019 at 12:25 PM
    #177
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    TTU19[QUOTED] likes this.
  28. Oct 16, 2019 at 8:07 PM
    #178
    rollin-on-dubs
    rollin-on-dubs New Member
    Chuck
    Middle TN
    2014 CrewMax Platinum
    Toytec Boss Suspension SPC Light Racing UCA's Coach Builder 3" Rear Shackles 20x9 Fuel Boost 275/60/20 Nitto Terra Grappler G2 Locker-Down Center Console Safe Morimoto XB LED Fog Lights Ellis Precision Shift Knob Ellis Precision Battery Hold Down
    Nice job! Way better than ridged brand
  29. Oct 18, 2019 at 1:36 PM
    #179
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Got my lights in! Dang these things are heavy for what they are, nice! Now just waiting to get in the other parts.
    So did everyone go through the front, or the back? What do you recommend on how you did yours?
    JoshuaA likes this.
  30. Oct 18, 2019 at 2:11 PM
    #180
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    The bezels push in from the front. Everything else take out the liner and go in from the behind.
