DIY: Replacing Front Brake Pads and Rotors
Discussion in 'General Tundra Discussion' started by csuviper, Oct 12, 2017.
  1. May 18, 2019 at 4:46 PM
    womprat57
    womprat57 BABE the Big Blue Ox
    NH
    2014 SR5 DC 4x4
    Figured I would reset my maintenance message since the oil change will happen soon and decided to go bed the pads, lights are gone and pedal is back to normal, go figure!
    Tundra Fan and equin like this.
  2. May 20, 2019 at 10:22 AM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Glad everything worked out. I plan on doing mine soon and don't like hearing about problems. Stories about how smooth everything went are much more comforting to read. :D
    I am going to do my rotors this time, but I'm wondering if something like this
    would make the job easier next time since you wouldnt have to remove the caliper.
  3. May 24, 2019 at 3:10 PM
    womprat57
    NH
    2014 SR5 DC 4x4
    Going gently with a screwdriver worked for me, even though I had the new rotors, but yeah thats a good tool. I still need to re-seat the wheels and get rid of my wobble but yeah take your time do it right. Great write-up!
  4. May 25, 2019 at 11:55 AM
    womprat57
    NH
    2014 SR5 DC 4x4
    TIP-If also doing the rears check-
    Inside of steel wheels, they rust where mounted-wire brush it off!
    Adjust the parking brake to just where you have resistance, use the lugs to keep the rotors straight, otherwise it may mount up a bit cocked and give you vibration at speed,
    Then take off the lugs, with the E-brake engaged to keep the rotor straight, mount the wheel whack it all around lightly with a hammer to ensure the rotor is over the inner lip, and torque wheels in the air 154 ft/lbs.
    The most work was the prep and jacking to be honest.
    YMMV!
  5. May 25, 2019 at 4:03 PM
    Tundra Fan
    Toby
    Installed mine today, no more steering wheel vibration when braking. :yes:
    womprat57 likes this.
  6. May 25, 2019 at 4:22 PM
    I'll be doing this soon, wonder where I'm getting parts from.........
  7. Oct 28, 2019 at 2:27 PM
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    I'm in process of replacing my front brake pads and rotors with stoptech and was wondering if you can tell me what is the torque for two calipers bolts?
    Thank you very much in!
  8. Oct 28, 2019 at 3:37 PM
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Does anyone know what is torque for front calip
  9. Oct 28, 2019 at 3:56 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    On my 2nd gen, it was around 74. Rear was around 68
    LKSR5-14[QUOTED] likes this.
  10. Oct 28, 2019 at 6:57 PM
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    I have ended up with 80 and whatever happens
  11. Dec 15, 2019 at 1:11 PM
    robd382
    robd382 New Member
    Rob
    I replaced both the front and rear, I was at about 62 k mileage wise. I am having a LARGE amount of vibration, more than before they were changed. Any suggestions on what that could be?
  12. Dec 16, 2019 at 10:50 AM
    Tundra Fan
    Toby
    Make sure everything was tightened back up.
  13. Feb 23, 2021 at 4:48 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Hey so i noticed that there is only one anti rattle clip per side, shouldn’t there be two on each set of pads
  14. Mar 5, 2021 at 8:35 PM
    Tactical_TRD_Pro
    Tactical_TRD_Pro New Member
    Scott
    2016 Toyota Tundra TRD Pro
    Torque on front calipers is 74 and 68 for rear calipers.
    What is the torque setting on rotors? Or will that be on the rotor box when received?
    TIA!
  15. Mar 6, 2021 at 7:33 AM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    For al of us in the SALT BELTS,keep those pins super clean and lightly lubed.If get super rusted its not going to be fun removing them.I remove mine atleast once a year and clean them.So far so good
  16. Mar 6, 2021 at 10:21 AM
    omgboost
    East Coast
    Aren't the rotors held together by the wheel lug nuts?
  17. Mar 7, 2021 at 4:53 AM
    Tactical_TRD_Pro
    Scott
    Asking what lbs to torque the lug nuts. I've read that tightening lugs too tight causes warped rotors and I want to prevent that.
  18. Mar 7, 2021 at 6:44 AM
    omgboost
    East Coast
    97 ft lbs for alloy wheels, 154 ft lbs for steel wheels
  19. Mar 7, 2021 at 3:16 PM
    #49
    Tactical_TRD_Pro
    Scott
  20. Apr 26, 2021 at 6:40 AM
    #50
    browniemix33
    browniemix33 New Member
    New Hampshire
    2017 Metallic Grey Tundra Limited 4WD
    Great write-up and discussion. Will be doing this project this weekend and will post results. Call me old-fashioned, but I prefer to do full OEM for parts. Figured I would post what I found for OEM part numbers for my 3rd gen 2017 Tundra:
    (1) Brake pads - 04465-0C020 (each set comes with 4 brake pads)
    (2) Brake rotors - 43512-0C020
    (4) Hole Pins - 90240-06024
    (2) Pin Hold Clips - 90016-AS903
    (2) Anti-Rattle Springs - 04947-0C030 (each set comes with 2 springs)
    (1) Shim Kit - 04945-0C040 (VERY important if ordering Toyota brake pad set since they do NOT come with shims)
    Side note: have read on other threads on here about the Toyota TRD performance pads. Part #PTR09-0C111 and come installed w/ shims
    GunWanderer, equin and JimboSlice413 like this.
  21. Apr 27, 2021 at 12:36 PM
    #51
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    I did this not long ago along with ss lines, and a full rebuild of the front rotors due to bad boots. If your going this far I would check your boots on your calipers to make sure they're good. If not rebuild the calipers, it's 14 bucks I think from the dealer for a rebuild kit and it comes with lube.
  22. Oct 5, 2024 at 4:20 PM
    #52
    GunWanderer
    GunWanderer New Member
    2019 Tundra SR5 4x4
    Thanks for this. I ordered the same. As for the Disc Brake Anti-Rattle Clip Set, the set contains 2, by all means we use one clip for each - left and right - side. But I guess it doesn't hurt to also install an extra one for the top. I don't know why Toyota didn't use 2 clips for each side, top and bottom.
    Would you happen to have the list for the rear brakes?
