DIY HELP. Rigid Fogs on '17 TRD Pro.
Discussion in 'Lighting' started by Devildawg712, May 26, 2018.
  1. May 26, 2018 at 7:00 PM
    Devildawg712
    Devildawg712 [OP] New Member
    Union City, Ca
    2020 Marine Corps Green Sequoia. (SEQUNDRA) Past~~ 17' Cement TRD PRO (FUNDRA)
    So I was about to tackle this DIY which is pretty straight forward from all the research and videos I watched. I pretty much hit a roadblock though at step 2 when I was about to install the 3 piece Rigid brackets.
    I'm assuming there's cutting involved on the bumper ends since its not lining up with my PRO ends ? The mounting plates don't sit correctly. At least not for me. the first part is supposed to sit straight up on the frame, but the painted caps appear be the biggest difference from what I can see in the DIY videos.
    If you've successfully completed this DIY on you '17 Pro, I'd appreciate any pointers. Thank you
    This is what I have.
    Rigid Industries 50481 D-Series SAE Fog Light Set
    https://www.amazon.com/gp/product/B00Q1RS83M/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    These are the brackets that are in question.
    Rigid Industries 46520 Dually Fog Light Kit for Toyota Tundra
    https://www.amazon.com/gp/product/B00NGYXA8Q/ref=ask_ql_qh_dp_hza
    Here's the youtube DIY
    https://youtu.be/ouoa8SQ2uhM?t=3m29s
  2. May 26, 2018 at 8:00 PM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    I’ve installed these on mind but it has the metal bumper ends and the bracket is sandwiched around the little lip on the inside of the opening. With the plastic bumper ends I believe the bracket is screwed into the plastic on the inside of the bracket. If you can return those brackets do it and get these instead: https://caliraisedled.com/collectio...4-toyota-tundra-led-pod-fog-light-replacement
    The Rigid brackets are flimsy and the light bounces horribly while you’re going down the road.
    Devildawg712[OP] likes this.
  3. May 26, 2018 at 8:02 PM
    MotoTundra
    MotoTundra The Ocho
    Don
  4. May 26, 2018 at 8:06 PM
    Devildawg712
    Union City, Ca
    Hey Thank You. So you're saying they Can be installed tho right? I didnt know there were alternatives so I went with these. I got them on prime so I'll return them and get the ones you recommended. Any manipulating involved on those? Thanks brotha
    JR
  5. May 26, 2018 at 8:17 PM
    manofsteele2003
    Grant
    24 Sequoia TRD Pro
  6. May 26, 2018 at 8:50 PM
    Devildawg712
    Union City, Ca
    MotoTundra[QUOTED] likes this.
  7. May 27, 2018 at 1:12 AM
  8. May 27, 2018 at 5:15 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Win-win. Yes Sir. Good luck!
