DIY: Fog Light Mod
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, Mar 13, 2014.
  1. Mar 28, 2022 at 1:45 PM
    #151
    Hanzo
    Hanzo New Member
    So how should I proceed? Do I need to run a line from my switch to the grey wire?
  2. Mar 28, 2022 at 1:46 PM
    #152
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    What year is your truck?
  3. Mar 28, 2022 at 1:46 PM
    #153
    Hanzo
    Hanzo New Member
  4. Mar 28, 2022 at 3:12 PM
    #154
    Hanzo
    Hanzo New Member
    I hooked the grey wire to the ground point in the footwell and now it’s working!
    14burrito likes this.
  5. Mar 28, 2022 at 6:04 PM
    #155
    Hanzo
    Hanzo New Member
    We’ll now I can’t turn them off separate from my headlights…
  6. Mar 28, 2022 at 9:25 PM
    #156
    RainMan_PNW
    Casey
    Clark County, WA
    I know it’s a super late response, but the changes in to the fog light power affect 2018-2021 trucks the same. The power for the relay coil and the relay power are both sourced directly off the battery. Using this “V1” mod to connect the fog light switch output (which is RED pin 26 on the J165 connector now) to the grey wire (which is no longer at AJ10) would cause your fog lights to be on ANY TIME that you had the fog light switch on (even with the engine off).
    kaymonster and Barrett50 like this.
  7. Mar 28, 2022 at 9:30 PM
    #157
    RainMan_PNW
    Casey
    Clark County, WA
    Are you sure you actually have factory-installed fog lights? Your picture of the J3 connector is leaving a LOT of spots open, even compared to what is in the original V1 write up.
    The 2007 EWD clearly shows that the factory fog light switch runs to pin 28 on connector J3 using a pink wire. If your fog lights were not factory installed, then there’s no telling what/how they are wired up and what method to use to change their behavior.
    Barrett50 likes this.
  8. Mar 29, 2022 at 7:29 AM
    #158
    Hanzo
    Hanzo New Member
    Looks like my truck was wired for the fog light assembly but not for the switch. My game plan is to pin a wire into the stalk connector (J10 - pin 4) and connect to the grey wire.
    Does anyone know what kind of pin I need for this?
  9. Mar 29, 2022 at 8:48 AM
    #159
    RainMan_PNW
    Casey
    Clark County, WA
    Start Here:
    Ultimate Wiring Diagrams Collection | Toyota Tundra Forum (tundras.com)
    Download the 2016-2021 Introductory Information to read up on how to use the EWDs
    Download the 2007 EWD. The Fog Light circuit info starts on page 228
    Also download the 2007 Wire Harness Repair Guide - that will help learn how to work with the connectors and the terminals
    Finally, download the Connector Data Sheets from the 2016-2021 section as needed to look at the details for the different connectors. These data sheets show the connector information including the Toyota part number for the terminals for the each connector.
  10. Mar 30, 2022 at 6:41 AM
    #160
    Hanzo
    Hanzo New Member
    I was able to call the local Toyota parts department and get a terminal repair kit for the fog light switch. Should be in next week and I can finish the wiring. I’ll let everyone know how it turns out.
  11. Jul 15, 2022 at 9:33 PM
    #161
    icodeintx
    icodeintx New Member
    Scott
    Palacios, Texas
    2021 Cement Gray Tundra SR5 CrewMax
    LED Headlights, LED Fog Lights, LED Interior lights
    Do you have anytime fog light mod applied to your 2021? If so, which one works? I'm looking to do the same.
  12. Jul 15, 2022 at 9:39 PM
    #162
    icodeintx
    Scott
    Palacios, Texas
    Did this get figured out? My 2021 is in serious need of this mod. I drive dark 2 lane highways and we have to those solid black hogs around here. :)
  13. Jul 16, 2022 at 6:36 AM
    #163
    RainMan_PNW
    Casey
    Clark County, WA
    This mod won’t work on the ‘21. Your fogs would be on any time your fog light switch is on - regardless of ignition switch state or any other lights.
    I mean - if that’s what you want… but for me, I prefer to keep my lights to turn off when I shut off the truck.
    icodeintx[QUOTED] likes this.
  14. Sep 20, 2022 at 1:20 PM
    #164
    FlipMonkey21
    FlipMonkey21 New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    anybody got a step for a 2019 Tundra?
  15. Oct 31, 2022 at 4:40 AM
    #165
    14tundraman
    14tundraman New Member
    Is the wires the same colors?
  16. Nov 5, 2022 at 5:50 PM
    #166
    lotsaspider
    lotsaspider New Member
    Scott
    2017 orange tundra
    This won’t work on a 2017 will it?
  17. Jan 6, 2023 at 3:34 PM
    #167
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    It's something I would want of I could locate J165 and the grey wire
  18. Jan 6, 2023 at 8:23 PM
    #168
    RainMan_PNW
    Casey
    Clark County, WA
    2ndTunder and 1lowlife like this.
  19. Jan 6, 2023 at 8:52 PM
    #169
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    Thanks.
    1lowlife likes this.
  20. Jan 12, 2023 at 8:09 AM
    #170
    sonofdad
    sonofdad New Member
    steamboat springs, co
    2017 Tundra SR5
    i tried this yestereday on my 2017 5.7L tundra. wanted to share my experience and see if anyone has ideas on how to troubleshoot...
    i read (and re-read) this entire thread and made notes for myself along the way - thanks to everyone that provided detailed photos and explanations by the way!
    i followed the instructions in the EddieV1-3.pdf, using posi-taps instead of male/female connectors.
    i triple-checked i had the correct two connectors and wires. no luck - fog lights would not turn on.
    i then reverted back to the original wiring configuration. fog lights still won't turn on.
    i then found this thread which got me wondering if i'd somehow blown a fuse. it mentions one in the engine compartment (labled FOG) and one in the cab (labeled TAIL). i checked both - they were fine.
    i'd really like to get the mod working. failing that, i'd like to get the fogs to work as they did originally. i'm no electrician, but i'm wondering if one of these scenarios is the issue:
    1) the posi-taps i used were labeled for 20-22 gauge wire. could they be too large for the size of wire that require jumping? i recently used one this same size to do the TPMS light delete - the mod worked as expected.
    2) the posi-tap connections aren't properly connected. i'm not certain how i could screw this up twice, but suppose it might be possible?
    3) the fog light relay is toast. again, i'm not sure how this could have happened, but maybe i borked it during my attempt at this mod?
    4) the fog light switch on the light control stalk is kaput?
    if anyone has any suggestions on how to trouble-shoot i'd appreciate it. thanks in advance.
  21. Jan 12, 2023 at 9:12 AM
    #171
    M_RED
    M_RED New Member
    I haven't ha my Sequoia long, and I am still feeling out all the forums to see which actually have useful information, and this one keeps coming up with answers... Thanks for sharing the "how-to"! Going to attempt this in a 2-16 Sequoia this weekend.
  22. Jan 12, 2023 at 10:46 AM
    #172
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    Bummer man. Those experiences are why I won't try and decipher thousands of pages of wiring diagrams to try and get this mod to work. It's just not my area of expertise. Most things I try on my own, for electrical stuff, I need directions and pictures, lol. Hope you get your lights fixed.
  23. Jan 12, 2023 at 5:27 PM
    #173
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    I used this (FogLightsEddieV1.pdf) on my 17 and has been working for 4 years. Instead of cutting the wires I just de-pinned the 2 connectors in the instructions and jumped them together. Easy to go back to factory.
  24. Jan 12, 2023 at 6:08 PM
    #174
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    That method didn't work for my 18. Glad I pulled the pins, made it easier to put back together.
  25. Apr 25, 2023 at 12:49 PM
    #175
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Did the V1 on 17pro
    parking lights on & with fogs.
    high beams & fogs
  26. Apr 25, 2023 at 5:25 PM
    #176
    stogey420time
    stogey420time New Member
    Houston
    I was set on doing Eddie's V1 fog light mod. Bought 22ga wires and fully insulated male/female crimps ready for the install. Decided to reread the entire thread again and found post #84 using another method so I chose that route instead. Works like a charm... after fog light mod was complete, I ordered SS3 LED Fog Light Kit from Diod Dynamics arriving Thursday... can't wait for the install!!!!
    WVI and Y0TA PR0 like this.
  27. Apr 25, 2023 at 5:46 PM
    #177
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Was ganna go that route but decided on the V1, but I didn’t cut the wires I de-pinned the wires and hooked them up together, super easy. Took me like 30mins to do.
    stogey420time[QUOTED] likes this.
  28. Apr 26, 2023 at 4:09 PM
    #178
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Can you offer in some detail how you depinned these connectors? I tried a couple of small SS wires into both sides of the backside of the connector (top and bottom) with zero success.
    I was about to cut the wire but I'd rather not do that.
    Thanks
    Y0TA PR0[QUOTED] likes this.
  29. Apr 26, 2023 at 5:27 PM
    #179
    Y0TA PR0
    Rafael
    2017 TRD PRO
    You see that white plastic across the connector, that white bar has to be pulled up with a little flat head or anything small. That will unclock you all your little pins (or little connector whatever they are called lol). The white bar doesn’t come up much, but you will know when it’s completely up.
    So when you have that unlocked you will flip the connector AJ10 around, so now the white bar will be facing down.
    Now with a small pin or sewing pin you will push UP from underneath where the red arrow is pointing, as your pushing up gently bull back on the wire, should pull out no problem. Once wire is out remember to push that white bar back in to be on lock mode again.
    The yellow arrow is where I pulled out the grey wire. I messed up the plastic a little cause at first I was trying to push down :frusty: But I just pushed the plastic back up and reconnected the grey wire and locks back in place just to make sure it still worked.
    Hope this makes sense lol. Any other questions let me know.
    This is from my 17 so not sure if older model’s connectors are different or same.
  30. Apr 27, 2023 at 10:14 AM
    #180
    KeepOnTruckin
    Randy
    Thanks! Much appreciated!
    That thing was a serious PITA! Got it though! I even had a male connector for the flasher relay with the same design and played with it for too long to pull a couple pins as practice. Connector AJ10 was very stubborn with pin removal!
    Anywho - I'm in the final stages now. Just waiting for some connectors and shrink tube to arrive and call this done.
    I rewired a fleabay switch making it shunt to ground while keeping the power light and on light enabled.
    It's all here in this thread.
    I'm happy to say that grounding the wire with a 12v incandescent test lamp safely allows testing and triggered the relay turning on the fogs.
    On to the next step!
    WVI likes this.
