Disabling the seatbelt chime in 2022 Tundra Platinum …
Discussion in '3rd Gen Tundras (2022+)' started by dlopp64, Mar 1, 2022.
  1. Jul 11, 2022 at 12:48 PM
    #91
    FI460
    FI460 New Member
    Rick
    2022 Limited CM/6.5' TRD OR 4x4
    Exactly my thoughts. It's one thing to say it's the dealership policy to not do that, or only for customers who purchased their. Whatever. But to say that it can't be done means either that someone is incompetent or someone is lying. Neither alternative is reassuring.
    I'll push the issue when I go in for my 5k service.
  2. Aug 12, 2022 at 7:10 PM
    #92
    bretn77
    bretn77 New Member
    Ryan
    2022 Tundra TRD Pro in Solar Octane
    How do I get Techstream to disable seatbelt alarm?
  3. Aug 13, 2022 at 6:32 AM
    #93
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    The official techstream software is $1500 for the OBD2 Mongoose cable and 1 year subscription service to techstream.
    There's a cracked version of Techstream that works with a $50 mini vci cable. Cable you can get off Amazon. Not sure how this works, but there are people here who had success with cracked version. I have the official techstream from my shop.
    But if you just looking to just do some setting customization, there's is Carista OBD2 adapter that works with your phone, other members here have found it works to disable seat belt, fake engine noise, window down with key fob, and changing warning volumes. Probably more options in there too. I believe this is the cheapest route, the adapter is about $30 and then the subscription service for $10/month.
    Thread about Carista
    xwarcat, Henry1jg, OnThaLake and 2 others like this.
  4. Sep 13, 2022 at 10:54 AM
    #94
    Wildcat80236
    Wildcat80236 New Member
    David
    I can confirm that an OBD2 adapter and the Carista app will work on our '22 Tundras. I used the same OBD2 adapter I bought in '17 to customize my Tacoma. Was able to select all five seating locations and disable the alarm as well as change my turn signal flash from three to seven. Total cost of $9.99 for a month to use it and as long as I cancel it isn't a recurring charge.
    Henry1jg, SC4333 and jeosbor1 like this.
  5. Sep 13, 2022 at 11:13 AM
    #95
    22TRDPROSOLAROCTANE
    22TRDPROSOLAROCTANE New Member
    Yes, buy the Carista for $29.99 and get a 1 month for $9.99, make your mods, then cancel. I can confirm it works fine.
    xwarcat, jeosbor1 and Wildcat80236 like this.
  6. Sep 13, 2022 at 3:34 PM
    #96
    sablue
    sablue New Member
    jay
    2022 tundra plat
    what mods can be made ?
  7. Oct 6, 2022 at 5:33 AM
    #97
    TundraBroYaKnow
    TundraBroYaKnow New Member
    2022 Tundra SR5 TRD Off Road
    Any option in TS for backup sensors while trailering?? Absolutely blows my mind Toyota didn’t have an option to turn off the insane amount of warnings when backing up with a trailer on. Instead I have to stop and press the little ok button to temp mute sensors just to have to do it again if I shift from R to D and back to R. Wtf Toyota? Completely thoughtless. I love this truck, but it seems Toyota didn’t think a lot of things through with the safety tech for certain situations. To be fair though I haven’t looked too deep as I know there is a whole section on trailering in the digital setup that maybe will help with this.
  8. Oct 15, 2022 at 5:33 PM
    #98
    Barleyologist
    Barleyologist New Member
    This guys an idiot!
  9. Oct 16, 2022 at 6:45 AM
    #99
    X42069
    X42069 New Member
    M
    Southwestern Ontario Canada
    23 SR5 CrewMax TRD Off Road 6.5ft box
    I thought you could push the button to the left of the steering wheel to turn off those sensors when trailering?
    Leif84 likes this.
  10. Oct 16, 2022 at 10:49 AM
    #100
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Exactly what I used to disable the seatbelt chime (allows you to do so by individual seats) and also disable the faux engine noise. There are a handful of changes that can be made via the Carista app. It's pretty much foolproof, whereas techstream is not.
  11. Oct 16, 2022 at 11:10 AM
    #101
    X42069
    X42069 New Member
    M
    Can you disable the auto start stop?
  12. Oct 16, 2022 at 11:38 AM
    #102
    SC4333
    SC4333 New Member
    Grant
    Unfortunately not.. yet at least. From what I can tell, Carista gives you the same options that you would likely want to alter with TechStream (I have both)
    I purchased a device for my wife's VW Atlas that plugs in between the physical start/stop disable button, and its factory wiring harness. It turns the start/stop off when the vehicle is started, and gives you the options to push the button, thus activating the start/stop function if desired. Hoping someone comes out with something like this for the Tundra. I wouldn't be too surprised if it already exists.
    Henry1jg and X42069 like this.
  13. Oct 16, 2022 at 2:30 PM
    #103
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    I disabled both seats thru Carista a couple years ago. My girlfriend constantly forgets to put her seatbelt on. It might be worth the $10 to turn the passenger seat chime back on..
    elmo Watkins likes this.
  14. Dec 28, 2022 at 8:28 AM
    #104
    Scotterick
    Scotterick New Member
    Scott
    2023 1794 Hybrid TRD Off Road
    This is so annoying. I had the dealer disable the front seats in my 2010 as soon as I brought it to their attention that Toyota listed it in the manual as an owner's preference to be modified by the dealer. In advance of my 2023 purchase, I downloaded the manual and couldn't find similar verbiage regarding the seat belt chime. I contacted Toyota to see if they could direct me to the specific instruction and they said that it was no longer included, citing driver safety, blah, blah, blah.
  15. Jan 4, 2023 at 5:02 PM
    #105
    Troa
    Troa I blue it again.......
    Nomad
    2022 Blueprint Limited
    Fake news! I love having mine disabled
    hairychestedfrog likes this.
  16. Jan 4, 2023 at 9:22 PM
    #106
    Thesamurai
    Thesamurai New Member
    2022Tundra TRD PRO
  17. Jan 4, 2023 at 11:16 PM
    #107
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    I'm going to try the bootleg Techstream route vs carista. $50 for a cable vs $30 for a OBD2 dongle, plus the cost of the app, and subscription every time I want to change something seems more worthwhile. Techstream is probably more robust, in what you can change, I imagine.
    As an adult, I don't need a reminder to buckle my seatbelt when I know it's prudent. I also don't need to be harassed when I'm driving 3mph on my own land.
  18. Jan 5, 2023 at 1:24 AM
    #108
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Please let us know if there are more features that Carista doesn't allow. Good luck!
  19. Jan 21, 2023 at 3:45 PM
    #109
    Magnum13
    Magnum13 New Member
    It's so frustrating to read so many STUPID & IDIOTIC replies from you morons!!!! DUH... do seatbelts really save lives??? No way, impossible, nobody has ever heard that before!!! Everyone in the world is a head trauma surgeon, everyone is a first responder, everyone has had a million relatives killed who weren't wearing their seatbelts, etc. Drinking alcohol isn't safe, eating fatty food isn't safe, eating candy isn't safe, do you want other people telling you what you can and cannot eat!!!! The question was posted for a reason and you don't know what the reason is... either answer the question or shut your mouth!!!! Nobody needs to be preached to... if you don't know the answer... don't respond.
    Kentucky Tundra likes this.
  20. Jan 21, 2023 at 3:49 PM
    #110
    99ways2die
    99ways2die New Member
    NJ
    Perhaps you should take your own advice, and lay off the sake as well...
    -99
  21. Jan 21, 2023 at 3:55 PM
    #111
    Magnum13
    Magnum13 New Member
    Could not agree more... it's punishing to read all the stupid responses about safety... like nobody realizes wearing a seatbelt is safe!!!
  22. Jan 21, 2023 at 3:57 PM
    #112
    Magnum13
    Magnum13 New Member
    Not a very smart response amigo... I did not respond to the question, I responded to the answers! In fact, exactly like you did... so why did you reply to my answer?
    Your comments add absolutely no value to the question. My comment adds value... as I'm trying to discourage people who add no value from posting stupid comments like yours.
    MTRock likes this.
  23. Jan 21, 2023 at 4:16 PM
    #113
    Magnum13
    Magnum13 New Member
    Wow! Thank you so much for sharing this with everyone. Although you added absolutely no value to the topic at hand... you did manage to tell everyone that wearing seatbelts is safe! Nobody had any idea wearing a seatbelt was safe - thank you so much. It's a shame it hasn't been a law in every State in the US for 30 years so it could save even more lives.
    I can't wait to read your next post when a member is asking how to fix their cigarette lighter and you tell them you've worked smoking deaths for 20 years and not smoking really does make a person more healthy.
  24. Jan 21, 2023 at 4:23 PM
    #114
    Magnum13
    Magnum13 New Member
    Agreed, and it was a surprisingly easy fix. Check it out here. https://www.youtube.com/watch?v=rX1jPcbj88o
  25. Jan 21, 2023 at 4:29 PM
    #115
    Magnum13
    Magnum13 New Member
    He's not wearing a seatbelt in the pictures?
    Furthermore, there are a million wrecks a year were seatbelts saved lives... not to mention there has been a seatbelt law in place for over 30 years now... so what value does your post add?
    The question was posted asking how to disable the seatbelt chime... it didn't say, "I want to drive without my seatbelt on can somebody please help me accomplish this"!
    This is a site to come to for answers to questions, not advice on how they choose to live their lives.
  26. Jan 21, 2023 at 8:57 PM
    #116
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Wow, trying to help people really gets your riled up. Sorry buddy. Maybe feel the area out a little before joining a forum and just jump right in on day one being a douche.
    xwarcat likes this.
  27. Jan 22, 2023 at 4:12 PM
    #117
    Magnum13
    Magnum13 New Member
    Trying to help? How? By telling people to wear a seatbelt? LOL! Classic. I can't wait to read your next post telling people not to smoke, not to chew, don't do drugs, etc. People who completely waste other peoples time does rile me up... it's rude and disrespectful. Whether it's on day 1, day 2, or day 50 million, doesn't change the fact that you didn't add any value to the topic. Remember to wear your safety glasses!
  28. Jan 22, 2023 at 4:28 PM
    #118
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I guess there's always the option to block my replies.... Just be happy. Maybe you weren't aware, but stress is inherently bad for you and should be avoided. There's my input for today; you already covered the other important topics.
  29. Jan 22, 2023 at 4:38 PM
    #119
    Magnum13
    Magnum13 New Member
    Now that added value! (...there's my input for today) and humor is good for stress... and yes, I'm well aware of just about everything to do with stress and treating it... it's the rumination that really takes a toll on me. Take care and no hard feelings.
  30. Jan 22, 2023 at 4:50 PM
    #120
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Dude, if the day comes a stranger can cause hard feelings, I need to hide and re-evaluate myself as a man! It's just the internet. All good bro, always up for a good :duel:
    By the way, you did win the word of the day post...rumination....nice:cheers:
