Disable TPMS
Discussion in 'Wheels & Tires' started by 650h1, Dec 9, 2014.
  1. Oct 23, 2022 at 1:45 PM
    #181
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Thanks to you folks for all the info! Just did it with a positap I had laying around. Worked awesome.
    8BF19A3E-4E99-43E9-95F8-68F1DF5B47DA.jpg FE6A841A-2DB3-42C0-B2E8-0A23BEE7680D.jpg 8B16516E-9190-4588-A2C7-B39480A5F266.jpg
  2. Oct 23, 2022 at 3:09 PM
    #182
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    2015 5.7L Silver Sky Metallic Tundra 1794
    Just getting started.... Start X remote starter.
    That's awesome BlueRibbon4x4 !
    I love that so many have done this and solved our problem that just bothered us ! There are some pretty smart people on this forum that have allowed us to complete this fix. Cheers
  3. Oct 23, 2022 at 3:11 PM
    #183
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Hey Coldcanuk, many of us have done this with great success but I do not think it works on the newest tundras. Have a read through the posts.
  4. Oct 23, 2022 at 3:28 PM
    #184
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Thanks TRXTER. I would really like to remove the TMPS light but will wait. Thanks for the heads up. I do not want to have my front dash go into Christmas Tree mode! Hopefully, some wizards here sort out the gen 2.5 someday. Cheers
  5. Oct 23, 2022 at 6:11 PM
    #185
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Yes, so looking back quickly. Post #108 speaks about the tpms location and type of system changing. Hopefully so.eday someone figures it out. Some pretty smart members, give them time. They will solve it.
    coldcanuk[QUOTED] likes this.
  6. Nov 11, 2022 at 3:45 PM
    #186
    kg4x4
    kg4x4 New Member
    Would this be the same location and wiring set up on a 2006 SR5. ... many thanks
  7. Nov 11, 2022 at 4:17 PM
    #187
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Hey there kg4x4, I believe it is but I know this is a pain go back to pg 1 of this post and read through. I recall the wires are a different color and I seem to recall you just need to ground a wire out instead of jumping power. Probably the safest to read through these. I learned alot by doing that. Good luck and let us all know how it works out for you. If I have a chance this w.e. I will skim.through the posts too and see if I can find it. Cheers !!
  8. Nov 11, 2022 at 4:25 PM
    #188
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Found it. Pg.4. Post #99. Looks like on the 2006 it's a pink wire and it gets grounded out. Start your reading in that area. On 2007 (Post 75. Pg 3) it's light green and carries on with that color to a few.years ago
  9. Nov 11, 2022 at 5:39 PM
    #189
    kg4x4
    kg4x4 New Member
    Many thanks, I'll get after it this weekend and report back .... sorry i was sooo lazy to begin with, always best to start things from the beginning :)
    CaptRussia253 likes this.
  10. Nov 12, 2022 at 11:48 AM
    #190
    kg4x4
    kg4x4 New Member
    Well I have found the TPMS box but I need to borrow a six year old with small fingers to get that connector plug out ... does it have a release tab or is it just friction, and if a tab is it on the top or btm. Hard to tell with the small view I have. Been poking at it for 30 + minutes and thought I'd take a break :(
  11. Nov 12, 2022 at 12:54 PM
    #191
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    ok just attempted this on my 17 and light is still on and was flashing.Yes i cut the light green/minty green wire and tapped to the yellow wire right next to it.So... what isnt correct? Glad they use about the smallest gauge wire possible too makes it awesome to work on .
  12. Nov 12, 2022 at 2:26 PM
    #192
    Rob's Inferno
    :mad::mad::mad: no clue why it wont work .
  13. Nov 12, 2022 at 3:13 PM
    #193
    Rob's Inferno
    i give up.Now ill have to try and resplice the green back to itself some how with a piece added so it will reach.I knew i should have never messed with it knowing my bad luck .
  14. Nov 12, 2022 at 5:59 PM
    #194
    Rob's Inferno
  15. Nov 12, 2022 at 6:08 PM
    #195
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    That's the one !!!! Yellow and mint green should.work but for whatever reason it's not. Your positaps are good right ?? Like no damage to the piercing pin and the guts are on the inside of it. I feel.for ya, shouldn't be this hard.
  16. Nov 12, 2022 at 8:50 PM
    #196
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I didn’t use the positap just normal connectors since sometimes they don’t work. Zero issues. Give it another go we’ve got the same year rigs
  17. Nov 22, 2022 at 4:49 PM
    #197
    mikefen1985
    mikefen1985 New Member
    Western mass
    2024 Tundra SX package
    Same here 2017 didn’t work. Not sure if it’s because I have the start x remote start pluggged into the grey box and the truck harness into that.
  18. Nov 22, 2022 at 4:54 PM
    #198
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Hey there, I have the startx on my 2015 and no issues. I just tapped the original wires and not the startx harness. I'm guessing you just don't have a solid connection on the wiring.
  19. Nov 22, 2022 at 5:16 PM
    #199
    mikefen1985
    Western mass
    Thank you I’ll try again tomorrow. I used posi taps maybe you’re right about the connection.
  20. Nov 22, 2022 at 7:15 PM
    #200
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Forsure, I used the smallest positap in the variety pack I bought and it is super hard to keep that wire tight enough to get a good pierce as you spin the connector tight. I had it not work the first time too. Inferno Rob (above) had a terrible time and ended up scratching the casing off a bit then tapping it and had success. I think he tried about 8x. It will work, just gotta get a good connection. Let us know how you make out. Cheers
  21. Nov 23, 2022 at 7:07 AM
    #201
    mikefen1985
    Western mass
    Yep you were right the spike on Posi-Tap was not in the wire. All set now thanks for the help.
    Rob's Inferno likes this.
  22. Nov 23, 2022 at 12:34 PM
    #202
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Glad it worked out !!! Score one more for the owners of Tundras. Cheers.
    sonofdad and Rob's Inferno like this.
  23. Jan 30, 2023 at 12:08 PM
    #203
    edwardlyle
    edwardlyle New Member
    2015 Pro CM - TPMS delete complete after my factory sensors were dying and I got new wheels/tires.
    After 2 trips to discount tire and they could not program the new sensors (aftermarket or OE toyota) I decided I would rather delete than pay Toyota to program them.
  24. Jan 30, 2023 at 12:27 PM
    #204
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Glad that it finally worked out and the dashlight is out.
  25. Jan 30, 2023 at 12:30 PM
    #205
    edwardlyle
    Me too!
    I think it was all worth it, especially considering I was already getting the malfunction light when it got cold because one of my sensors was probably dying (battery).
  26. Feb 7, 2023 at 1:21 PM
    #206
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    So a interesting added feature of this modification. I live in the snow belt and super cold weather at times and it seems if I do not drive my truck for a day and it's very cold out, when I start truck up I get the Tpms flashes on the dash then it turns out like it's functioning the way it should. But I did the mod, all good connections but it seems the extreme cold must drain the current from circuit then when it starts up I get the flashes then turns out. Weird but this only has happened in the cold weather.
  27. Sep 26, 2023 at 10:37 AM
    #207
    Schmidt_l
    Schmidt_l New Member
    Leidir (Lay-Jeer)
    2008 Tundra Sr5 DC
    Grille??
    Thx, light is gone!!
  28. Sep 26, 2023 at 10:41 AM
    #208
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    That's awesome, glad it worked out and no annoying dash light. Cheers !!
  29. Sep 26, 2023 at 10:43 AM
    #209
    Schmidt_l
    Leidir (Lay-Jeer)
    2008 Tundra Sr5 DC
    Grille??
    Exactly!!!
    its a malfunction system anyways to say the least
  30. Sep 26, 2023 at 10:56 AM
    #210
    coTony
    Tony
    Montrose, CO
    Having TPMS sensors and not using them is one thing, you need them? I have been fond of them from the beginning. I would much rather know my tire is low than have it blow on the highway and cause possible body damage or damage the wheel.
    When I first bought my Tundra I had a lift and larger tires put on and the light kept coming on. Well this went on for 3 years or more and the leak was very slow. I told the shops each time my tires were touched and nobody could find it. One day a lady comes out and told me my truck was done. I asked if she found the leak and she looked at the paperwork and missed the comment to check. She asked a handful of questions and she went to work. She started by putting it in a large tub of water to isolate the leak and it took a while but the wheel (Icon Six Speed) had a tiny pin hole. She brought me over to show me and she pointed to it under water. I told her I did not see anything and she said keep watching. Very slow leak but covered under warranty.
    Use them as they were intended and they are valuable. Driving on a low tire will damage your tires over time
