Disable TPMS
Discussion in 'Wheels & Tires' started by 650h1, Dec 9, 2014.
  1. Apr 1, 2022 at 5:56 AM
    #151
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    2015 5.7L Silver Sky Metallic Tundra 1794
    Just getting started.... Start X remote starter.
    A poem to Toyota :::
    Good bye Orange Light,
    Good bye Orange glow,
    A HUGE Thanks to all of those who came before me in this post, MyTPMS light is finally OUT !
    I am good to go !!!
    Well I took a leap and attempted this and so far of no regrets. The first attempt did not work, the posi taps I used were a bit too big and never poked through the wires. I had bought a variety pack and used the mini ones (see pic - the 2 smallest ones on left side of pkg) the only thing I did different was I used 2 posi taps, since these wires are so fine (and fat fingers which might lead to having stripping the light green) I figured I would poke (tap) each of the wires ( 5 & 6 pic) in the harness, I still cut #5 light green after I tapped it. Then I just had a small piece of wire go between the 2 positaps. Presto, all fixed.
    Seriously Toyota, as one person said, we can disable air bags with a switch, why not the TPMS.
    Thanks everyone for your help.
  2. May 11, 2022 at 2:45 AM
    #152
    chrisf111
    chrisf111 New Member
    Completed per these instructions today. Easy as can be. No need to remove any trim if you don't mind working on your back.
    Took 10 minutes and only required wire strippers, and electrical tape.
    Next up is the seat belt chime...
    blackoutt[QUOTED] likes this.
  3. May 11, 2022 at 5:17 AM
    #153
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    Over 3 years ago and still working great! Forgot I even did this but glad I don't have to worry about it.
    Gene_in_FL and chrisf111[QUOTED] like this.
  4. May 11, 2022 at 8:36 AM
    #154
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Works like a charm, no regrets. Stupid system in my opinion.
  5. Aug 30, 2022 at 5:01 PM
    #155
    SpottedDog
    SpottedDog New Member
    G
    Moab, UT
    2017 TRD OR
    Old Man Emu heavy 285/75R18 Toyo AT3’s
    I just took a long, frustrating gander at the wiring on my 2017 and can make hide nor hair of which plug I’m supposed to be looking at behind the passenger kick panel.
    Anyone out there done this kid to their 2017 and have some insight?
    Had new tires put on last week at the nearest decent shop (2hrs away) and the stupid light came on about 20 miles into the drive home.
    I’m attaching a pic…
    Edit:
    Is this the right plug? I’m a welder, so my fingers are all jacked up, I know.
    Also, there is what looks like speaker wire spliced into on of other blue wires in the same plug. I wonder what the previous owner was up to….?
  6. Aug 30, 2022 at 6:02 PM
    #156
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Hey there SpottedDog.
    Yep looks like that's the right connector. So the way your holding it, the 2 wires on the rights side, yellow and light green are the 2 wires your after. As I had posted above mine was a 2015. You wanna cut the light green and tap light green into the yellow. Look back at previous posts and pictures and you will see the way people have done it. Not sure what's up tapping that blue wire. There was a schematic of the wiring in a post way back which may tell you what the blue wire is. As always, this is at your own risk, seems to work and was fine on my 2015 model 1794. Good luck !!!
    TheBeast and SpottedDog like this.
  7. Aug 30, 2022 at 6:19 PM
    #157
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Not sure if this may help too, I wrote down how and why this was done and put it in with my manual. Not planning on selling truck but figured I would document it.20220830_211530.jpg
    sonofdad, TheBeast and SpottedDog like this.
  8. Aug 30, 2022 at 10:02 PM
    #158
    TheBeast The Beach
  9. Aug 31, 2022 at 2:42 PM
    #159
    SpottedDog
    G
    Moab, UT
    2017 TRD OR
    Thank you, sir. Just waiting on the Posi-Taps now. None to be found in my town.
  10. Aug 31, 2022 at 3:00 PM
    #160
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    I found that as well no posi taps anywhere..... what gives they are great. I ordered mine through Crutchfield- car stereos. As mentioned I used the smallest ones in the multipack. Tried a medium size first but just seemed the piercing point that taps the wire was too big on that one. When i started truck and light was still on i was like ahhh @#$%, what went wrong. Then whenni disassembled te connection it was obvious it didnt pierce. The smallest ones worked best for me, although a bit tougher for the large hands. Good luck with it.
  11. Sep 8, 2022 at 3:53 PM
    #161
    SpottedDog
    G
    Moab, UT
    2017 TRD OR
    Y’all kick ass! Light is off on my 2017!
    Also, Posi-Taps are the bomb.
  12. Sep 8, 2022 at 7:07 PM
    #162
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Sweet, glad to hear it worked out. Toyota is an awesome truck builder (well when they made the 5.7L) but the TPMS system totally blew.
  13. Sep 9, 2022 at 1:26 PM
    #163
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Is this the connector?
    Nvm I just said fuck it and went for it. Light is officially off!!!
    Gene_in_FL, mav7021234 and SpottedDog like this.
  14. Sep 9, 2022 at 2:39 PM
    #164
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Ha ha. Nailed it ! Awesome.
    CaptRussia253 likes this.
  15. Sep 9, 2022 at 4:40 PM
    #165
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    when I did this to mine I found a wire tapped into that blue wire as well. I’m curious as to what it’s for as well. Anyone know?
  16. Sep 9, 2022 at 4:44 PM
    #166
    SpottedDog
    G
    Moab, UT
    2017 TRD OR
    Yeah, I kinda want to know what the PO did also.
  17. Sep 9, 2022 at 4:59 PM
    #167
    Musicmasterd12
    Southern Louisiana
    I think this is the wire diagram for it, but I'm not sure what SIL stands for, assuming I'm looking at the correct wiring diagram
    This pic might show that wire having something to do with the transponder key?
  18. Sep 9, 2022 at 6:45 PM
    #168
    SpottedDog
    G
    Moab, UT
    2017 TRD OR
    Musicmasterd12 likes this.
  19. Sep 9, 2022 at 7:15 PM
    #169
    Musicmasterd12
    Southern Louisiana
    that’s what I was thinking. I had one installed but for some reason was thinking that wiring was there before that, guess it wasn’t and it is for a signal for remote start
  20. Sep 9, 2022 at 7:54 PM
    #170
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Ahhh, good call on that. I remember now when I installed my remote start from X-START. I had to run a harness from ignition across to tpms unit. That plugged into the tpms, then the harness we have altered plugged into the new remote harness. Make sense, see collectively we can solve any issue or.make it alot worse. Lol. Glad we have this resource to solving this stuff. Cheers
    Vahret832 likes this.
  21. Sep 9, 2022 at 9:11 PM
    #171
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    So is this located in the passenger footwell? I’m gonna tackle this soon since I don’t run sensors
  22. Sep 10, 2022 at 12:38 AM
    #172
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    It is located up behind glove box. You will know your in the right area when you see the bright yellow wiring from the airbags. Do not touch those. Tpms is a small little grayish box with wiring harness. Refer to previous posted pics in this discussion. It's worth reading all the posts before starting. Good luck.
    CaptRussia253 and reywcms like this.
  23. Oct 21, 2022 at 8:06 AM
    #173
    sonofdad
    sonofdad New Member
    steamboat springs, co
    2017 Tundra SR5
    tackled this yesterday. my TPMS warning light is off!
    thank you to everyone here that provided info on how to do this!
    the tip to use posi-taps was a especially helpful - i'd never used them before.
    the only real difficulty (other than contorting myself to do the work from the passenger foot well :eek2:) was stripping the light green wire. my wire stripper wouldn't handle a wire this small and had to resort to using a box cutter blade.
    appreciate all of the knowledge on this site - thank you!
  24. Oct 21, 2022 at 8:25 AM
    #174
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    Hey Glad it worked out for you. It's a huge sigh of relief when it's done. I had same issue with green wire too so I positaped it as well and just ran a bigger guage of wire between the 2 positaps. If ever I want want to restore to original set up, I will just undo positap on the yellow wire and tap the end of the green wire that I cut then it's restored.
    Happy cruising without the yellow dash light !!!
    sonofdad[QUOTED] likes this.
  25. Oct 21, 2022 at 8:47 AM
    #175
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    Can someone point me in the right direction for removing glove box? please and thank you
  26. Oct 21, 2022 at 8:51 AM
    #176
    sonofdad
    sonofdad New Member
    2017 Tundra SR5
    i didn't remove the glove box, just the trim piece below it. i suppose removing the glove box would give you more room to work, but i was lazy and didn't want to pull off any more bits than i had to:D
    it'll be obvious once you crawl in there and look up - i can take a photo of that bit if you need more info. good luck :thumbsup:
  27. Oct 21, 2022 at 9:05 AM
    #177
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    I only removed the lower trim piece under the glove box as well. Honestly you should be able to do it that way. I'm a big guy and was successful just with the seat pushed back out of the way. Having a good light is very helpful too. Good luck !!
    sonofdad likes this.
  28. Oct 22, 2022 at 10:01 AM
    #178
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    I wanna send BIG HUGE THANK YOU to all those who contributed to this thread. I just did it, and it works like a charm! (2016 SR5)
    My wiring looks exactly like @CaptRussia253 's pics in post #164, except I didn't use the big red connector like he did. I just scraped some insulation off the yellow wire and wrapped the light green wire around it. I came at it from underneath, not through the glove box, and the access panel is easy. No single-use plastic rivets to deal with.
    FWIW, I had my sensors in a "pipe bomb" and that method was working fine. But I like this better for several reasons.
    THANK YOU!!
  29. Oct 22, 2022 at 12:51 PM
    #179
    Gene_in_FL
    FLORIDA
    Funny, I was just thinking about Grasshopper and the pebbles yesterday. What a great show. And what an ignominious death for David Carradine. :(
    Sierradevil likes this.
  30. Oct 22, 2022 at 3:30 PM
    #180
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Anyone with the nerve to do this, there are great little wire 'T' taps called 'Posi-Taps'. Seems perfect for tapping into the two wires leaving only a pinhole if you need to go back.
    Next Day: I see someone already posted the Posi-Taps idea here.....Hey another vote for Posi-Taps being decent quality.
    Posi-Tap
    Sierradevil and Gene_in_FL like this.
