Diode Dynamics SS3 SAE Pro fog lights installed. Update 4/17/21. Now with SS3 Max.
Discussion in 'Lighting' started by Danman34, Dec 13, 2019.
  1. Dec 6, 2021 at 12:29 PM
    #601
    kwan_918
    kwan_918 New Member
    Is that the DD bar? Any wobble? I have the NSV in the garage waiting to go on, but that space is calling for something and love the idea of an amber driving light.
    Looks awesome!!!!!
    Danman34[QUOTED][OP] likes this.
  2. Dec 6, 2021 at 12:32 PM
    #602
    Danman34
    Danman34 [OP] New Member
    Danny
    2018 White Tundra TRD Sport
    Yes. It’s the DD 30” stage series light bar with the stealth kit brackets. No wobble that I can tell. The 30” bar and bracket seems to be more rigid than the 42” counterpart. Which makes sense seeing as how the span and weight of the bar is greater with the 42”. This one seems pretty solid.
    HulkSmurf14 likes this.
  3. Dec 6, 2021 at 12:40 PM
    #603
    kwan_918
    kwan_918 New Member
    Great, thanks for the feedback!
  4. Dec 6, 2021 at 3:27 PM
    #604
    kwan_918
    kwan_918 New Member
    I looked at multiple posts during my research so wanted to post a before and after for my Pro’s (also on another thread). The OE LED’s weren’t bad but the DD Pro’s are noticeably better…I bet the Max would rock too. The vertical wasn't as bad as I thought it could be; really happy with my purchase.
    Savmikey47 and bulldog93 like this.
  5. Dec 6, 2021 at 4:00 PM
    #605
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    These pros are definitely bright
    kwan_918 likes this.
  6. Dec 22, 2021 at 3:55 PM
    #606
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    How does the white match the factory LEDs? I see a ton of pics in amber. I'm looking to go with the white bit I want them to match. Out pit pics (pro preferred) in white with the factory LEDs would be much appreciated. Thanks
  7. Dec 22, 2021 at 3:57 PM
    #607
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Color temp of SS3s in white is going to be right in-line with your OEM LED output. Will actually be a tad more white than blue though.
    bulldog93 likes this.
  8. Dec 22, 2021 at 4:49 PM
    #608
    Danman34
    Danny
    Oem leds are around 6300k. White SS3s are 6000k. You won’t notice a difference.
  9. Dec 22, 2021 at 6:08 PM
    #609
    94slowbra
    john
    new orleans
    2016 TRD pro
    So, close enough. I hate lights that don't match. Hopefully someone has a poc they can throw up here.
  10. Dec 29, 2021 at 3:10 PM
    #610
    Ronster
    Ronster New Member
    Ron
    2017 Tundra Crewmax
    What’s the current lead time on the SS3 Pro Amber fogs? No backlight. Thanks.
  11. Dec 29, 2021 at 3:46 PM
    #611
    memario1214
    Colton
    Missoula, MT
    If you order from us here at Hotshot Offroad it'll be about a week. It would normally be ZERO lead time, but we have been waiting on a pallet to show up that has been stuck in SLC for almost 2 weeks now.
    Ronster[QUOTED] and HulkSmurf14 like this.
  12. Jun 1, 2022 at 7:30 AM
    #612
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    So I'm looking. Can someone explain "-Amber Backlight -" option for dd amber fog lights ..
  13. Jun 1, 2022 at 7:34 AM
    #613
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    All it means is when it's "off" it glows a subtle amber color as backlighting (not really on, but a night-light-esque "on")...when you turn them on, they blast out the amber color...think of it as a "soft off."
  14. Jun 1, 2022 at 7:36 AM
    #614
    memario1214
    Colton
    Missoula, MT
    Here is the same light. One with the backlight on, and one with the main beam on. Then of course there would be everything off (not pictured). You have the opportunity to wire them however you'd like via wire tap, but most folks will tap either their parking light or DRL for activation. It is a strictly aesthetic feature.
    texasrho83, bulldog93 and HulkSmurf14 like this.
  15. Jun 1, 2022 at 7:41 AM
    #615
    HulkSmurf14
    2014 Tundra Limited
    WAY BETTER THAN WORDS!
    Sonicbluerider and memario1214 like this.
  16. Jun 9, 2022 at 9:59 AM
    #616
    Flyinhigh90
    Flyinhigh90 New Member
    Eli
    2018 tundra crew max
    BDS 7 inch coil over lift 20 inch XD820
    I could not find what parking light wire to tap into for mine having troubles
  17. Nov 5, 2022 at 8:42 PM
    #617
    Onelook2213
    Onelook2213 New Member
    Andres
    2014 sequoia limited
    Can you have amber backlight with white leds ? And what is driving white compared to regular white?
    Thanks
  18. Jan 25, 2024 at 6:06 AM
    #618
    Critical05
    Critical05 New Member
    2018 MGM TRD Sport, Crewmax 4x4
    Just a sanity check, have SS3 Pro yellows installed since 2020. I intermittingly use them when needed, can't imagine i have over 20 hours on them, do led's performance degrade over time?
    When first installed, they used to over power my headlights and everything was lit up and yellow. Now, they seem less intense to me, a good fog light but not as bright as when i first installed them. I checked and all 4 led emitters are working.
  19. Jan 25, 2024 at 6:09 AM
    #619
    HulkSmurf14
    2014 Tundra Limited
    They degrade less then halogens - almost not at all...clean your lens and typically, it's from abrasion of road debris that causes the output seeming to be less. Another thing to constantly check is your battery voltage and fuses used to protect the circuit...even making sure wires are tightly connected and not corroding are good yearly maintenance items...always easier said than done though...I know I don't do that but really should...
    BillyB and bulldog93 like this.
  20. Jan 25, 2024 at 7:26 AM
    #620
    Danman34
    Danny
    Check voltage at the connection. If it’s not getting the full running voltage, they will light up, but won’t be at their full potential. Could have some corrosion causing a voltage drop across the terminal. I’ve had mine for years and never noticed any real decrease in lighting.
    BillyB, bulldog93 and HulkSmurf14 like this.
  21. Jan 25, 2024 at 9:09 AM
    #621
    AlrightAlrightAlright
    AlrightAlrightAlright New Member
    Northwest Arkansas
    2020 SSM DC 4x4 with SR5 Upgrade Package
    RetraxONE MX retractable bed cover TRD Rear sway bar Debadged FabFours Matrix front bumper Smittybilt 9,500# XRC winch Aries 30" light bar (internal bumper mount) Diode Dynamics SS3 3" SAE Fog and Driving lights ConsoleVault RhinoRack crossbars
    Id take a close look at those lenses like @HulkSmurf14 mentioned above. I got covers for mine when I got them from @memario1214 at Hot Shot Offroad… maybe it’s the wear and tear on lenses due to rock chuckers and road debris?
    If it is, maybe you can use a headlight polishing kit to put off having to buying new lenses.
  22. Jan 25, 2024 at 10:29 AM
    #622
    Critical05
    Thanks guys for the suggestion. I checked the lenses and they had a film of grime on them so I polished them up a bit. The surface is ribbed so the grooves were dirty. Alot of melting snow so its hard to keep things clean, will see tomorrow morning if it helped.
    Both lights are the same brightness and I used di-electric grease on the connectors at install. I cleaned up the fuse contactor at break.
  23. Jan 25, 2024 at 6:06 PM
    #623
    Northwest Arkansas
    I’ll be curious what you find out. @crashnburn80 over on the Tacoma World forum did several *very* extensive analyses on lighting, truly scientific works of art if you want to review it. Being an automotive lighting engineer, he’s kind of the ”Guitar George who knows all the chords” when it comes to this stuff. Between him and Colton over at Hot Shot, I think the DDs I ended up getting were perfect for my setup and are holding up nicely. Post back and let us know, brother!
  24. Jan 26, 2024 at 5:59 AM
    #624
    Diode Dynamics
    Diode Dynamics New Member
    Please feel free to go ahead and give us a call at 314-205-3033 Monday-Friday 10 a.m.- 5 p.m. CST, or shoot us an email at contact@diodedynamics.com, and our in-house US service team would be happy to help you with that. If there is an issue, you're covered by our hassle-free 8-year warranty!
    Hours: Monday-Friday 10 a.m. - 5 p.m. CDT
    Email: contact@diodedynamics.com
    Phone: 314-205-3033
  25. Jan 26, 2024 at 6:49 AM
    #625
    Northwest Arkansas
    This is a sign of a great company here, guys. Just sayin’
  26. Jan 26, 2024 at 10:53 AM
    #626
    Critical05
    Thanks everyone for the reponses. I think it might have been a combination of things making me feel they weren't as vivid as before:
    - grime/film on the lenses
    - wet road conditions, causing more light scattering
  27. Jan 27, 2024 at 11:24 AM
    #627
    JEHTUNDRA
    JEHTUNDRA New Member
    2021 Crewmax SR5 4x4
    I want to order a set of the SS3 Pro or Max. Haven’t made up my mind. Does anybody know where the best deal is currently?
  28. Jan 29, 2024 at 9:50 AM
    #628
    memario1214
    Colton
    Missoula, MT
    We offer deals to forum members everyday over here at Hotshot Offroad! Shoot me a message with your zip and whether or not you want the backlight and I can get some numbers over to you. :thumbsup:
  29. Jan 29, 2024 at 9:10 PM
    #629
    Savmikey47
    Savmikey47 New Member
    This looks amazing
  30. Jan 30, 2024 at 7:36 PM
    #630
    Savmikey47
    Just ordered my ss3 pros in amber from hotshot. Great customer service. Can’t wait to get it and install them. @memario1214
