Diode Dynamics SS3 SAE Pro fog lights installed. Update 4/17/21. Now with SS3 Max.
Discussion in 'Lighting' started by Danman34, Dec 13, 2019.
  1. Sep 12, 2021 at 1:04 PM
    #571
    20Tundra_sauce21
    20Tundra_sauce21 New Member
    Great choice on the DD SS3, I love mines!
    What @memario1214 said or if you’re like me you could have 2 pairs of fog lights in case you might need them lol.
    RogueAngler[QUOTED] likes this.
  2. Sep 12, 2021 at 1:06 PM
    #572
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    RogueAngler and Squatting Pigeon like this.
  3. Sep 12, 2021 at 1:14 PM
    #573
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    I put them in a box and carted them to the new place just this morning. You know a guy? :spy:
  4. Sep 12, 2021 at 1:25 PM
    #574
    memario1214
    Colton
    Missoula, MT
    Yes. @RogueAngler needs em!
  5. Sep 12, 2021 at 2:08 PM
    #575
    RogueAngler
    RogueAngler New Member
    @NESURFPRO
    2021 MGM TRD Pro DC
    Tint (3M) to VA limits TRD rear sway bar AJT Design chrome delete; all black TRD shifter Coachbuilder trd pro kit with Bora spacers Toyo OC AT3s CBI overland rock sliders Ordered: UpTop overland Alpha roof rack with Baha lights Considering: RSi SmartCap
    I placed an order today with Sparks but I’m sure I can cancel tomorrow morning if good chance of finding some out there with the brothers. I am hoping to do install next weekend at latest in advance of fishing trip. Open to ideas. Appreciate it.
    Sparks Parts numbers are 52127-0C070 and 52128-0C070.
    COTundra23 and Squatting Pigeon like this.
  6. Sep 12, 2021 at 2:11 PM
    #576
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Give sparks a shout tomorrow and see about canceling. I’m happy to unload mine to ya :D
  7. Sep 12, 2021 at 3:57 PM
    #577
    infidel
    infidel New Member
    Jesse
    SE Wisconsin
    2016 Silver SR5 Crewmax
    Procomp 3/1 Method 307 18x9 +25 Falken Wildpeak AT3W 295/70r18
    What a guy
  8. Sep 17, 2021 at 11:30 AM
    #578
    TRDSPEC
    TRDSPEC New Member
    Or with a bit of fabrication and cussing you can maintain the Pro bezels with the DD fogs using their SS3 Universal Bracket kit and a bit of bracketry that you'll have to fabricate like found in the following thread. It's a tight fit and you wont be able to use the brackets listed in the thread because they are installing the Rigid fogs. But you might find what you need to do similar at your local hardware store.
    https://www.tundras.com/threads/diy-rigid-trd-pro-fog-lights-brackets.37902/
    Tip: I mounted from the top vs. from the bottom as they did in the Rigid thread. This is due to the geometry of the SS3 brackets vs. the Rigid.
    They will sit outside of the Pro bezels slightly, but I think you wind up with better light throw to the sides that might be blocked some by the stock round bezels.
    SS3 Max Fogs in Pro bezels
  9. Sep 17, 2021 at 1:13 PM
    #579
    Southbound1
    Southbound1 New Member
    2016 Limited
    Installed the SS3 pros, very impressed with the quality and light output. FYI when I went to remove the fender liner a couple of bolts were seized so I just popped the bezels out from the front switched lights and snapped back in, took about 10 minutes. I tried to aim them as far down as I could in the housing and the alignment worked out perfect, then I zip tied them in place
    memario1214 likes this.
  10. Sep 19, 2021 at 8:12 AM
    #580
    memario1214
    Colton
    Missoula, MT
    Yes. Yes you should! I’m your hook up when you do it! :cool:
    whitetundy808[QUOTED] likes this.
  11. Sep 20, 2021 at 10:00 AM
    #581
    Southbound1
    2016 Limited
    Money well spent
    20Tundra_sauce21 likes this.
  12. Sep 23, 2021 at 10:29 AM
    #582
    SubDubba Bubba
    SubDubba Bubba New Member
    2010 Tundra Platinum
    I installed a pair of Diode Dynamics SS3 Pro yellow fog lamps in my 2010 CM Platinum a couple weeks ago and finally took a snap of the lights on the road. Nice side to side lighting with a crisp horizontal cut-off. I adjusted the fog lights to the lowest possible angle. A few days later I did the EddieV1 fog lamp wiring modification. Worked as advertised. I called Colton @memario1214 at Hotshot Offroad and he took good care of my order. Colton is a good guy to do business with and is highly recommended. And a BIG thanks to all the members of this forum who share their talent and experience. There's plenty of good information here.
  13. Sep 23, 2021 at 1:53 PM
    #583
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    what's the "EddieV1 fog lamp wiring modification"?
  14. Sep 23, 2021 at 1:59 PM
    #584
    infidel
    infidel New Member
    Jesse
    SE Wisconsin
    You can jump out a couple wires and such and it allows the fogs to stay on with your marker lights and brights.
    kuokoa[QUOTED] and Barrett50 like this.
  15. Sep 23, 2021 at 3:14 PM
    #585
    SubDubba Bubba
    Silver4x4trd and Barrett50 like this.
  16. Sep 23, 2021 at 3:43 PM
    #586
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    A must do with good fogs!!
  17. Sep 24, 2021 at 1:27 AM
    #587
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    interesting. so you can turn the fogs off and on, while the parking lights and high beams are on?
    I did this one, which was just using some jumper wires in the fuse box. basically, fogs are always on (can't turn it off or on with the stalk) when the parking/low/high beams are on:
    https://www.tundras.com/threads/easy-5-min-anytime-fog-light-relay-mod-diy.20508/page-7#post-1534277
  18. Oct 4, 2021 at 5:47 AM
    #588
    fmscott2
    fmscott2 New Member
    Anyone have the behind-the-grille Diode Dynamics light bars? I have their amber fog pattern light bars and was wondering which of their SS3 fog lights would be a good pairing. I also have the OEM LED headlights. I’m thinking the white spot/driving pattern would be good since I already have a good wide fog pattern in amber so a light to reach out a little further directly in front would be the icing on the cake.
    Are the Max lights worth it over the Pros?
  19. Oct 4, 2021 at 6:55 AM
    #589
    Danman34
    Danman34 [OP] New Member
    Danny
    2018 White Tundra TRD Sport
    Pro vs Max. Notice the intensity of light on the fence with the max.
    HulkSmurf14 likes this.
  20. Oct 4, 2021 at 7:12 AM
    #590
    memario1214
    Colton
    Missoula, MT
    Hello there! So @Danman34 gave you some nice comparison shots there! The Max definitely has a tighter beam and less uplight/diffusion which is nice. Is it WORTH it? That's up to you. If you go Max you'll never be left wondering "what if", but if you go pro you still won't be disappointed in the output. They're great.
    As for what to do with pattern here is what I would do if I were you:
    • Make your selection on fog lights (pro vs max and color) and go with just that. An SAE Fog pattern fog light mounted in your stock fog light location. When properly aimed you will be legally able to run them on the street if you so desire.
    • Make a small swap on your light bars that are in the grille. I recommend swapping the lenses over to a driving pattern. I would recommend white, but if you want yellow that's okay too. A lens swap is pretty inexpensive on the Stage Series light bars with the lenses being $3 apiece + some shipping.
    Shameless plug I carry all of these goodies too :)
  21. Oct 4, 2021 at 9:25 AM
    #591
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I have the Pros on my 2014 in no different of configuration from the OEM setup...my inquiry is, with no wires crisscrossed, modified, or changed from OEM, when I engage my fogs, my radio begins to squelch a lot and immediately stops once I toggle the fogs off...ground deal or...? Any suggestions?
  22. Oct 4, 2021 at 9:41 AM
    #592
    memario1214
    Colton
    Missoula, MT
    Almost always a ground issue when someone mentions similar issues. Try this first. Try swapping the adapter harnesses from left to right and let me know what happens. We'll troubleshoot from there.
    HulkSmurf14[QUOTED] likes this.
  23. Oct 4, 2021 at 9:44 AM
    #593
    HulkSmurf14
    2014 Tundra Limited
    I assumed that's the first test...I just noticed it this morning headed to work and have run them every week headed to work this whole last year...not sure what could've changed but I'll try it out..I need to secure the darn lights a bit better anyway with some super-hero zipties...I will share my findings this coming weekend...Thanks Colton!
  24. Oct 4, 2021 at 9:47 AM
    #594
    memario1214
    Colton
    Missoula, MT
    Worse comes to worse just buzz on over here and we'll get it whipped into shape! :rofl:
  25. Oct 4, 2021 at 9:47 AM
    #595
    HulkSmurf14
    2014 Tundra Limited
    Hahaha Deal!
  26. Oct 4, 2021 at 9:02 PM
    #596
    kmeindin
    kmeindin New Member
    Ken
    2021 Tundra Trail - Cement
    Lomax Cover, Adarac Rails, Yakima Bike Racks, Undercoat, 3M PP, Step
    I just order some Pro Yellow Fog can't wait to get them
    Jr3volution likes this.
  27. Nov 26, 2021 at 2:06 PM
    #597
    kwan_918
    kwan_918 New Member
    Great thread - just ordered my Yellow SS3 Pro Fogs from @memario1214 (Hotshot Offroad)!
  28. Dec 6, 2021 at 12:24 PM
    #598
    Danman34
    Danny
    Added a 30” Amber driving to complement the max fogs.
  29. Dec 6, 2021 at 12:26 PM
    #599
    memario1214
    Colton
    Missoula, MT
    :militarypress::militarypress:
    Danman34[QUOTED][OP] likes this.
  30. Dec 6, 2021 at 12:28 PM
    #600
    Danman34
    Danny
    I don’t waste no time. Haha.
