Diode Dynamic 42” stealth light bar questions?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rangergillikin, Sep 7, 2022.
  1. Oct 29, 2022 at 3:51 AM
    #61
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Following along here, I'm also interested. Thanks!
  2. Oct 29, 2022 at 5:37 AM
    #62
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    Me too me too!!!
  3. Oct 29, 2022 at 6:07 AM
    #63
    MedCityMoto
    Out of curiosity, I see other threads mentioning less expensive versions of the 42" lightbar made with the same outer case, and I'm curious to look at them if anyone's got a link? $500's steep enough to warrant considering alternatives.
  4. Oct 29, 2022 at 6:17 AM
    #64
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    Sure there are alternatives but I've learned a while back. Buy once cry once
  5. Oct 29, 2022 at 6:27 AM
    #65
    MedCityMoto
    It depends on who makes the alternatives, which is why it's worth considering them. Let's say Rigid makes one for $300, same outside shell, you still think the $500 Diode Dynamics is the only reasonable option? =) Hence inquiring what others that've been spotted.
    Rangergillikin[OP] likes this.
  6. Nov 4, 2022 at 5:18 PM
    #66
    SnowSquach
    SnowSquach New Member
    Upstate, NY
    2021 Super White TRD Pro
    Wireless Charger Ride-Rite Airbags with Dynastar Cradles Westcott 1.5" Front Lift Coachbuilder +3 Shackles Gator Cover Swingbox Tailgate Power Lock
    Following
  7. Nov 5, 2022 at 1:04 AM
    #67
    Rangergillikin
    Rangergillikin [OP] New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    I know what you are saying. I try to save money were I can. The problem with cheaper lights is that they seem like they have a problem with getting moisture inside the housing. I really don’t understand why it’s so had for these companies to make a water tight housing. The other big problem with cheaper lights is that they alway over exaggerate the Lumin output. They will list specs on their led chips with a lumin rating thats not even close to what a led can physically produce with out meltdown within a few seconds. I wish they would make these companies have some kind of certification to back up their claims. They don’t so they can just throw out any watt or lumin output they want on the description. If you watch some test reviews on YouTube you will see that most don’t even come close to what they claim. It’s just false advertising. I’ve been buying led hand held lights ever since they claim out and that is a big problem in the led light industry. If your just getting a light for the looks then cheap is the way to go as long as you take some extra precautions to seal it up yourself with some extra silicon. Some other things to consider is the coating used on the housing and the wiring. Cheaper lights don’t always come with the best coating and have very small gauge wiring or aluminum wiring that is just awful. The coatings don’t holdup as good to the elements and end up looking bad . I’ve bought cheap leds before and have had to deal with the thin cheap wiring. It’s a pain to splice and solder. Other problems that is not mentioned much about led is the quality of the driver that are running the lights. Driver are what controls the amount of power going to the leds and also stepping down light output for thermal protection. They are the heart of the lights. To me a $500 range Light bar is a cheap price for a reputable company that stands behind their product and has a good warranty considering the price of each LED chip, drivers, reflectors, housing, heat sinks, wiring harness, plugs, mounts, coating quality, assembly, lenses, and testing. If a light bar is only a couple of hundred then you know they are cutting a lot of corners somewhere and is probably just making up a lumin output to be able to sell it that cheap. A Nitecore TM28 4 led hand held flashlight that is 6,000 lumins (that has been measured in accordance to the international flashlight testing standards ANSI/NEMA FL1) cost $390. A Gehavin Tactical flashlight off Amazon that has 1 led chip that they claim will produce 150,000 lumin of output with no certification is $59. Light company can make any kind of claims they want to about their measurements because their is no law requiring them to have their claims back up by standardized test. I only go with company’s that test their products with recognized testing standard. There is a lot of ripoff company’s out there trying to get your money. I watched one YouTube video that tested lights of all kinds of brands and almost every cheap Chinese brand light only really produced about 1/10 of what they claimed their light would produced. All of the reputable companies that were higher in price were pretty much spot on with their claims. Warranty and customer service is also something to consider. If I have problem with a product I want to be able to talk to someone in the US that will stand behind their product. It’s also really nice that, if I have a problem with one of my lights, I can reach out to them right here on this forum. Can’t do that with those cheap lights. I’m not trying to talk you into buying more expensive light by any means just wanted to share my thoughts about cheap lights. I’ve already dealt with buying cheap lights.
  8. Nov 10, 2022 at 12:42 PM
    #68
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    MedCityMoto likes this.
