Diff fluids, transfer case fluid, plugs
Discussion in '2.5 Gen Tundras (2014-2021)' started by apbreaux, Apr 1, 2019.
  1. May 15, 2019 at 5:27 AM
    #61
    buffaluphagus
    buffaluphagus —————————————
    Do the transfer case plugs use washers?
  2. May 15, 2019 at 5:33 AM
    #62
    15whtrd
    15whtrd Mr. Blonde
    14 and up have a different TC. Pipe plugs, no washers.
    buffaluphagus[QUOTED] likes this.
  3. May 15, 2019 at 3:01 PM
    #63
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    If it’s sealed oil then no
    apbreaux[OP] likes this.
  4. May 21, 2019 at 7:00 AM
    #64
    offsetplayer2
    offsetplayer2 New Member
    Woods and Fields, NC
    2018 Inferno CM 4WD
    Didn't think so. It's sealed so should be good to go. thanks.
  5. Sep 1, 2019 at 8:00 AM
    #65
    apbreaux
    apbreaux [OP] New Member
    Paul
    CO
    2016 Tundra DC
    Intake, exhaust, remote starter, LEDs everywhere, OVTune
    This is older post, but feel I should update. Goldplugs finally did get back to me. They refunded me for the plugs I sent back. I had email correspondence with Tim, and he was helpful.
  6. Sep 1, 2019 at 8:09 AM
    #66
    apbreaux
    Paul
    CO
    2016 Tundra DC
    Thanks, again, for this tip. I recently changed the oil in the Tundra and Passat, and put this to use. I'll see how things look in 5K miles.
  7. Oct 7, 2019 at 12:42 PM
    #67
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    In case anyone else finds this useful. i made this for my own reference. torque and toyota part numbers included.
    edit: I use Ravenol oil, since they sell both the 75W-85 (vs 90) and the SAE 75W for the transfer case.
  8. Oct 7, 2019 at 12:51 PM
    #68
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Thanks! I just did mine and having this in one place would have been helpful.
  9. Oct 8, 2019 at 5:17 PM
    #69
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    Awesome...thanks, brother!
  10. Apr 30, 2022 at 7:51 AM
    #70
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Bump, for anyone about to drain and fill both diffs and the TC. Highly useful. Thanks! :cheers:
    BTBAKER likes this.
  11. May 1, 2022 at 5:29 AM
    #71
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Thanks. It is useful. Is it possible to torque the T case plug? I just ran it back to where it was when I pulled it.
  12. May 1, 2022 at 6:41 AM
    #72
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Old post I know, but care to mention the best place to buy some Red Line?
  13. May 1, 2022 at 6:43 AM
    #73
    Terndrerrr
    Music City
    6UR-FE
    Probably your safest bet. Some guys put some Teflon tape on it as well.
  14. May 1, 2022 at 9:16 AM
    #74
    BIGUGLY
    Paul
    2018 Limited
    Amazon sells redline. you can buy direct from them. Otherwise other parts sellers, jegs, summit and the like
  15. May 1, 2022 at 2:03 PM
    #75
    2017_Tundra_AZ
    2017_Tundra_AZ New Member
    How often do you all change your Trans/Transfer case/Diff oils? More often than what the manual says?
