Diff fluids, transfer case fluid, plugs
Discussion in '2.5 Gen Tundras (2014-2021)' started by apbreaux, Apr 1, 2019.
  1. Apr 1, 2019 at 8:04 AM
    apbreaux
    apbreaux [OP] New Member
    Paul
    CO
    2016 Tundra DC
    Intake, exhaust, remote starter, LEDs everywhere, OVTune
    As always, please direct me to existing thread if out there...
    For 2016 Tundra, DC: I'm changing the fluids in the diffs and transfer case: What is the best brand/viscosity to use?
    Is there a magnetic drain plug for all these you recommend?
    Thanks.
  2. Apr 1, 2019 at 8:48 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  3. Apr 1, 2019 at 9:25 AM
    apbreaux
    Paul
    CO
    2016 Tundra DC
  4. Apr 1, 2019 at 9:37 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    For the 75w you have 2 options: Toyota stuff $$ or Ravenol
    For the diffs, all personal reference to be honest. Lots of guys LOVE Amsoil, RP, Mobile1...etc
    SteyrM40A1, BTBAKER and 15whtrd like this.
  5. Apr 1, 2019 at 9:41 AM
    matrdguy
    matrdguy New Member
    Pete
    'The Notch' Western MA
    MGM 2016 Tundra Platinum 1794 Edition
    18" TRD Wheels, Falken Wildpeak AT3 275 75 18, Westin Bed Rug with Linex, Window Vents, TRD Sway Bar, Bilstein 6112/5100 CB +3 shackels, CB Shims, Chrome Tailgate Letters. More To Come....
    I just did mine this weekend... I ran the RedLine 75W85 Synthetic in Front and Rear Diffs ( I believe Manual recommends 75w85)....
    Transfer Case I used the Ravenol 75W ( got it on Amazon ( has really cool pour spout in it)
    Front and rear diffs have magnet on the drain plug. make sure you clean it off before re filling diffs
    equin and 15whtrd like this.
  6. Apr 1, 2019 at 9:42 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    I'm using the Ravenol right now as well, 6Tmiles issue free so far!
    15whtrd likes this.
  7. Apr 1, 2019 at 9:52 AM
    matrdguy
    matrdguy New Member
    Pete
    Here is what my rear diff drain plug looked like 2016 CM 45000 and never been changed ( got changed this weekend)
    Couple large metal flakes, but I figured its clean now... 20190330_152941.jpg
  8. Apr 1, 2019 at 9:55 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Wow! or Eeww! Good thing it's clean oil now!!!
  9. Apr 1, 2019 at 9:57 AM
    15whtrd
    15whtrd Mr. Blonde
    That doesn’t look too bad. Looks like a mixture of fine metal shavings and assembly grease.
    831Tun and JohnLakeman like this.
  10. Apr 1, 2019 at 10:03 AM
    matrdguy
    matrdguy New Member
    Pete
    I may just run 5-10K on it and re check it and replace diff fluid if needed. We will see..... the 'Seat of the Pants Dyno' seems to feel that the shifting is smoother and the switching in and out of 4x4 is smoother too..
  11. Apr 1, 2019 at 10:08 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Unless you are running a heck of lot of miles in 4wd I would not mess with the tcase. I don't run as many miles in 4wd as someone in snow country does but I use it fairly often. At 50k on my Tacoma it was spotless.
    Tierhog likes this.
  12. Apr 1, 2019 at 10:29 AM
    matrdguy
    matrdguy New Member
    Pete
    I am IN Snow country ( New England)... one of the last storms of 2018 I ran from TN to MA all in 4wd...due to the 6-8" of snow.. for the couple bucks in 75W.... I just change it... peace of mind to me
  13. Apr 6, 2019 at 7:18 AM
    apbreaux
    Paul
    CO
    2016 Tundra DC
    Thanks for info. The only thing that gives me pause about the Ravenol is that it seems to be made for German makes. I'd love more info re: Ravenol, your experiences with it, etc. Please let me know.
    That being said, after much research, I found that no one makes a specific T-case oil for the Tundra. Apparently, Toyota has kept this recipe a secret. I ended up going to the local Toyota dealership. They don't even use Toyota's T-case oil - said it's too damn expensive to recommend to customers ($75/quarts, 2x quarts needed). They use BG 75W-90, 2 quart container, $90. Said they've been using it for years, trouble-free. So with the knowledge I have at this point, I'm deciding to use Amsoil 75W-90 for diffs and T-case. Anybody have any evidence why 75 may be better to use than 75W-90?
  14. Apr 6, 2019 at 7:25 AM
    matrdguy
    matrdguy New Member
    Pete
  15. Apr 6, 2019 at 7:30 AM
    15whtrd
    15whtrd Mr. Blonde
    Don’t do it man. That’s what I did, I went off of a write up from the second GEN assuming the same transfer cases. They are not. I put in the same stuff I put in my front and rear differential 75W-90 royal purple. I click my truck into 4 x 4 on a straight piece of road on the way to work occasionally just to keep it lubed up. I could feel the truck pulling to the right or left. Also it would not disengage 4x4 until I made a turn. The 4hi light would flash until I did. Then you would hear a clunk and the light would go off.
    Switched out to 75W Ravenol, and now all above, is now smooth operation.
    Joe333x, BTBAKER and 831Tun like this.
  16. Apr 6, 2019 at 7:35 AM
    apbreaux
    Paul
    CO
    2016 Tundra DC
  17. Apr 6, 2019 at 7:37 AM
    apbreaux
    Paul
    CO
    2016 Tundra DC
    Appreciate it. Does indeed look like this is compatible with Tundra. Will give it a shot.
    15whtrd[QUOTED] likes this.
  18. Apr 6, 2019 at 7:42 AM
    15whtrd
    15whtrd Mr. Blonde
    It does suck that you can’t just use the same fluid for the differentials. But I highly recommend either using this or the ridiculously expensive Toyota version. Nothing less.
    Ely010606 and BTBAKER like this.
  19. Apr 6, 2019 at 7:44 AM
    apbreaux
    Paul
    CO
    2016 Tundra DC
    For sure. Just ordered from Amazon. Thanks again for info. Much appreciated.
  20. Apr 6, 2019 at 7:48 AM
    15whtrd
    15whtrd Mr. Blonde
    No problem bud!
  21. Apr 6, 2019 at 11:36 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Sounds like that's cleared up!
    15whtrd likes this.
  22. Apr 6, 2019 at 4:11 PM
    apbreaux
    Paul
    CO
    2016 Tundra DC
    For sure.
    15whtrd likes this.
  23. Apr 6, 2019 at 5:29 PM
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    Dimple magnets if your willing to spend the money. Please review Toyota OEM voa vs Ravenol voa I posted in transfer case thread. I use Red Line 75w80 mtl and sticking to it. I can post someones Red Line voa if you would like to compare.
    UTTundra likes this.
  24. Apr 6, 2019 at 7:40 PM
    apbreaux
    Paul
    CO
    2016 Tundra DC
    Hadn't heard of Dimple. However, ordered Gold Plugs (https://goldplug.com/), about $20 a piece, for diffs, tcase, tranny, oil pan. If nothing else will make me feel better. They look to be of decent quality. Going with Ravenol 75W for Tcase. What is VOA?
  25. Apr 6, 2019 at 10:26 PM
    acmesupply
    Look up my past posts ref virgin oil analysis.
    I wish I could link and post but i am still learning the forum format. Btanchors did quite a lot of work and research. Look up my old post history to see that Ravenol is not in my opinion that good compared to Toyota OEM TC fluid. I paid for the VOA on the Ravenol. Anymore info please ask anything.
  26. Apr 6, 2019 at 10:43 PM
    matrdguy
    matrdguy New Member
    Pete
    Can you provide some more insite into this ? or any other Information ? I'm interested !!...
    I dont want to keep beating a dead horse...its just 75W Transfer case oil, but I'm still interested..
  27. Apr 6, 2019 at 11:55 PM
    acmesupply
    Toyota OEM is approx 60 a quart. Straight ,unknown mineral, semi, synthetic, 75w very fortified for what Borg Warner spec'd for 2014 and later TC cases.
    Ravenol is 15-20 a quart , straight 75w synthetic manual transmission fluid.
    Red Line is 20 plus a quart 75w-80 synthetic manual transmission fluid more fortified and closer to specs of Toyota OEM fluid.
  28. Apr 7, 2019 at 12:11 AM
    matrdguy
    matrdguy New Member
    Pete
    Yes, and Thank you for the reply.. I read both VOA and saw some values were higher for some additives ( in the Toyota Fluid), however in the comment section of the Blackstone report it states that is is fine for its intended use.
    I'm not sharpshooting you by any means, you have gone far and above what most would do and I appreciate your efforts in getting us ( ppl on this forum) the best information.
    Thank you for your time and effort
  29. Apr 7, 2019 at 6:56 AM
    apbreaux
    Paul
    CO
    2016 Tundra DC
    Again, thanks for clarification on this. I tend to continue research after I've purchased something, and I found that I was looking at two different bottles. One is the pic you have above. The other is this:
    https://www.amazon.com/Ravenol-J1C1...+Line|TOYOTA&rnid=2528832011&s=gateway&sr=8-1
    This is "Transfer Case Oil" from Ravenol. Looks to be for the Germans. Wonder what the difference is between this and the manual fluid?
  30. Apr 7, 2019 at 6:58 AM
    apbreaux
    Paul
    CO
    2016 Tundra DC
    Thanks.
