Delayed door lock response from key fob on brand new truck
Discussion in '2.5 Gen Tundras (2014-2021)' started by Redline870, Nov 14, 2021.
  1. Nov 14, 2021 at 3:32 PM
    Redline870
    Redline870 [OP] New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    Yesterday I added some Sylvania LED bulbs to the the truck (brake lights, turn signals, bed lights, 3rd brake light, tag lights, reverse lights, corner marker lights), I added a load equalizing resistor for the flashers, and I added an OEM power lock for the tailgate. Now when I exit the truck, I can’t lock it right away with the key fob, I have to wait about 20 seconds before the key fob will respond to me pressing the lock button. How could this be related to the LED’s?
    Any idea what’s going on?
    I found this thread https://www.tundras.com/threads/delayed-door-locks-after-tpms-sensor-change.92159/ which sounds very similar to my issue, but it doesn’t tell what the resolution was…
  2. Nov 14, 2021 at 3:40 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    LED bulbs in the cargo lights mess up the wireless signal for the remote. There are a few threads on this, but the easy fixes are put the halogen bulbs back in for the cargo lights, buy LEDs that don’t interfere, or turn off the cargo lights.
  3. Nov 14, 2021 at 3:42 PM
    Redline870
    Ian
    Central NY
    I just determined that as long as the interior lights are on, I can’t lock the doors. As soon as those interior lights are off, the doors will lock.
  4. Nov 14, 2021 at 3:46 PM
    Redline870
    Ian
    Central NY
    Good call! Any ideas what LED bulbs don’t interfere?
  5. Nov 14, 2021 at 3:49 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It’s kind of hit or miss. I used these and they worked fine, but YMMV
    AUXITO 912 921 LED Backup Light Bulbs High Power 2835 15-SMD Chipsets Error Free T15 906 W16W for Back Up Lights Reverse Lights, 6000K White (Upgraded, Pack of 2) https://smile.amazon.com/dp/B0728DYR9H?_encoding=UTF8
  6. Nov 14, 2021 at 4:44 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    I am sure that it is located in one of threads, but I found a video on YT from a dealer who showed a simple fix with aluminum foil in the third light to help so the bulbs will not interfere with the signal. My bulbs worked perfectly, but lately it can be a problem from the rear. I never have a problem with the remote from the front. If I have an issue from the rear, I will usually point my remote lower and it will work. My exterior bulbs came from Amazon and I found them usually below in the sponsored links. My interior bulbs came from eBay that I bought for my 2015 that parted out and used in my '21. I hope you get it resolved soon as it can be a pain.
  7. Nov 14, 2021 at 4:49 PM
    Redline870
    Ian
    Central NY
    I guess I should be specific when talking about this in case anyone comes across this thread. The ones that causes interference are the Sylvania Zevo 921. The regular Sylvania 921 LED bulbs though not nearly as bright, do not cause the interference issue.
    KingsAustin likes this.
  8. Nov 14, 2021 at 6:57 PM
    There are several brands of leds for the cargo bulbs that cause interference. Vleds has non-RF bulbs that will work. The interference is caused due to the receiver being mounted above the headliner near the shark fin. I am still looking into this because I saw some videos that say it is mounted in the C-pillar aft of the rear doors.
  9. Nov 14, 2021 at 7:17 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    It’s the leds in the cargo light. The sensor for the key is located near the cargo light. Cheap leds interfere with the transmission of the key fob while the light is on. Leave the switch in the off position unless you need the cargo light. Or, Vleds make cargo lights specifically for tundras to combat this.
    STR1 likes this.
  10. Nov 14, 2021 at 7:24 PM
    The original Vleds cargo lights interfered as well. I switched to their non-RF bulbs, but think I may switch back to their High output bulbs that I originally had and just turn the switch off. Did they move the sensor to the headliner on the 2020/21? I saw a video where the 19 and older has it in the C-piller.
  11. Nov 14, 2021 at 7:28 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It’s been in the headliner since 2018 at least. I thought they moved it out of there for the 2020+, but apparently not.
  12. Nov 14, 2021 at 7:34 PM
    It's confusing as hell. Someone with a 2020 pulled the headliner for sound matting installation....I wonder if they would remember lol.
    TRDFerguson[QUOTED] likes this.
  13. Nov 14, 2021 at 8:01 PM
    plact88
    plact88 MGM SR5 CM
    Tucson, AZ
    2021 MGM Tundra Crewmax
    VLED Interior VLED Cargo Light VLED Reverse Light Driverside Grab Handle Bilstein 5100 front 2nd setting TRD Dual Exhaust Black Chrome AJT Chrome Delete TRD Air Filter Tyger Side Steps TVD Vinyl Decals MGM Tundra Radio Decals TVD Vinyl Decals MGM Tailgate Handle Decals Tundra Tailgate Badge Chrome Moto Metal 970 wheels 275/70/18 KO2 Tires TRD Rear Sway Bar MGM Door Handles and Mirror Caps TRD Pro LED Black Housing Headlights Black Housing LED Fog Lights AJT Black Door Handles AJT Black Steering Wheel Controls Tacoma Leather Steering Wheel Pedal Commander TRD Pro Hood Scoop 12 Volt Solutions Remote Start Clazzio Leather Seat Covers
    Haven't had a problem with my VLEDs.
  14. Nov 14, 2021 at 8:28 PM
    Redline870
    Ian
    Central NY
    I’m not so sure that it’s just “cheap” LED’s. The zevo line from Sylvania are their premium LED’s. On top of that, their cheaper version doesn’t interfere.
  15. Nov 15, 2021 at 4:10 AM
    Danman34
    Danman34 New Member
    Danny
    I’m using the updated vled bulbs. Zero issues in over a year.
  16. Nov 15, 2021 at 4:12 AM
    I have the updated ones, I'm just not impressed with the lack of brightness compared to the original high outputs that I had.
  17. Nov 15, 2021 at 4:16 AM
  18. Nov 15, 2021 at 7:04 AM
    plact88
    plact88 MGM SR5 CM
    Tucson, AZ
