Dechroming...4WD knob
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cthulhu, Dec 21, 2019.
  1. Jan 9, 2020 at 4:21 PM
    #61
    Cthulhu
    Cthulhu [OP] The White and Black Goat of the Woods
    Initially setting it up can be challenging regarding all the settings, etc. (you need to be a little tech-savvy and preferably have Android OS skills), but there’s a thread here called “Android Headunit” that’s 90 pages chock full of helpful posts on the unit, and there’s also a FB group dedicated to it called Toyota tundra-Tesla Unit(Tips,Tricks,Updates).
  2. Jan 9, 2020 at 5:41 PM
    #62
    Flying Fuzz
    Flying Fuzz New Member
    2019 GX460 Premium with Sport package.
    No apology needed just wanted to rattle your cage a bit ;)
  3. Jan 9, 2020 at 9:08 PM
    #63
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    Oven cleaner? I know folks use that to strip chrome off headlight bowls
  4. Jan 10, 2020 at 6:10 AM
    #64
    Jra8
    Jra8 New Member
    Tampa Fl
    2018 Inferno
    I didn't even know this items existed!!! I'm glad because sometimes I get a glare from the chrome around the cup holder. Time to spend more money.
    Voyagermike likes this.
  5. Jan 11, 2020 at 3:58 PM
    #65
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    So how does the 4wd chrome come off? I couldnt figure it out
  6. Jan 11, 2020 at 4:03 PM
    #66
    Voyagermike
    Voyagermike New Member
    California
    Here is the video showing how to disassemble. There are 2 clips on the inside that you'll spread apart. While working on one clip try and slide your fingernail under the chrome ring to help keep it loose. Then slowly work your way to the other side.
    https://youtu.be/uQI0x6kVODo
    InsaneAuto86[QUOTED] likes this.
  7. Jan 11, 2020 at 4:04 PM
    #67
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    THANK YOU! I searched for this video when the dash was out, could not find it!
    Voyagermike[QUOTED] likes this.
  8. Jan 11, 2020 at 4:06 PM
    #68
    Voyagermike
    California
    Dont do it as quick as he does it. Take your time with taking it apart. Really pay attention to the pieces you're taking apart. Take photos. Make sure nothing falls out.
  9. Jan 17, 2020 at 8:10 AM
    #69
    tundra403
    tundra403 New Member
    KG
    2018 Tundra SR5 4x4 TSS Off Road - MGM
    -Internal LED Lights -Added VLED's Footwell light strip
    Completed!! Got the shift knob yesterday!!! Next will be the climate rings and 4x4 knob.. Havent decided if i want to do AJT's climate knobs yet. Still pondering.
    82283725_4247307942675_42070726027635589_ec844cf13573115c6f8ed223f6eebdbce5404c70.jpg82421802_4247308262683_86107340878223769_20f6639e3790342956b6e7e1fd87c71b9743813e.jpg
  10. Jun 1, 2020 at 1:18 PM
    #70
    Yzed608
    Yzed608 New Member
    Wisconsin
    Just a FYI for anyone taking the 4x4 knob apart, there are a few small pieces I haven't seen shown anywhere that you need to be careful of. When you disassemble the switch, the middle portion has 2 little plastic 'pushers' with 2 springs beneath. This is what gives it the push to go to 4LO. Here's a pic of what I mean and where they go. I accidentally dropped that part and though I broke tabs off, but it was just the pieces falling out.
    Here you can see the on the left I Ijust have the spring in, the right has the spring then one of the little pusher things on top of it.
    They have a little grease on them so for most they will stay in, but just something to watch for. I was luckily able to find the second spring on my garage floor.
    Also a smaller allen wrench (I think I used a 5mm), with the short right angle worked good for undoing the lower clip. Slide it through the OEM hole under the switch, first pulling up on it to disengage the clip and pull out, then do the top clip.
  11. Jan 19, 2022 at 12:56 PM
    #71
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I know this is an old thread but is the 4x4 knob looser than it was for anyone else following install of a new 4x4 knob? Mine has a little wiggle in it but it works just fine.
  12. Jan 19, 2022 at 11:23 PM
    #72
    Yzed608
    Yzed608 New Member
    Wisconsin
    Do you mean the fit of the knob in the dash piece, or the knob itself turning? If it's the whole knob in the daah piece I wonder if something got a little warped when taking it out. If you mean turning the knob itself I'd probably try taking it apart again and make sure everything is in the right place, it's kind of intricate in there.
    In addition to the few photos in my above post here's one I had of it apart if it helps at all.
    Nbab23 likes this.
  13. Jan 20, 2022 at 6:54 AM
    #73
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    It’s more so the fit of the knob into the dash. It turns just fine and felt solid outside of the dash but for some reason the whole assembly is a little more loose in the dash that it was previously. I was able to get it out really easily so I don’t think I screwed anything up in that regard. It’s not like it moves when I’m driving and it goes into 4 high and low just fine so I may just leave it be unless it gets worse.
