Debadging a new Tundra, need advise and encouragement
Discussion in 'Detailing' started by BravoDeltaRomeo, Sep 23, 2019.
  1. Oct 6, 2019 at 8:45 AM
    mastergunnera8
    mastergunnera8 New Member
    Northern Virginia
    DId the 5.7 badges yesterday. I prepped by spraying Jay Leno quick detailer around it, then used 50wt braided fishing line. Kept pressure towards me (and the badge) so as to not rub the line against the paint. That left the square 3m tape on the car. I soaked it again with the quick detailer..then using a small thing called a "lil chisler" (off Amazon) I worked the adhesive off the car..using downward strokes and it came off surprisingly easy!! after that I used a very small amount of good gone, then meguiars cleaning solution, then the quick detailer. Came out great..the braided line works great!!!
  2. Oct 6, 2019 at 9:19 AM
    rascalrider
    rascalrider New Member
    2009 Crewmax Silver Sky
    Stock.... as of now.
    Ahhhh just do it!! The new cleaner look will be so nice she won’t even notice they are gone!
  3. Oct 6, 2019 at 10:00 AM
    BravoDeltaRomeo
    BravoDeltaRomeo [OP] Old Man Little Blue Finger
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I thought about that!
    rascalrider[QUOTED] likes this.
  4. Oct 7, 2019 at 6:12 PM
    Big Red 1969
    Big Red 1969 New Member
    I agree!
  5. Oct 7, 2019 at 11:14 PM
    Ranger T
    Ranger T New Member
    2019 Calvary Blue TRD Sport
    Truck looks bitchin! what type of lift do you have on it?
  6. Oct 8, 2019 at 9:46 AM
    KTM Hauler
    KTM Hauler New Member
    Rich
    Santa Clarita
    2017 SR5 Tundra 4x4
    Method 306 18"x9" Nitto Ridge Grapplers 275/65r18 Leveling kit
    Thank you! It just has a 2.5" leveling kit on it, rear is stock.
  7. Oct 8, 2019 at 11:06 AM
    Cpa757va
    Cpa757va New Member
    Chad
    Hampton roads VA
    2019 Tundra limited TRD off road
    See build thread below.
    Debadged my limited a few months back. Took every emblem off including large TRD sticker on truck bed. Only thing i left is the “limited” badges but i bought black covers for them. I’m thinking about leveling next but need some recommendations on height, companies, etc.
  8. Oct 8, 2019 at 11:37 AM
    KTM Hauler
    Rich
    Santa Clarita
    2017 SR5 Tundra 4x4
    Your truck looks great. There are so many leveling kits out there but two things that I was looking for was metal spacers and a kit that came with the differential drop spacers to keep everything aligned. Not really sure if metal is significantly better than polymer type...I just figured it could crack or might breakdown over time so went with metal. I don't do anything too serious off road and it's worked out great for me, if you plan to off road a lot you might want to consider adjustable shocks instead of spacers, just my 2 cents.
    BravoDeltaRomeo[OP] likes this.
  9. Oct 8, 2019 at 11:52 AM
    Cpa757va
    Cpa757va New Member
    Chad
    Hampton roads VA
    You have a picture?
    Also, what company leveling kit did you end up going with?
    Thanks
  10. Oct 8, 2019 at 12:48 PM
    KTM Hauler
    Rich
    Santa Clarita
    2017 SR5 Tundra 4x4
    I don't recall off hand but I'll take a picture and look on the receipt tonight.
    Cpa757va likes this.
  11. Oct 8, 2019 at 12:57 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Just to add onto this Kite string works great and will break less on you. About 30 seconds on the small badges, 60 seconds on the larger ones with a heat gun don't keep the heat focused move it constantly to not over heat any spot. To remove the left over tape reheat for 10 seconds and it will roll off. Lastly to get the residue off Turtlewas bug and tar works great
  12. Oct 8, 2019 at 1:16 PM
    Cpa757va
    Cpa757va New Member
    Chad
    Hampton roads VA
    Ever seen anything like this after debadging? Rub my hand over and it feels smooth. Not sure what caused it or how to get rid of it. Only did it with the V8 emblem and only noticeable in direct sunlight at certain angles.
  13. Oct 8, 2019 at 1:18 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Not sure, but another thing about taking off badges if you wait to long the pigment change will stand out especially with black.
  14. Oct 8, 2019 at 1:52 PM
    AZBoatHauler
    So.Arizona
    Looks like it got too hot and burned the clear coat? Did you use a hair-dryer or heat gun before removal?
  15. Oct 8, 2019 at 3:24 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    That's it for de-badging for me. I was hoping to get them all done but don't have the go ahead. Oh well, I got a few off.
    What a shame. :facepalm:
  16. Oct 8, 2019 at 3:26 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Or the rest fell off...
  17. Oct 8, 2019 at 3:36 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Maybe I'll pressure washer them off by accident in the spring.
    "See, I told you we should have taken them off."
    Tchase[QUOTED] likes this.
  18. Oct 8, 2019 at 4:14 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    If you just want want to level, look at Bilstein 5100s. Where in the 757 are you?
  19. Oct 8, 2019 at 4:18 PM
    #49
    Cpa757va
    Cpa757va New Member
    Chad
    Hampton roads VA
    Chesapeake/ Virginia Beach area. Looking for somewhere to purchase and have them installed.
  20. Oct 8, 2019 at 4:19 PM
    #50
    Cpa757va
    Cpa757va New Member
    Chad
    Hampton roads VA
    Used a hairdryer briefly.
  21. Oct 8, 2019 at 4:40 PM
    #51
    JMB
    Chesapeake, VA
    I'm in Chesapeake. My SIL is a mechanic. I can ask if he wants to install. I had him do my front because spring compressors scare me. I'm sure you'll get a thousand recommendations on parts. For me, I wanted to clear wider tires for beach driving. 5100s worked fine. Maybe do a search on here or start a new thread with the question.
  22. Oct 8, 2019 at 5:39 PM
    #52
    rmvcard0303
    rmvcard0303 New Member
    Ray
    San Gabriel Valley, CA
    2019 White Tundra TRD Sport CM
    I’d rather not list. My wife might see it.
    Said the guy who’s never been married. Haha
    BravoDeltaRomeo[OP] and Tchase like this.
  23. Oct 8, 2019 at 5:59 PM
    #53
    Cpa757va
    Cpa757va New Member
    Chad
    Hampton roads VA
    That would be awesome! I’m interested for sure.
  24. Oct 8, 2019 at 8:12 PM
    #54
    AZBoatHauler
    So.Arizona
    Hmmm. I wouldn’t think that would be enough to burn the clear. Post something on the detailing sub-forum. They might have a better idea.
    Tchase likes this.
  25. Oct 8, 2019 at 8:20 PM
    #55
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    I’m a lucky married man my wife lets me do what I do, now if I started touching her car I’d probably need to negotiate lol
  26. Oct 8, 2019 at 8:48 PM
    #56
    BravoDeltaRomeo
    Bruce
    MB Canada
    Exactly why I need to get our 2nd vehicle purchase going sooner, rather than later.
    Once she's in a new vehicle too, we'll all he happy and I'm sure I'd have some more leeway. As it stand now, she's in an 08 Escape. She will probably end up in a Rav4 or if I have any say, a 4Runner. The 4Runner would probably be both our choice, it'll come down to funds.
    I'm not giving up yet though
  27. Oct 8, 2019 at 8:52 PM
    #57
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    We just hit our 23rd year so we've been in the single car boat... marriage is work but well worth it.
  28. Oct 8, 2019 at 9:47 PM
    #58
    Niceguy
    Niceguy New Member
    19 Cement Limited
    This thread encouraged me to get going on some good ‘ole debadgin. Got rid of my chrome Limited badges. It was already pretty sacrilegious that I put on the Tundra and V8 black badge overlays last week, leaving the Limited as the only chrome outcast since Toyota didn’t make a black overlay for that one. Process went smooth. Used the wifeys hair dryer, some waxed dental floss, and Goof Off. Only complaint was the floss kept breaking, so I had to take it easy with the sawing. Didn’t have any fishing line; imagine that would work much better. Oh well, still got the job done. Thanks for all the advice!
  29. Oct 8, 2019 at 11:18 PM
    #59
    Bust
    Bust New Member
    Shean
    2013 Black Toyota Tundra Rock Warrior
    Are you handy at all? I put on fat Bob garage vated 3" adjustable coilover lift a few months ago. Me and two buddies did it in about an hour. Just needed a few wrenches, sockets and floor jacks. No spring compressor or anything required. Just pull the old shock and coil out and place in the new coilover. The kit does come with a diff drop, I didn't install cause I only lifted 2". Price shipped to me was under $500, best price you can find for adjustable coilovers.
  30. Oct 9, 2019 at 3:09 PM
    #60
    00PS
    00PS New Member
    2016 Barcelona Red Limited Crewmax TRD 4x4
    Hah! Maybe I just got lucky but as long as I keep the wife’s car clean and good working order, I get to make all the decisions in the garage. Almost married 10 years with 3 kids.
    Tchase and BravoDeltaRomeo[OP] like this.
