Dasaita Android Head Unit
Discussion in 'Audio & Video' started by 916tundra, Apr 27, 2019.
  1. Jul 7, 2023 at 8:02 PM
    #2251
    donellyd
    donellyd Member
    Eastern PA
    2020 Sequoia TRD Pro
    SOLD: 2008 Sequoia Limited SOLD: 2004 Sequoia Limited
    I still get FM and thumb drive tunes when a cycle thru the sources. Yours are good options to try but I'm not hopeful.
  2. Jul 7, 2023 at 8:20 PM
    #2252
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Installed it in December 2021, so about year and a half
    Yea they're not very responsive on their website forum, I messaged them through Amazon, they respond pretty quick through there but all their replies will be at night. The seller for my unit was Dasaita Official Store but shipped by Amazon also, so no sure how it would go if yours was through a different seller.
  3. Jul 9, 2023 at 5:11 AM
    #2253
    Skaufma0
    Skaufma0 Just a little stitious.
    Rock Hill, SC
    2018 MBM Limited CM
    Just got mine in and I'm trying to figure out how to mount it to the brackets. Anyone have any advice? Original bolts are too big and it came with some smaller ones, but the holes aren't lining up.
    There are also a few extra connections from the factory unit that have nowhere to go. And RCA's from the harness the unit came with that have nowhere to go either... The instructions are useless as we all know already.
  4. Jul 9, 2023 at 6:18 PM
    #2254
    Skaufma0
    Rock Hill, SC
    2018 MBM Limited CM
    I'm a dumb-dumb apparently. Figured out the cable issues for the most part...except the reverse camera. Mine has two yellow camera cables. If I go to the AVIN app on the unit it'll display video, but in reverse it's black with a big exclamation point in the middle.
    I'm also trying to see how to get it to fit better. Seems like it's an 1/8th of an inch too low.
  5. Jul 19, 2023 at 3:40 PM
    #2255
    BoatBroker
    BoatBroker New Member
    Sarasota, Florida
    2016 Tundra SR5
    You have the two yellow RCA's reversed. Switch them and your back up camera will work.
  6. Jul 20, 2023 at 5:37 AM
    #2256
    Skaufma0
    Rock Hill, SC
    2018 MBM Limited CM
    Yeah I figured it out, was hot and tired of looking at it so was easily stumped. Now I'm dealing with a different issue, debating on the best way to get around it. This tab under the dash that holds the middle clip on the factory unit at the top is in the way of the Dasaita sitting the way it's supposed to and allowing the A/C controls to go back in properly. I'm debating trimming it off, but I don't want to if I don't have to or someone has a better solution who's run into it before. I can't find anyone mentioning it being a problem though.
    2023-07-20-08-32-27-Dasaita-Android-Head_6ed2cf7408aeb79e7039cdbbbbc8473bab876998.png
  7. Jul 20, 2023 at 5:40 AM
    #2257
    BoatBroker
    Sarasota, Florida
    2016 Tundra SR5
    That A/C temp. section just below the Dasaita has always been pushed out slightly on mine. It's because there is nothing solid for it to clip into on the bottom of the Dasaita. The OEM HU had two bolts on the bottom and the Dasaita only clips at the top so the bottom kind of dangles. You have it installed corrected from what I can see. If you do figure out something different please let me know.
  8. Jul 21, 2023 at 5:44 AM
    #2258
    Skaufma0
    Rock Hill, SC
    2018 MBM Limited CM
    It just looks so cheap and janky not fitting properly. I'm thinking I'll modify the factory brackets to hold it in place better.
  9. Jul 21, 2023 at 6:05 PM
    #2259
    BoatBroker
    Sarasota, Florida
    2016 Tundra SR5
    HIGHLY recommend these as a replacement to the factory POS dash tweeters. Unreal the difference for $70. Dasaita with amp bypass installed powering them.
    MedCityMoto likes this.
  10. Jul 21, 2023 at 6:08 PM
    #2260
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    What are they?
  11. Jul 21, 2023 at 7:09 PM
    #2261
    BoatBroker
    Sarasota, Florida
    2016 Tundra SR5
  12. Jul 24, 2023 at 9:31 PM
    #2262
    illtww
    illtww New Member
    T
    Can you run these on a NON JBL amped SR5 (Amp under passengert seat) Factory Setup or is that a waste?
  13. Jul 25, 2023 at 5:20 AM
    #2263
    BoatBroker
    Sarasota, Florida
    2016 Tundra SR5
    Yes, the factory tweeters are paper garbage that the sun destroys. You will see a huge difference even with factory head unit I'm sure.
  14. Aug 21, 2023 at 12:53 PM
    #2264
    run4fun
    run4fun New Member
    2018 sr5 trd
    Hello all! Im thinking about getting one of these HU for my 2018 tundra. Im looking at this one that's on amazon. ITs the 10.2 Dasaita vivid with Android 11. Im mostly just wanting to get apple car play working however I do have the anytime front and rear camera setup on a switch already. is it possible to retain that.
    Also another big things I'm wanting to add is a dash cam, does anyone know if it's possible to hook a dash cam up the the HU instead of buying a whole new dash cam setup. Like is it possible to just add a camera and have it all saved to the HU? Also are people still happy with their choice? I was thinking of doing the Tesla style radio but seems like to many people have issues with them so I'm thinking this might be a better way to go. I also will be able to keep all the factory knobs for ac so its one less thing that the new HU could mess up. Thanks in advance!
  15. Aug 21, 2023 at 1:33 PM
    #2265
    MedCityMoto
    Hi there! I'm here to reverse my recommendation on the Dasaita.
    One: if you buy it on Amazon, it's not actually from Dasaita. You don't get the 1-year warranty. Mine's currently stuck in boot-loop and Dasaita's been kind enough to help me troubleshoot but their website clearly states that resellers don't get honored warranty support / exchanges because there's no telling what/if you get genuine software or hardware from them. Yikes.
    Two: Longevity isn't there. If you listen to your radio a lot, you'll eventually run into overheating after 2 hours or so. Ever since I saw my first "overheating, turning off" message for the first time, it's not connected to Android Auto right anymore.
    It's better than sticking with a stock headunit but have your expectations set accordingly, and buy it from the company directly so you get warranty replacement/exchange support if you need it. If you have to buy two in the lifetime of the truck, you've no longer saved any money vs getting a nice Alpine or Kenwood or such.
  16. Aug 21, 2023 at 2:07 PM
    #2266
    run4fun
    run4fun New Member
    2018 sr5 trd
    Great advice thanks! really trying to decide what HU to buy. I have looked at the Pioneer DMH-WT8600NEX, it's just 3 times the cost. I was hoping this would really work out but sounds like it might not be worth bothering with. I was liking the idea of the Tesla styled ones but again seems like so many people have issues with a lot of these aftermarket HUs. Might just have to pay the extra money for a nice Pioneer or Kenwood.
  17. Aug 21, 2023 at 2:24 PM
    #2267
    MedCityMoto
    There's a thread in here for an Alpine ilx-f309 which would be a great upgrade. Very fairly priced.
  18. Aug 21, 2023 at 2:28 PM
    #2268
    run4fun
    run4fun New Member
    2018 sr5 trd
    Yeah I saw the thread on the Alpine ILX-F511 Halo11. Im thinking that might be the way to go. Just wish it was about half the price ha!
  19. Aug 21, 2023 at 5:38 PM
    #2269
    MedCityMoto
    The guy selling it is asking $350 or so, are you sure you found the right post? I'll suss it out if not, one sec
  20. Aug 21, 2023 at 5:40 PM
    #2270
    MedCityMoto
  21. Aug 21, 2023 at 7:21 PM
    #2271
    run4fun
    run4fun New Member
    2018 sr5 trd
  22. Sep 15, 2023 at 9:36 PM
    #2272
    Tex283
    Tex283 New Member
    I tried to still se 13.3 Dadaita to my Tundra non-jbl but I could not get audio from the doors. Somebody know how to solve it?
  23. Sep 16, 2023 at 2:51 AM
    #2273
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
  24. Sep 23, 2023 at 1:58 AM
    #2274
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    Does anyone know if there's more than 2 camera inputs, and if so, what the labels are? Wondering how hard it would be to wire in some blind spot cameras into this unit...
  25. Oct 2, 2023 at 2:21 PM
    #2275
    litehedded
    litehedded New Member
    Hi all, apologies i'm sure this info is contained somewhere in this thread but I'm still a bit confused.
    I have a 2007 Tundra limited with the jbl system. is this what I need?
    https://www.amazon.com/Dasaita-Andr...---------&vehicleName=2007+Toyota+Tundra&th=1
    it seems a bit cheap like it may be missing some wiring harnesses I'll need? Can someone with a gen2 jbl truck point me in the right direction?
  26. Oct 3, 2023 at 7:25 AM
    #2276
    litehedded
    seller on Amazon tells me this has everything I need. we'll see shortly
    BoysandHisToys likes this.
  27. Oct 3, 2023 at 9:19 AM
    #2277
    BoysandHisToys
    Central Virginia
    I thought it would have, but that’s about $200 cheaper than I paid for mine so I wasn’t sure.
  28. Oct 3, 2023 at 9:21 AM
    #2278
    litehedded
    Yea the price was so good and it was Amazon so I figured I’d just give it a try. Comes tomorrow so I’ll know soon enough
  29. Oct 5, 2023 at 2:39 PM
    #2279
    litehedded
    works. installed today and this thing is great. 2007 Tundra limited with jbl system is basically plug and play.
    i had to map the steering wheel buttons but everything is up and running now.
  30. Oct 5, 2023 at 7:11 PM
    #2280
    litehedded
    First issue with the new Headunit.
    When I’m using CarPlay and playing music via pandora and I have navigation running (google maps or Waze) it completely mutes the music every time it gives directions. Anyone encounter this and know how can I fix it?
    *edit* never mind found it
