Dasaita Android Head Unit
Discussion in 'Audio & Video' started by 916tundra, Apr 27, 2019.
  1. May 10, 2022 at 4:54 PM
    #2041
    Beer Man
    Beer Man @cement.tundra
    2021 SR5 XP CrewMax Cement
    I forget which one, I probably say in my earlier posts above, but with my 2021 & CB047 1 of those isn’t used. They both plug in, but only 1 makes the unit fire up.
    To your question earlier, I didn’t have to hook up any amp wires, which I thought I was going to have to do. They must’ve updated the canbus because I know it was a problem causing the door speakers to not turn on.
    I had a lot of stuff leftover that they sent, the only thing I hooked up other than the canbus wires were the backup cam wire & wifi antenna. I didn’t need xm or gps or anything else since I use CarPlay exclusively.
  2. May 11, 2022 at 5:48 AM
    #2042
    OHnickIO
    OHnickIO New Member
    2020 TRD Sport Non JBL
    This is the back of the 2020 Radio. Maybe one is XM and one is GPS, i'm not sure
    **Update The white one is for GPS. Black is XM radio.
  3. May 12, 2022 at 4:46 AM
    #2043
    xsplicer26
    xsplicer26 New Member
    2016 metallic gray tundra limited
    So I finally have everything working on mu HU.
    It turns out I overlooked one of the wire harness that plugs into the HU and then I just had to connect the 2 yellow connectors to each other and the backup camera worked. My bad.
    The people at Dasaita were totally CORRECT with the info they had in their emails, and I told them so in an email saying it was my mistake. So I have to take back what I said about their CS being bad, they were right on.
    The HU looks great in the truck and I really like it.:thumbsup:
    And Beerman you were totally correct with your response that the 2 yellow connectors plug into each other. Thanks
    Beer Man and BoysandHisToys like this.
  4. May 12, 2022 at 11:16 AM
    #2044
    OHnickIO
    OHnickIO New Member
    Does the PX6 have resolution settings for the backup camera? I have a 2020 Tundra with factory backup camera and the resolution looks awful
  5. May 12, 2022 at 11:40 AM
    #2045
    Beer Man
    All I’ve found is how to adjust the brightness
  6. May 12, 2022 at 1:48 PM
    #2046
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    I think you'd have to upgrade the rear camera. Some other member had an audio shop upgrade the rear camera to what I think is a Kenwood CMOS-230: https://www.tundras.com/threads/avssuc-2021-trd-pro-build.93944/
    Debating whether or not I should try it out. The camera is $100; the connections look like they're fairly standard, so you'd just need to get a wiring harness/adapter if you wanted to utilize the stock connections. Power, Negative, Reverse signal, and Video Out.
    OHnickIO[QUOTED] likes this.
  7. May 12, 2022 at 7:41 PM
    #2047
    fish2keel
    fish2keel New Member
    How is the sound quality for yall? Non jbl system. I see mention of negative sound quality with this head unit. Is it worth going with joying as well?
  8. May 13, 2022 at 8:06 AM
    #2048
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    get either the dasaita or any AHD backup camera. It will make it better.
    https://www.dasaita.com/products/dasaita-170-hd-1080p-ahd-car-backup-camera-fisheye-waterproof-rear-view-camera-parking-assistance-wide-viewing-angle-night-vision
    The ahd cameras are all over AliExpress. From joying to t’eyes to other.
    Of course you will have to run the new wiring and all. But the clarity is very nice.
  9. May 13, 2022 at 12:38 PM
    #2049
    motiusclyde
    motiusclyde New Member
    what launcher is everyone using? I find it pretty annoying the stock firmware displays a map of my location as the default homescreen. Havnt figured out a way to change it.
  10. May 13, 2022 at 3:13 PM
    #2050
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    Most prefer the Agama car launcher. I use CarPlay 95% of the time tho.
  11. May 13, 2022 at 4:22 PM
    #2051
    fish2keel
    Also how is the dasaita with android auto? Does it work wirelessly?
  12. May 13, 2022 at 6:32 PM
    #2052
    Beer Man
    CarPlay lmao
  13. May 14, 2022 at 2:59 PM
    #2053
    BoysandHisToys
    Central Virginia
    Anyone know if you can use the “Fcam” app to use the reverse camera as the rear camera?
    I have a front camera, but when I change to rear it just shows a triangle.
  14. May 16, 2022 at 5:48 AM
    #2054
    xsplicer26
    I took a 4 1/2 hr trip over the weekend in my truck with the new HU installed. No problems at all, the sound with the JBL system is better than the factory radio. Using the Sirrius XM app was flawless and using the GPS antenna that came with the HU works better than the factory antenna. I am really liking this unit and it looks great in my truck. Thanks to all you have replied to my questions that helped with the install.
  15. May 16, 2022 at 7:09 AM
    #2055
    fish2keel
    Is everyone buying direct from dasaita or is there a preferred seller/Amazon?
  16. May 16, 2022 at 3:10 PM
    #2056
    BoysandHisToys
    Central Virginia
    I bought through Saita Navi on Amazon. Support was pretty good and they resolved my CANbus harness quickly enough.
  17. May 16, 2022 at 5:12 PM
    #2057
    OHnickIO
    OHnickIO New Member
    I bought from a guy who purchased off Amazon in December and the resolution is only 1200x600. I believe the PX6 now is a higher resolution right?
  18. May 16, 2022 at 5:27 PM
    #2058
    BoysandHisToys
    Central Virginia
    Mine is 1280x720.
  19. May 18, 2022 at 10:17 AM
    #2059
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    Not sure if anyone knows the answer to this, but my truck was the fleet version, so no center speaker. with the dasaita unit, could I just add a center speaker since there's a "mid" RCA input? and if so, is there any kind of special speaker i need to look for?
  20. May 19, 2022 at 6:01 AM
    #2060
    motiusclyde
    13.3 installed. USed the CB004 harness for my 2019 with JBL. I couldn't figure out how to retain the stock GPS or XM antennas. But besides that it all works.
    Has anyone upgraded their backup camera? It looks sooooo crappy on this huge screen lol
  21. May 19, 2022 at 6:02 AM
    #2061
    motiusclyde
  22. May 24, 2022 at 11:17 AM
    #2062
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    Yes, works just fine (I have the 10.2" and have used wireless AA for over a year now).
    fish2keel[QUOTED] likes this.
  23. May 24, 2022 at 11:19 AM
    #2063
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    You have to enable it in the 'factory settings' menu and use the correct RCA plug as well.
    https://www.youtube.com/watch?v=PjCJNIyBN00
  24. May 31, 2022 at 3:15 PM
    #2064
    BamatundraSC
    BamatundraSC New Member
    Greer, SC
    2021 SR5 CM
    TRD Pro grille, color matched hood bulge, TRD Pro headlights, color matched front bumper end caps, Rough Country two inch loaded front struts, Matte black SCS Ray10’s, Cooper Rugged Trek 275/70/18, Rough Country tri fold hard bed cover, Dirty deeds 12” exhaust
    My truck is a 21 non JBL. I bought the 13.3 and have the cb0047 harness. The only issue I have is no sound out of the door speakers. I’ve looked through virtually every page of this thread, but unless I’ve missed it, I haven’t seen where anyone came up with a solution.
    Obviously the factory amp isn’t turning on. Im sure it’s a connection from the back of the radio to the harness, but I don’t want to start plugging/unplugging stuff without having an idea what needs to be connected to what to turn the amp on. Does anyone have any ideas as to which connection Im missing?
    Everything else works. Back up cam, TPMS, steering wheel controls etc.
    Thanks
  25. May 31, 2022 at 4:11 PM
    #2065
    OHnickIO
    OHnickIO New Member
    Could I run the Rears speakers directly off the HU (high level input) and Run RCA to my 2 channel amplifier for the front speakers? Technically it's a 5 channel, but I'd like to bridge the A/B Channels for more power to my front aftermarket speakers
  26. May 31, 2022 at 5:45 PM
    #2066
    Beer Man
    Sent you a PM.
    Let me try & find the thread you need.
  27. May 31, 2022 at 5:50 PM
    #2067
    Beer Man
    Here you go:
    https://www.tundras.com/threads/2021-tundra-dasaita-install-help.100349/#post-2722744
    BoysandHisToys likes this.
  28. May 31, 2022 at 6:59 PM
    #2068
    fish2keel
    Could you post a picture of yours?
  29. Jun 1, 2022 at 7:51 AM
    #2069
    BamatundraSC
    Greer, SC
    2021 SR5 CM
    Thanks @Beer Man.
    I was thinking I was on to something with the harness that comes from the radio that has all the pre outs for running external amplifiers. Since all of my system except for the head unit is stock, my thinking was that with that harness connected to the back of the radio but with no connections made that the radio was looking for an external amplifier to power the speakers and by unplugging that harness from the back of the radio, the radio might seek another source (maybe from the canbus) to engage the factory amplifier that powers the door speakers, but that didn’t work either.
    I am now wondering if I have the RCAs (pictured) plugged into the wrong harness?
    I currently have them plugged into the same harness that the back up cam is plugged into.
    I am also beginning to wonder if they sent me the wrong harness and not the cb047, but I can’t find anything that tells me which harness I have… everything else works as it should.. 382B25DE-E360-40B5-A404-E8981561A6C9.jpg
  30. Jun 1, 2022 at 2:26 PM
    #2070
    BamatundraSC
    Greer, SC
    2021 SR5 CM
    I unplugged the RCAs and plugged them into the other harness with no luck. I took a picture of the canbus they sent me (attached) and compared it to the one in the photo of the cb047 harness they sold me through Amazon. The model numbers are the same and mine appears to be a newer version than the one they have pictured.
    I don’t know what I’m missing here..C869CBBA-FABA-4881-99D2-9C9A9E2ECE5A.jpg
