Dasaita Android Head Unit
Discussion in 'Audio & Video' started by 916tundra, Apr 27, 2019.
  1. Dec 31, 2021 at 9:33 AM
    #1801
    donellyd
    donellyd Member
    Eastern PA
    2020 Sequoia TRD Pro
    SOLD: 2008 Sequoia Limited SOLD: 2004 Sequoia Limited
    In the HU go to Settings / Apps & notifications then scroll down to and click on Default Apps (Google is prob listed). Agama should be listed. Select it as default launcher and you shouldn't have any more problems reverting back to another launcher.
  2. Dec 31, 2021 at 10:15 AM
    #1802
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    Ok I’ll give it a try. But in the Agama launcher when I select radio it brings up the Max 10 radio. I’m just not a fan of how that looks.
  3. Dec 31, 2021 at 10:16 AM
    #1803
    BoysandHisToys
    Central Virginia
    Have you tried different can buss settings? There should be several for Toyota and I just tried them all until I found the one that worked.
  4. Dec 31, 2021 at 11:33 AM
    #1804
    Ghostface
    Ghostface New Member
    I haven’t tried any others as the seller from the dasaita Amazon store instructed me to use option #8.
  5. Dec 31, 2021 at 11:38 AM
    #1805
    BoysandHisToys
    Central Virginia
    I’d try the others and see. Pretty sure I had the same issue with other CANbus settings that didn’t work for my truck. I have the JBL OEM system.
  6. Dec 31, 2021 at 1:06 PM
    #1806
    Ghostface
    Went through all that mentioned anything about Toyota and unfortunately no luck. I don’t have the JBL system. I left a message with the dasaita seller. Hopefully I’ll hear back soon so if any others with a 2021 or any with the newer 7 inch screen can learn. I’m the Guinea pig. Thank you though!
  7. Dec 31, 2021 at 1:18 PM
    #1807
    BoysandHisToys
    Central Virginia
    Hmmmm…. Thought I could help you out but guess not.
    I did find this in the forum. Do you still have an amp for the non-JBL systems?
    https://www.tundras.com/threads/door-speakers-not-working-after-changing-head-unit.49366/
  8. Dec 31, 2021 at 1:20 PM
    #1808
    Ghostface
  9. Jan 4, 2022 at 2:34 PM
    #1809
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    Anyone know if you can enable/disable the beep the car makes when you lock the doors with the remote fob? I've tried looking under car settings but I don't see anything about tones, like it does in the manual about the OEM head unit : https://www.toyota.com/owners/resources/warranty-owners-manuals.tundra.2014 (page 530).
    My lights still flash when I lock/unlock the door, so I'm pretty certain it's not a lock sticking/door lock actuator issue
  10. Jan 6, 2022 at 12:17 AM
    #1810
    bigdave5
    bigdave5 New Member
    David
    2017 Tundra CM
    My "beep" stopped working after installing my Daisata unit. I don't know whether there is a setting on the head unit for that or not. Frankly I like it without the lock beep. The lights still flash and that's good enough for me.
  11. Jan 6, 2022 at 8:02 AM
    #1811
    newuser511124
    newuser511124 New Member
    2019 SR5 TRD Off Road
    Just wanted to throw my installation out there. I already have a Dasaita in my Subaru WRX STI and dealt with Iris previously, so I emailed her to make sure I get the correct unit & purchase directly from their store.
    I have a 2019 Toyota Tundra SR5 TRD Offroad w/ the amplifier under the passenger seat. My Entune was non-JBL and non-Navigation. I previously replaced the amplifier with the Alpine KTP-445U amp.
    She directed me to get: https://www.amazon.com/Dasaita-Screen-Android-Navigation-Meomery/dp/B09J2K1LXR/
    So far everything has been running as expected. I was also excited to see the headunit properly integrated with the truck where it displays the door open warnings, I can access the fuel economy settings like the Entune unit (which I never used, but still cool it's in there) and the vehicle settings applications.
    I ended up just using the GPS puck included with the radio and mounted it under my dash. I had a non-navigation Entune, but I assume I still have a factory GPS puck on the top of the truck that I could have gotten an adapter.
  12. Jan 6, 2022 at 9:13 AM
    #1812
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    Not sure about the later years, but in 2017 the GPS module was under the dash behind the radio. That 'bump' on the top of the Tundra's roof was for XM Radio. I would think that the stock GPS unit still remained under the dash in later years.
  13. Jan 6, 2022 at 9:15 AM
    #1813
    newuser511124
    Well TIL -- I figured it was a dual mount antenna on the roof. The puck included with the Dasaita is getting clear signal where I mounted it under the dash so I'll just leave it be. Thank you!
  14. Jan 6, 2022 at 9:18 AM
    #1814
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    All of the 'wireless' icons are in the 'waiting for connection' portion of Zlink. You can update your version of Zlink to make it work if you don't see these below (not my picture, but you get the idea):
    blackoutt[QUOTED] likes this.
  15. Jan 6, 2022 at 10:15 AM
    #1815
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    Do you remember if it stopped working immediately after installing the Dasaita unit? From my memory I think I still had the beeps for a while, so I'm wondering if it's just coincidence that my beeper unit went bad, or if it really is because of the new head unit.
  16. Jan 6, 2022 at 12:32 PM
    #1816
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    Yep. My "newer" version doesn't have wireless AA on the max10 rom that came with my unit. Still haven't had time to try vivid rom.
  17. Jan 6, 2022 at 12:37 PM
    #1817
    Big Tree
    Big Tree New Member
    I'm kind of torn between getting the Dasaita 10.2 or 11inch or the Joying. I'm curious if both are the same just different brand name? I'm going to hopefully place my order for one of the two this week and see a lot of info on here once I try to set it up.
    One question I did have was do these retain factory rear camera? or should I buy an after market one instead?
  18. Jan 6, 2022 at 1:11 PM
    #1818
    newuser511124
    Do you have your phone connected via BlueTooth? I didn't even realize I had wireless carplay. I connected the phone via BlueTooth to the headunit and suddenly Zlink popped open and brought my wireless carplay. I also changed the BlueTooth on my phone to show the device as a "Car Radio" under the BT settings.
    donellyd likes this.
  19. Jan 6, 2022 at 8:21 PM
    #1819
    bigdave5
    bigdave5 New Member
    David
    2017 Tundra CM
    I think it was pretty much immediately, but I could be wrong. :confused:
  20. Jan 6, 2022 at 11:59 PM
    #1820
    BoysandHisToys
    Central Virginia
    It should use the factory backup camera.
  21. Jan 7, 2022 at 6:08 AM
    #1821
    donellyd
    donellyd Member
    Eastern PA
    There's some posts in here saying the two HU's have differences. I don't recall what they are but I didn't lose anything in my 08 Sequoia Ltd when going to the Dasaita EXCEPT fader controls - which does stink. I have the JBL premium set (drawing a blank on correct name). Only recommendation is to order from the Dasaita store on Amazon and one you have your order placed go to the Dasaita store and message them pics of the front and back of your HU and vehicle year and model. Iris took care of everything for me to ensure I had all the correct parts (which involved ordering separately the correct canbus for another $60).
    BoysandHisToys likes this.
  22. Jan 10, 2022 at 8:30 AM
    #1822
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    Hello all, long time reader but first time poster.
    I have a 2013 Tundra, Platinum with Factory Nav, Backup Cam, JBL amp.
    I recently ordered the following:
    Amazon.com: Dasaita 10.2 inch Touch Screen 1 din Android 10.0 Car Stereo for Toyota Tundra 2007 to 2013 and Sequoia 2008 to 2018 Radio GPS DSP 4G Ram 64G ROM Bluetooth Navigation Carplay Android Auto : Electronics
    Amazon.com: Dasaita CB005 Power Cable w/CAN-Bus Adapter for Car Radio Installation Fit for Lexus GX470 & Toyota car from 2006 to 2011 to Support JBL Amplifier Radio Antenna Canbus Decoder Car Stereo Wire Harness : Electronics
    This was all that was needed to get everything working. It took some time to get the amp settings in the new stereo to actually add base to the audio... but once I figured it out, it sounded much better than OEM. The backup camera was a pain, but I figured out the green trigger wire and was able to splice in the orange wire from the CB005 harness into the Green reverse trigger wire coming from the truck harness. Once I spliced this in, everything worked as it should.
    I ordered an HD backup camera as well so the resolution is much better than the OEM camera offers. THis is a must have for the new high res screen on this head unit.
    I downloaded AGAMA launcher for the stereo and it seems to work very well. CarPlay is what I primarily use (with WAVE for navi).
    Factory USB ports are NOT operational...but that's only because I didn't hook them up. You can get these to work with an adapter. I ran the 3 USB's down under the HVAC controls and under the cup holders.... not currently accessibly while driving but very easy to access if I wanted to get to them or add a port somewhere.
    Just figured I should share the positive review on this.
    Also- Iris was VERY responsive and helpful. Just reply to the email that it generates to your Amazon email address and you will get a response back around 9pm EST consistently.
    donellyd and BoysandHisToys like this.
  23. Jan 10, 2022 at 9:00 AM
    #1823
    donellyd
    donellyd Member
    Eastern PA
    Thx for sharing. What BU camera did you get?
  24. Jan 10, 2022 at 9:04 AM
    #1824
    carn_dogg
    Pat
    Eastern Shore MD
    I purchased this one:
    2007-2013 Tundra OEM HD Camera Kit | Tailgatecamera.com
    pricey, but it was full OEM integration. Plugged into the factory plug behind the bumper. Just had to run the wire inside the tailgate. Replaced the OEM handle as well (which was great for me because my OEM camera mount had broken). Full disclaimer, it appears that they just have a custom bracket and OE plug for a nice HD camera that they integrate into the OE handle and sell as a package/upgrade.
  25. Jan 10, 2022 at 10:58 AM
    #1825
    pleasehelpimlost
    pleasehelpimlost New Member
    2020 Toyota Tundra SR5
    Hey guys/gals,
    I have a 2020 Tundra and connected everything up with no problem except for the typical rear speakers not working. I have two connectors (as shown) without a home and was hoping you could help out. I tried changing my canbus settings to no avail and now I’m stuck. I’ve reached out to Dasaita but they don’t seem to have an answer. It looks like I do have an amplifier beneath the passenger seat so I’m guessing one of these plugs powers the back speakers. I just don’t know how to connect them. Any help would be greatly appreciated!
  26. Jan 11, 2022 at 2:27 PM
    #1826
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    Can you post pictures of how the image quality is on the HU?
  27. Jan 11, 2022 at 2:41 PM
    #1827
    carn_dogg
    Pat
    Eastern Shore MD
    Yeah I can take one tomorrow. I didn't take a picture of the image quality with the new HU and stock back up camera though, but can provide a picture of how it looks now with the new HU and new backup cam.
  28. Jan 11, 2022 at 3:01 PM
    #1828
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    possibly might have the wrong CANbus if there's no connector for that one on it.
  29. Jan 11, 2022 at 3:34 PM
    #1829
    carn_dogg
    Pat
    Eastern Shore MD
    @jimmyfu
    Pic attached of the backup cam view from the hd cam
  30. Jan 11, 2022 at 8:03 PM
    #1830
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    thanks! this looks loads better than the OEM. Now I'm wondering if it's possible to utilize the original handle but swap over JUST the camera...
