Dasaita Android Head Unit
Discussion in 'Audio & Video' started by 916tundra, Apr 27, 2019.
  1. Mar 20, 2020 at 11:20 AM
    #1201
    Thattundradude
    Thattundradude New Member
    Platinum Tundra
    Lifted
    It's the factory camera from toyota
  2. Mar 22, 2020 at 10:52 AM
    #1202
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    Does any know if this unit has Video out to hookup rear headrest monitors to play the video?
  3. Mar 27, 2020 at 6:58 PM
    #1203
    Yohan11
    Yohan11 New Member
    2012 MGM
    Yes, it has an hdmi out.
    Coolhardy[QUOTED] likes this.
  4. Apr 8, 2020 at 9:33 AM
    #1204
    minter66
    minter66 2007 TSS CrewMax
    Welp, I'll be the first to report my Dasaita unit failed last night.
    It had worked the night before, got in my truck yesterday afternoon and everything started up fine, but absolutely no audio. I didn't even have that "white noise" that we all know about.
    I checked my amp fuse, my radio fuse - nada.
    I know it's the unit because I took some speaker wire and jumped various speakers and got a popping noise from each one, so I know they are getting power and signal through the JBL amp.
    So far Dasaita hasn't responded - I emailed them at noon their time (in China). They state these have a 12 month warranty, I bought it April 26th.
    I'll update ya'll on what happens.
    Disappointing - as I leave to go camping in a few hours.
    Edit: Does anyone have a stock JBL radio from a 2007-2009 Tundra? I'd buy it from you or pay shipping both ways to test it out.
  5. Apr 8, 2020 at 8:22 PM
    #1205
    JROD15
    JROD15 New Member
    john
    2019 Toyota Tundra
    Well my brother' I'm sorry to hear that! Don't get your hopes up on a immediate responce. Its been three weeks since I returned my unit and I'm still waiting on a refund. My advise to anyone buying anything from China' Dont do it!!
    Stick with Alpine' Kentwood, name brands you know and grew up with. Those big screen radios are nice, lots of features but no quality. Again I'm sorry to hear that! Hope things work out for you.
  6. Apr 9, 2020 at 6:53 AM
    #1206
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I just installed the joying intel unit. So far so good. I've had another joying unit, 4.4.4, in the wife's rav4 since 2016 ish. Still running ok. For what i use it for, it's ok.
    Joying also offer 2yrs warranty on their unit. Their canbus harnes is direct plug 'n play, even for the factory camera. Even though they said it doesnt support factory camera on their site. The harness they send the 2nd time was the correct one for my sequoia with jbl. Everything plugged in. They even included the usb adapter cable to retain the factory usb/aux port. which i also bought one thinking they were not included. But it was.
    True plug n play kit. I didnt have to modify anything. Except one small thing in the back for the swc to work. You also have to pick the correct canbus protocol for your vehicle. Anything camry or rav4 with (amp) will work with steering wheel control. 20200302_180431.jpg IMG-20200306-WA0002.jpg 20200406_151132.jpg IMG-20200406-WA0005.jpg 20200406_150625.jpg
  7. Apr 22, 2020 at 11:51 AM
    #1207
    pedroyap
    pedroyap New Member
    Peter
    For those who installed an aftermarket amp with their Dasaita, did you use the cutoff frequency and Bass frequency? I am assuming these are the HPF and LPF. I had them turned off and adjusted the crossovers on the amp. I had to adjust the loudness and bring up a tad the "G" on the Bass and "G" on the Sub for the subwoofer to produce good bass. Did you guys do the same? I am assuming the "G" stands for Gain and "F" for frequency. @916tundra saw you have some posts installing an aftermarket amp on your dasaita. What are your settings on this section that I just described? Can you please share.
  8. Apr 22, 2020 at 12:29 PM
    #1208
    minter66
    Update: Dasaita is shipping me a new motherboard. Basically replace the guts of the Dasaita unit and keep the original screen/wiring/harness.
    I will report back if it works.
    McMason and BrandonL812 like this.
  9. Apr 22, 2020 at 2:46 PM
    #1209
    Bsenra11
    Bsenra11 New Member
    Hey all, just purchased this unit. Went to install today and I have one plug that does NOT match up with corresponding plug on the harness. I believe it is my back up camera because that’s the only thing that does not work. Am I supposed to have a canbus for my truck. 2018 Tundra SR5
  10. Apr 23, 2020 at 8:13 AM
    #1210
    supermotobobby
    supermotobobby New Member
    Bobby
    2022 Tundra Platinum 4x4
    My Navigation doesn't work. Do I have to connect to a hot spot?
  11. Apr 23, 2020 at 8:15 AM
    #1211
    BrandonL812
    Brandon
    If you use google or any online base map, then yes.
    If you use the offline map that came with the unit, then no.
  12. Apr 23, 2020 at 8:15 AM
    #1212
    kameleon
    kameleon New Member
    Jackson, MS
    2015 Crewmax Limited 5.7 MGM
    Only if you are using an app that requires data. For instance Google Maps requires data unless you download offline maps but then it requires data for that. Waze is online only. Sygic is the best offline one I've used.
  13. Apr 23, 2020 at 8:19 AM
    #1213
    supermotobobby
    Bobby
    How do I make the navigation that came with the unit work because they keep saying offline retry?
  14. Apr 23, 2020 at 8:23 AM
    #1214
    supermotobobby
    Bobby
  15. Apr 23, 2020 at 8:24 AM
    #1215
    supermotobobby
    Bobby
  16. Apr 23, 2020 at 9:43 AM
    #1216
    BrandonL812
    Brandon
    When you tap on navigation icon, does it open to google maps or other map app? It look as though that app you are using is trying to go online to get data. So you may need to hotspot your phone or use your home wifi to get the navigation to go online.
    The search screen look like google maps. If it's google map, you have to be online for it to work. Unless you pre download the offline maps then it wont requires internet.
  17. Apr 23, 2020 at 10:59 AM
    #1217
    supermotobobby
    Bobby
    It opens google maps, I thought it came with Navigation already installed on an sd card???
  18. Apr 23, 2020 at 11:37 AM
    #1218
    BrandonL812
    Brandon
    You need to change the navigation default to whatever the factory is so you can use the preloaded map on your map sd card.
    Try looking under the setting for navigation and change it from google maps to the factory one, im not sure what that would be. But it should be there.
  19. Apr 23, 2020 at 11:39 AM
    #1219
    supermotobobby
    Bobby
    Ok, I'll try. Thank you
  20. Apr 23, 2020 at 12:13 PM
    #1220
    McMason
    McMason New Member
    Scott
    Boise, Idaho
    2019 TRDOR CM Cement
    I just saw this comment. Hopefully I can help somebody after having the same issue. Sometimes the units come with different default settings. If you go in to the settings menus, you will see an option to have the front cam on or off. If the default is set to off, the fcam app won't appear. Once you switch it to ON, the app will be visible.
    The yellow triangle usually means you have the input plugged in wrong. Even if the label says you've done it correctly, try a different yellow RCA. I have found 2 wires labeled incorrectly (the other was the sub out-it was switched with the mid out).
    A general note for others on the fence about getting one of these: I like the unit, but there's a reason these cost ~$550 and the big Alpine unit costs ~$1500. There is definitely value here if you're willing to play around with the settings and you don't want to maximize every potential feature. You just aren't going to get Toyota quality for Yugo money.
  21. Apr 23, 2020 at 1:44 PM
    #1221
    effektz
    effektz New Member
    Fort Worth, TX
    2017 Tundra CM TSS Offroad
    Hello all!
    Sorry its been a while since I have been able to get on here, life has been in the way. Anyways Ive had the unit for almost a year and so far so good. Just a couple things I hope someone can help me fix
    1 - When turning the audio volume from 0 to 1, the sound is loud for being the first step. After the first one, the sound gradually increases nicely. How can I get the 1st volume to be lower in sound?
    2 - My Apple Car play will disconnect from my phone after 30 mins of it being connected. Do you think it could be a loose wire?
    3 - How can i move the FCAM app to the front page? I cannot for the life of me get it to move off the page its on
    4 - How do I update the AndroidAuto/CarPlay? I have the 1st version of the Android 9 system not sure if that helps
    Thanks in advance for any help!
  22. Apr 23, 2020 at 7:42 PM
    #1222
    egibson606
    egibson606 New Member
    Eric
    Georgetown, ky
    2019 super white SR5 tundra
    Just press and hold the icon then drag. Its kinda tricky to drag from one page to another. But just drag it to the left edge, wait a second and it will move to the next page.
  23. Apr 24, 2020 at 8:07 AM
    #1223
    codygs83
    codygs83 New Member
    Cody
    TX
    2019 Tundra TSS
    Me personally I didn't notice a difference with the G in the eq for Sub wether it was all the way up or down. The eq setting for Bass is what I adjust and makes an audible difference on mine. Mine is set at 62hz and the gain all the way up. I am however using a 5 channel amp with a separate bass knob. So I only use the knob for quick easy adjustments.
  24. Apr 24, 2020 at 12:49 PM
    #1224
    pedroyap
    pedroyap New Member
    Peter
    Thanks @Cody010393... I see a difference on the "F" on the BASS level... I just tried the "G" all the way up and then play around with the "F" of the BASS... It makes a difference... I am guessing when it is "ON" it is limiting the Low Pass Filter, depending on what it is set. I am hoping when turned "OFF" that will be native and will allow the amplifier to filter the sound - hopeful on this. I bought a bass knob so i can just adjust the bass from there.
    I also turned "OFF" the CUT FREQ, which I am assuming the High Pass Frequency. I set my HPF in the amplifier as well. The LOUDNESS I guess is four loudness, but what is PHAT? My SUB is also "ON" but I set the "G" all the way down. I set my gain on the amp for both the sub channel and the door speakers. I also have a 5 channel amp.
    By the way, I do not get any distortion on the dasaita unit with the amp gain all the way down and the dasait volume all the way up. I could see the SMD hitting the test tones but no distortion at all. Anyone else getting the same result?
    I am hoping @916tundra can share his experience on tuning his dasaita with an aftermarket amp. I do not have a CANBUS to begin with so not sure if that makes a difference.
    Thanks.
  25. Apr 24, 2020 at 1:50 PM
    #1225
    pedroyap
    pedroyap New Member
    Peter
    @916tundra @jmevis @minter66 @VTYOTA what did you set the CUT FREQ and BASS to? Did you turn them off? I am assuming SUB is “ON” and “G” is all the way down? Did you guys add a bass knob on your amplifiers and just adjust the bass from there? I plan to add a knob too. What did you set your PHAT and LUD?
  26. Apr 24, 2020 at 2:50 PM
    #1226
    McMason
    McMason New Member
    Scott
    Boise, Idaho
    If you dig through the settings (I think it's under system settings) you will see amp volume as an option. You can set that as low as -15 or something similar. That starts off volume 1 at a lower level, but you'll still have plenty of room to go up.
  27. Apr 27, 2020 at 7:56 AM
    #1227
    minter66
    Uh, i'll have to take a photo. I set it all by ear until sound was groovy.
    I get my replacement Dasaita motherboard on Friday - so hopefully I will be thumping along soon.
  28. Apr 27, 2020 at 8:00 AM
    #1228
    pedroyap
    pedroyap New Member
    Peter
    Thanks... I am curious how you setup your filters, LUD (LOUDNESS), PHAT, CUT FREQ, BASS, and SUB. Thank you.
  29. Apr 27, 2020 at 8:01 AM
    #1229
    pedroyap
    pedroyap New Member
    Peter
    Also, are you running any aftermarket DSP?
  30. Apr 30, 2020 at 6:26 PM
    #1230
    Stocky Balboa
    Stocky Balboa New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Been really eyeing the dasaita for my ‘18 limited w/JBL but I’m not sure how that face holds up to off-roading?
    What’s your guys take?
    After having one for awile would you recommend it?
    Thanks
