Dasaita Android Head Unit
Discussion in 'Audio & Video' started by 916tundra, Apr 27, 2019.
  1. Jan 24, 2020 at 3:22 PM
    #1081
    lighthouze08
    lighthouze08 New Member
    The hdmi output supports touchscreen interface? I though it’s usually done with another usb or serial interface?
  2. Jan 24, 2020 at 3:32 PM
    #1082
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    Ok updating
  3. Jan 24, 2020 at 3:32 PM
    #1083
    SiberianTundra
    Greg
    War Machine
    Yes it works but you need HDMI and usb
  4. Jan 24, 2020 at 3:49 PM
    #1084
    SiberianTundra
    Greg
    War Machine
    Ok update done I’ll monitor to see. If it solved my issues. I really want to like this stereo
  5. Jan 24, 2020 at 4:33 PM
    #1085
    supermotobobby
    supermotobobby New Member
    Bobby
    2022 Tundra Platinum 4x4
    What in car settings is did you have to do to make the factory back up camera work?
  6. Jan 24, 2020 at 6:00 PM
    #1086
    lighthouze08
    You don’t need anything . Just plug the factory camera into the wiring harness that comes with the dasaita unit
  7. Jan 24, 2020 at 7:16 PM
    #1087
    supermotobobby
    Bobby
    There is now place to plug the camera into the wiring harness.....
  8. Jan 24, 2020 at 7:29 PM
    #1088
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    It should all came with the canbus the seller send you. The only issue is whether the canbus is programmed to send the correct voltage to power up the factory camera.
  9. Jan 24, 2020 at 7:48 PM
    #1089
    SiberianTundra
    Greg
    War Machine
    I updated through USB using Dos FAT 32 format. Worked great.
    Love the new update.
    Volume for HDMI screen is disabled. That is awesome!
    Also few other things now work better.
    Still need to test the LED in the morning. We shall see if it fixes the issue. Over all nice update. Props to Dasaita for trying to better this .
    Also noticed there is a new slider for Night mode. But it does nothing really. Unless I'm missing something.
    Bluetooth connection is better. Apple CarPlay connects better. Wifi connections to hotspot is still a hit and a miss. But I noticed that it depends on where I am located in the city. Only enough.
    the layout is better. Siri works much better too.
    Dgjman likes this.
  10. Jan 24, 2020 at 7:49 PM
    #1090
    supermotobobby
    Bobby
    Which connector is for the camera?
  11. Jan 24, 2020 at 7:50 PM
    #1091
    BrandonL812
    Brandon
    Post picture of your canbus.
  12. Jan 25, 2020 at 7:58 AM
    #1092
    supermotobobby
    Bobby
  13. Jan 25, 2020 at 9:01 AM
    #1093
    BrandonL812
    Brandon
    Do you have phot of all the plugs?
  14. Jan 25, 2020 at 1:17 PM
    #1094
    supermotobobby
    Bobby
  15. Jan 25, 2020 at 1:27 PM
    #1095
    BrandonL812
    Brandon
    In your first photo of the 2 plug. Can you probe the right (big) plug. Probe the dark grey and light grey. See if you get 6v. Then the red and white wire beside those greys. Probe those also, see if you get any reading. Im purely guessing the dark grey and light grey is the camera power (6v). The other 2 are the video signal power and ground.
    Put your mulimeter black probe to ground and stick the red in yhe dark grey or light grey wire. See if 6v show up. Put the car in Reverse while probing.
    If my speculation is correct, you will see 6v on one of those wire. The other will be the negative (ground) for that 6v.
    Dgjman likes this.
  16. Jan 25, 2020 at 1:31 PM
    #1096
    supermotobobby
    Bobby
    So your saying this Canbus and Vehicle specific harness really isn't "Plug and Play"?
  17. Jan 25, 2020 at 2:42 PM
    #1097
    lighthouze08
    You shouldn’t have to do anything, there should be a cam input for the backup camera, all you have to do is plug in the rca cable. Do you see any rca that’s label cam?
  18. Jan 25, 2020 at 3:04 PM
    #1098
    supermotobobby
    Bobby
    Yes, there is an RCA CAM but the factory cam harness doesn't connect to an RCA. That's what I'm confused about.
  19. Jan 25, 2020 at 3:16 PM
    #1099
    lighthouze08
    Can you take a picture of your factory cam harness?
  20. Jan 25, 2020 at 3:19 PM
    #1100
    BrandonL812
    Brandon
    It should be that big plug in his first photo
  21. Jan 25, 2020 at 4:21 PM
    #1101
    supermotobobby
    Bobby
    I have two harnesses from dasaita. Do you know which part number is for my 2010? They are XC-5217-0031(LC), and the other is XC-5217-0061 (LC)
  22. Jan 27, 2020 at 6:09 PM
    #1102
    robbb38
    robbb38 New Member
    Rob
    18 limited crewmax
    It seems like there’s a bunch of different models. Anyone know which the “best” model is??
  23. Jan 27, 2020 at 6:37 PM
    #1103
    SteveM
    SteveM New Member
    2014 sr5 crewmax
    Dasaita radio, baha designs lightbar
    I got my unit in last week and have it all set up. The only setting I cannot figure out is....when I put the truck in reverse and the back up camera comes on the image on the screen is flipped horizontally. Anyone know how to fix this? I see that you can tap on the camera icon. And it flips it that way but it does not stay in the correct position. Any ideas?
    SiberianTundra likes this.
  24. Jan 27, 2020 at 10:02 PM
    #1104
    SiberianTundra
    Greg
    War Machine
    Ill check factory settings tomorrow. You can go factory settings for more stuff. But not sure and will check.
  25. Jan 29, 2020 at 7:34 AM
    #1105
    supermotobobby
    Bobby
    So Dasaita says my factory backup camera will not work even with their vehicle specific harness. Is this correct? Mine is a 2010 limited
  26. Jan 29, 2020 at 7:47 AM
    #1106
    BrandonL812
    Brandon
    I dont know how true it is. Can you post up all the 24 pin plug from the dasaita harness? Let me see how they pin it.
    Because if they dont work, you will have to get something lik this and do it yourself.Screenshot_20200129-103825_AliExpress.jpg
    You can see (reading right to left) pin 11, 12, 23, and 24 is occupied for the camera power (6v) and video signal.
    Pin 11: video positive signal
    Pin 23: video negative signal
    These 2 pins(above) = yellow male rca wite.
    Pin 12: power 6v+
    Pin 24: power 6v-
    You already identified the reverse signal wire. Pin 2 from the 28 pin plug (also reading right to left)
    You can compare that to the dasaita 24pin plug and see if those 4 slots are occupied.
    If it is occupied it should look like the photo below, it may have more pin occupied in other slots also. I dont know what those other one are or what they do.
    As far as the converter goes, it will need to be connected to an acc+ and ground. It will pull power and reduce to 6v to turn the camera ON.
  27. Jan 29, 2020 at 7:51 AM
    #1107
    supermotobobby
    Bobby
    I'll post pictures when I get a chance
  28. Jan 29, 2020 at 10:22 AM
    #1108
    supermotobobby
    Bobby
    There is no 24 pin harness on my dasaita harness.....
  29. Jan 29, 2020 at 10:31 AM
    #1109
    BrandonL812
    Brandon
    So you dont have a plug from your dasaita harness that plug into the factory 24 pin plug?20200105_215946~4.jpg
  30. Jan 29, 2020 at 12:39 PM
    #1110
    supermotobobby
    Bobby
    No I don't. The first harness they sent me does buy, it doesn't plug into the Canbus.
