Dasaita Android Head Unit
Discussion in 'Audio & Video' started by 916tundra, Apr 27, 2019.
  1. Sep 26, 2019 at 2:21 PM
    #721
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    I have a spare one somewhere I can send too. Probably faster.
  2. Sep 26, 2019 at 2:44 PM
    #722
    greener
    greener New Member
    2019 TRD off-road MBM
    Thanks, but no worries. If dasaita doesn’t send me one I’ll get one from Amazon. Thanks for the help though!
  3. Sep 26, 2019 at 3:22 PM
    #723
    kameleon
    kameleon New Member
    Jackson, MS
    2015 Crewmax Limited 5.7 MGM
    Ok so I just installed the unit I got from prerunnerseth a few months ago. So far I'm liking it over the Tesla but have a few questions:
    1. How do you deal with the slop in the screen? It seems to move with the slightest touch.
    2. Where are the settings to change the fastboot timeout and such? *strike that, I found that post*
    3. How did you fit the unit in the dash while stuffing the wires behind it? It seems VERY tight back there now.
    Still have a few bugs to iron out and have to get used to a smaller screen but so far so good.
  4. Sep 26, 2019 at 4:49 PM
    #724
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    there like propeller twist knobs at the connections points. tighten them and it will tighten the ball bearing notches that hold the display
  5. Sep 26, 2019 at 4:51 PM
    #725
    kameleon
    kameleon New Member
    Jackson, MS
    I did that and it still flops around driving down the road. I'll try to get it tighter but I have fat fingers.
  6. Sep 27, 2019 at 6:04 AM
    #726
    buffaluphagus
    buffaluphagus —————————————
    I have mine basically leaned against dash so it doesn't move at all
  7. Sep 27, 2019 at 3:45 PM
    #727
    greener
    greener New Member
    Got this bad boy installed today. Love it so far. Wireless CarPlay works perfect. The Android system is going to take some time to get used to, but I’m liking it so far. Bought a backup camera to use as a front camera, not a good choice.
    Can anyone recommend a good front camera?
    Only issue I seem to be having is with the parking sensors, don’t seem as sensitive as they were. I can get really close to something now before they activate. Was this controlled from the original head unit? Is there a setting I can change somewhere?
    Thanks
  8. Sep 27, 2019 at 3:47 PM
    #728
    lighthouze08
    lighthouze08 New Member
    I forgot which app but it’s one of the apps on there that will let you change the sensitivity of the sensors
  9. Sep 28, 2019 at 4:35 AM
    #729
    Tito2018
    Tito2018 New Member
    2017 SR5 White Tundra TRD
    I’m buying a unit on Amazon but they said buy it from seller in order to send me the Canbus adapter? Is something fishy here? I just don’t want to wait weeks for it! Any suggestions? Is just a harness or also needs a module to work ?
  10. Sep 28, 2019 at 9:27 AM
    #730
    greener
    greener New Member
    Buy from "Dasaita official store" on Amazon. after you buy, send them a message with year and model of vehicle. they will include canbus and plug and play harness for your truck. only thing you will need is a dash kit, and in my case a factory usb adapter to use the factory usb slot, they said they were out of stock when they shipped mine. Shipping was a week exactly.
  11. Sep 28, 2019 at 7:14 PM
    #731
    Tito2018
    Tito2018 New Member
    Thanks for response, the thing is they don’t want me to buy it on prime, even is the option, directly from store is $10 more and takes a month according to aproxímate delivery time, I guess it’s coming back because they send it already
  12. Sep 28, 2019 at 8:18 PM
    #732
    tinman10101
    Tinman
    2016 MGM Crewmax
    sucks ... looks like they are trying to save by not shipping it to you with air express.
  13. Sep 30, 2019 at 2:05 PM
    #733
    cha5.6
    cha5.6 New Member
    Im still working on my reverse camera and this is the outcome when i shift reverse B07F4104-3F7F-4028-A335-BBF012C1A8E4.jpg
    I connected the yellow RCA to CAM VID IN(headunit) and RED wire to ORANGE WIRE(headunit) and at the back YELLOW camera RCA To YELLOW RCA harness then then RED wire from harness to reverse lamp (+) wire BLACK wire from harness to ground.help pls!
  14. Sep 30, 2019 at 8:35 PM
    #734
    greener
    greener New Member
  15. Oct 1, 2019 at 5:26 PM
    #735
    cha5.6
    cha5.6 New Member
    Help pls...
  16. Oct 1, 2019 at 5:37 PM
    #736
    916tundra
    916tundra [OP] New Member
    Ken
    2017 Tundra Crewmax
    You should DM @minter66 since he installed a reverse camera for his truck. Most of us have the 3rd gen truck and didn’t have to hook up a reverse camera.
  17. Oct 1, 2019 at 5:38 PM
    #737
    916tundra
    Ken
    2017 Tundra Crewmax
    Also it looks like you don’t have video signal, try hooking up the yellow rca from the camera to another input.
  18. Oct 2, 2019 at 7:13 AM
    #738
    gmeek2
    gmeek2 New Member
    2017 Silver CM
    I used the eraser end of a new No. 2 Pencil. Lol
    I fits back there easily and the eraser part grips the wings good enough to get them snug.
  19. Oct 2, 2019 at 7:59 AM
    #739
    kameleon
    kameleon New Member
    Jackson, MS
    Good idea. I think I might have something wrong though because I can't tighten the wings any more and it is squeaking pretty bad driving down the road.
  20. Oct 2, 2019 at 8:22 AM
    #740
    minter66
    minter66 2007 TSS CrewMax
    Thanks for tagging me, work has picked up and I am not on as much as I used to be.
    @cha5.6 have you tapped the reverse signal wire in the lower passenger floorboard?
    And as mentioned, are you in the correct RCA port? Best way to tell ( I did the same thing) was to switch to the FCAM input and see if it shows there, while in reverse.
  21. Oct 2, 2019 at 8:23 AM
    #741
    916tundra
    Ken
    2017 Tundra Crewmax
    Make sure you have the pins fully seated before tightening the wing screws.
  22. Oct 2, 2019 at 8:27 AM
    #742
    tinman10101
    Tinman
    2016 MGM Crewmax
    I have a feeling that the ball bearing inside the propeller might have inadvertently fell out. The reason I know this is because I took those connectors off thinking you had to remove them for display installation and inside there is a spring and then a tiny ball bearing. You have to be careful because it can easily fall out and land somewhere on the floor to never be found if you unscrew those propeller knobs. I almost lost one of the ball bearings but once you see whats inside, you understand how the connector works by placing tension on the ball bearing into the slotted holes you see on the hinge of the display monitor. I would venture to take both sides out to see if one side is missing or both are. Just thinking out loud. Hope this helps.
  23. Oct 2, 2019 at 2:37 PM
    #743
    19TRDPRO_FL
    19TRDPRO_FL New Member
    Paul
    Parkland, FL
    2019 Tundra TRD Pro
    Audio: Pioneer 8200NEX Infinity Kappa complete speaker package 4 Channel Kenwood amp 5 Channel Kenwood amp 10 inch JL Audio W1 shallow mount sub X 2 Readylift Pro Plus 4in lift (6 total) 22x12 Fuel Sledge wheels 35x12.5R22 Nitto Ridge Grapplers LED bar in hood scoop LineX step rails
    After tons of trouble shooting and numerous emails, they finally admitted to sending the wrong harness and agreed to send the corrected canbus... Finally my controls will work and the back up camera!!!
    Side ask, has any one figured out how to get the wifi to auto connect to my phones hotspot? I have to play this fun game of turning the hotspot and wifi, off and on to get it to finally connect. Then if I turn the truck off, the game starts all over...
  24. Oct 2, 2019 at 3:01 PM
    #744
    cha5.6
    cha5.6 New Member
    @916tundra i did yellow RCA camera to yellow RCA rear video in(Dasaita).then red wire from camera connected to orange wire rear cam(Dasaita).i will try switching them later on..tnx
  25. Oct 2, 2019 at 3:06 PM
    #745
    cha5.6
    cha5.6 New Member
    @minter66 i did the front camera and its working I will try to tap on reverse light wire to see if it’s gonna work.tnk you guys
  26. Oct 2, 2019 at 4:37 PM
    #746
    cha5.6
    cha5.6 New Member
    @minter66 ,@916tundra, I will be posting some pics here soon on how I connect the wires and RCA’s
  27. Oct 3, 2019 at 10:21 AM
    #747
    lighthouze08
    not sure what i changed in the Desaita setting, but my truck stopped beeping when i lock/unlock using the keyfob. It used to beep, but not anymore. I changed the canbus settings around, still no go. Does anyone else have the same issue?
  28. Oct 4, 2019 at 9:33 AM
    #748
    codygs83
    codygs83 New Member
    Cody
    TX
    2019 Tundra TSS
    To anyone with an AM amp, did you use the camera power line on the RCA harness as a remote turn on for the amp? I'm installing a 5 channel amp soon and don't remember seeing a remote wire.
  29. Oct 4, 2019 at 9:49 AM
    #749
    tinman10101
    Tinman
    2016 MGM Crewmax
    It should be labeled on the canbus as well as "ANT" or "AMP CONT"
    codygs83[QUOTED] likes this.
  30. Oct 4, 2019 at 11:51 AM
    #750
    lighthouze08
    i used the cigarette acc wire in the rear . There should also be a 12v acc wire on the speaker harness under the passenger seat u can use for remote wire
